Blinker blinking faster?
Discussion in 'Technical Chat' started by Pismo, Dec 2, 2011.
  1. Dec 2, 2011 at 11:04 AM
    Pismo
    Pismo [OP] Active Member
    Tasha
    California
    06 Tacoma PreRunner TRD
    3" Spacer Lift, 17" dick cepek dc2 wheels, 265/70/17 bfgoodrich rugged terrain t/a, ipod adapter w/ stock stereo, jdm headlights & taillights, roof racks, side steps, exhaust tip
    What does it mean when my left blinker is blinking faster than my right? Someone told me that meant I needed to replace a bulb. - But. The thing is, it's slightly intermittent. It blinks faster when driving and it doesn't when in stopped and in park.
    anyone? :\
    DJKitten likes this.
  2. Dec 2, 2011 at 11:05 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do all the bulbs work? Usually a fast blinker means one of the bulbs is out. Put the 4-ways on, get out of the truck and make sure all 4 blinker lights are working properly.
  3. Dec 2, 2011 at 11:06 AM
    jjbsocal
    jjbsocal Well-Known Member
    Jeff
    So☆Cal
    2010 DCLB PreRunner TRD Sport
    Camburg MT; 4.0 Spindles and UCA's, Fox Extended Travel with Resi's all 4 Corners, All Pro Expo Leaf Pack, Method Standard's, BFG AT's, DTLT's, 1st Gen TRD CAI, Magnaflow Pro Offroad Exhaust..
    One of your bulbs are toast.. that is all.
  4. Dec 2, 2011 at 11:06 AM
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    Your symptoms blow the low voltage at idle theory out of the water.
    Poltergeists perhaps JK
  5. Dec 2, 2011 at 11:07 AM
    BattleStatic
    BattleStatic Gluten Free
    Goodyear
    2013 TRD O.R. 4x4
    OME 885's w/Nitro Chargers and Dakar rear leafs ATX AX199 Mohave I I (0 offset, 4.5" bs) BFG KM2 285 75 16 Avid Sliders w/ kickoffs Pelfreybilt rack w/ Tepui RTT Katzkin front and rear Sunroof
    Bulb out.:notsure:
  6. Dec 2, 2011 at 11:10 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    everything they said, or it just might be a bad connection. the classic test/(sometimes fix) is to walk out and see which light is not blinking and give her a little bump with the side of your fist. i used to do it all the time with my jeep lol. but yeah, it's skipping that light so the other one is blinking double speed!
  7. Dec 2, 2011 at 11:31 AM
    Pugga
    Massachusetts
    Basic Tools 101, if it moves and it shouldn't, use duct tape. If it doesn't move and it should, use WD-40. Lastly, if you can't fix it with a hammer, then you have an electrical problem. :D
  8. Dec 2, 2011 at 2:23 PM
    Toyoghi
    Toyoghi Well-Known Member
    Shoghi
    Calgary, AB
    2011 Tacoma Double Cab
    Solid tri-fold Tonneau, Deezee Bed mat, Pop n Lock.
    I actually found this so funny, I considered putting it in my sig. :rofl:
  9. Dec 3, 2011 at 9:56 PM
    Pismo
    Tasha
    California
    Thanks for the help, turns out that my left front blinker is slowly dying. =)
  10. Dec 4, 2011 at 6:43 AM
    jgwheeler17
    NC
    neglect, mostly.
    dude, i can build shit with wood, fabricate metal, drive anything with a solid chassis any size anywhere, but i sure as hell aint a mechanic. so, before i usually attempt to appropriately fix something or consult someone who can i usually just hit it several times. in my experience it works well on these trucks.
  11. Dec 4, 2011 at 7:02 AM
    Blackshirts
    Blackshirts Well-Known Member
    TX
    09 PreRunner-Totaled. 2016 SR5 Blue DC
    Stuff
    Make sure when replacing the old one push hard till you hear it snap. If not any time you go over a bump it will loosen and not work.
  12. Dec 4, 2011 at 7:11 AM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    This is the simplest advice when diagnosing lots of electrical problems. I can't tell you how many light bulbs, A/C control heads, instrument clusters & radios I've diagnosed as bad just by simply tapping/banging on them. :thumbsup:
  13. Dec 4, 2011 at 7:14 AM
    jgwheeler17
    NC
    neglect, mostly.
    suck it M3. suck it long. . . . and suck it hard.
  14. Dec 8, 2011 at 4:13 PM
    Balien
    Balien Well-Known Member
    Central Canada
    TRD Tacoma auto, long box in red
    lighted 4x4 switch, python alarm/starter, weather tech matts, bug and rock deflector, , kuda cell phone mount in matched grey. DMV2 Tires, Bilstein 5100 lift, Icon RXT leafs. Sprayed the frame with Rust Check All the time.
    Wow as an avionics technician for 10 years. I never smack things just a light tap or jiggle should do. By the way if all the lights work it's probably the timer relay.
    Electronics tools 101. If you cant use a multi meter to fix it, replace it.
  15. Dec 8, 2011 at 4:16 PM
    pyroskier
    pyroskier Well-Known Member
    Jacob
    Laramie, WY
    2004 Ext Cab TRD 3.4
    I would have checked my blinker fluid first... but that's just me.
    I only run synthetic in mine.
  16. Dec 8, 2011 at 4:20 PM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    No one likes the sarcastic type :anonymous:
  17. Dec 8, 2011 at 4:21 PM
    pyroskier
    Jacob
    Laramie, WY
    :confused:
    :D:D:D:D
  18. Dec 9, 2011 at 3:58 PM
    Pismo
    Tasha
    California
    It turned out that I had a short in my right blinker...and still do so until I replace the blinker housing I guess?
  19. Dec 9, 2011 at 4:49 PM
    NelsonTacoma
    Tucson, AZ
    If it's just a short in the connector you don't need to replace the whole housing. The connector that the bulb goes in can be replaced by itself. The housing is just plastic and does not have anything to do with the wiring.
  20. Dec 10, 2011 at 3:39 PM
    Pismo
    Tasha
    California
    O rly now? Is this something I can find at autozone by any chance? Haha
