Blinkers Aren't Working--Weird Problem/Fix
Discussion in '1st Gen. Tacomas (1995-2004)' started by gatrapper, Sep 6, 2016.
  1. Sep 6, 2016 at 5:01 AM
    gatrapper
    gatrapper [OP] Well-Known Member
    Senoia, Georgia
    1998 SR5 4x4
    Hey Y'all,
    I've been dealing with blinker problems for the past two years. In the mornings my blinkers would never work, but by the afternoon they would work fine. I assumed it had something to do with the humidity/moisture.
    I brought my truck to the Toyota dealership and they looked at it for a week and could not find a problem.
    This weekend my truck's blinkers didn't even turn on in the afternoon, so I started checking relays and fuses. I turned on my caution lights and they worked. Then I tried my blinkers and they started working.
    This morning I hop in my truck to head to work. I turn on my blinkers and they don't work. I hit the button for the caution lights and they turned on. I turned them off and hit my blinkers and they worked.
    Any idea of what the problem could be?
  2. Sep 6, 2016 at 7:48 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Could be a week flasher unit. Kinda hard to get at, from what I've heard. It is attached to the inside fuse box behind the dash near the driver's left knee.
  3. Sep 6, 2016 at 3:46 PM
    Jolly Onion
    Jolly Onion Cheap is not Good & Good is not Cheap
    Alex
    Forest Hills, N.Y
    2004 Tacoma 6cyl crewcab
  4. Sep 6, 2016 at 6:03 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    All of the wiring for turn signals passes through the hazard button, so it's possible there is a loose connection there. More likely that you have a weak flasher unit and the higher amperage draw of the 4 flashers being on kicked it into gear for a bit.
  5. Sep 6, 2016 at 6:05 PM
    jackkpecoraa18
    jackkpecoraa18 I like to party.
    Jack
    Bradford, Pennsylvania
    2009 Silver Lifted Regular Cab
    Lotsa shit.
    damn that blinker fluid.
  6. Sep 6, 2016 at 6:09 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    I had a similar problem. Turned out my hazard button was stuck half way in between on and off. Pulled it out and everything is good now.
  7. Sep 7, 2016 at 7:38 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    Yup! Same deal here. I noticed too that if you press the hazards half way down, it activates the either the left or right turn signal. Wierd.
  8. Sep 7, 2016 at 7:59 PM
    Indy
    Indy Master of all I survey.
    You've heard wrong. 5 seconds to swap one out.
  9. Sep 10, 2016 at 3:01 AM
    fortiz619
    fortiz619 yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    I had the some problem on my 04 Tacoma , after trying everything I found out That the problem was that taillights were filled with moisture and the connections on the bulbs were rusty and contact was weak or wasn't happening , I replaced bulbs sanded the connections with a pick and sand paper, used a lot of dialectic grease since I didn't want to buy new taillights , fixed the problem
