Blindspot monitor not available message
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aleriance, Jan 14, 2019.
  1. Jan 14, 2019 at 5:30 PM
    aleriance
    aleriance [OP] Well-Known Member
    Jorge
    Naples, FL
    2017 TRD Off-Road 4x4
    CMC 285/70/17
    For about 2 weeks now my blindspot monitoring isn't working. Dash displays "blindspot monitor not available message".
    Took it to Toyota over the weekend and they only came back with letting me know that the inside of the rear bumper has some mud packed inside and that a diagnostic came back with "inoperable" status for the driver's side BSM sensor. Replacement will be $870 for just the part. Not covered by warranty obviously. No thanks.
    Took it home, removed both bumper caps and gave it a good cleaning underneath. Used electrical cleaner on sensor connectors, and disconnected the battery in an attempt to reset the message, but no luck. No wires look damaged or frayed. Has always worked fine and no wheeling was done anytime prior to it failing.
    Anyone care to chime in?
  2. Jan 14, 2019 at 5:57 PM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Open a claim with Toyota...inform them that you did not receive the benefit of your bargain the very contract thought to raise and limit your actions. The warranty is a performance contract between Toyota and the owner of the vehicle...the dealership has no authority to deny a claim as they are not a party to the contract. They can only dismiss a complaint...Request an appointment at the dealership when the Toyota regional rep is available to review your claim...
  3. Jan 15, 2019 at 1:31 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    Anyone else?
  4. Jan 15, 2019 at 1:51 PM
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    If it still doesn’t work after you’ve cleaned them, try another dealer. If that fails, do what @Ronzio said
  5. Jan 15, 2019 at 2:00 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Another member just had this same problem. It was a week or so ago. Try searching, and see if you can find his out come. I never looked back to see if he got it resolved, or not.
    If I remember right it was also mud packed, and dealer wanted $$$ to fix.
  6. Jan 15, 2019 at 2:12 PM
    na8rboy
    WI
    Ok, I found his post, dealer said it was because of a scuff on BSM. Also dealer complained about mud and horse shit packed in bumper. He cleaned bumper BSM's and it still didn't work after driving on city streets. But in his final post, he stated it works now. Needed to drive around awhile after cleaning, on hwy . so it would recalibrate.
    His post - BSM error dealer trying to charge me
    toddcmenard likes this.
  7. Jan 19, 2019 at 5:18 PM
    aleriance
    Jorge
    Naples, FL
    CMC 285/70/17
    This worked. It wasn't coming back on because I was driving with BSM OFF to avoid the annoying alert on the dash... Thank you!
    For anyone in the future, a decent clean and then drive around for a few days with BSM ON and it will begin to work again. By the way, all city driving was enough for mine.
  8. Jan 19, 2019 at 5:33 PM
    na8rboy
    WI
    :thumbsup:
    GillyLink likes this.
  9. Jan 29, 2019 at 10:16 PM
    strictlys
    strictlys Well-Known Member
    2016 Super White Tacoma DC TRD OR SB
    Mine hasn't worked for a while. I am out of warranty as well. I'll try the same thanks for the tip.
  10. Jan 29, 2019 at 10:30 PM
    here4cake
    here4cake Well-Known Member
    That message can also pop up if the sensors lose their calibration - that's a procedure that has to be done by the dealer, and they'll likely want $$ for it. Mine once lost calibration on a smooth highway and the dealer re-calibrated for free.
  11. Dec 30, 2019 at 6:06 AM
    trentpaulk
    trentpaulk New Member
    Trent
    Tacoma
    I'm having the same issue. Where exactly are the sensors?
  12. Dec 30, 2019 at 6:22 AM
    Tynan
    Tynan W3YIP
    Nick
    Austin Texas
    2017 Sky Metallic TRD Offroad
    Rear bumper corners under the plastic cover. You can see them from under the bumper in the corners. For what it's worth, I've had issues with mine since the truck was new and I've been back and forth with the dealer and toyota reps, and they ALWAYS blame me for the malfunction. They've been dirty before and worked fine, they have been clean and not worked at all. After my warranty was up, I turned em off and never looked back. If they are so susceptible to dirt and mud, why didn't Toyota put them in the tail lights like every other car maker? The world may never know!
  13. Dec 30, 2019 at 6:23 AM
    Madtown
    Madtown Well-Known Member
    Eric
    Madison,WI
    Former 3G Tacoma owner
    The BSM sensors have a failure rate. They are exposed to the elements & get corroded. Mine were replaced under my Toyota extended factory warranty at 42K. Out of pocked cost would have been $2600 otherwise. I replace them all the time on Mercedes as well so this isn't just a Toyota issue.
    Tynan likes this.
  14. Dec 30, 2019 at 6:25 AM
    Tynan
    Tynan W3YIP
    Nick
    Austin Texas
    Yeah, I understand. I wasn't implying that they wouldn't break or malfunction like any other part. I don't really feel like corrosion is an issue on my end though, living in the middle of Texas, there isn't exactly a lot of salt on the roads or anything.
  15. Dec 30, 2019 at 6:45 AM
    WreckedRooster
    WreckedRooster Well-Known Member
    Jake
    Oklahoma
    2020 MGM DCSB
    I'm wanting to do a rear bumper, but am going to wait until either my BSM's fail or I crush/destroy the factory bumper. I like my BSM's (mainly for cross traffic when I'm backing up out of a parking spot), but have driven 18 years without them and have been just fine.
  16. Dec 30, 2019 at 6:52 AM
    caribe makaira
    Caribbean, Puerto Rico
    eurowner, Kev250R and Junkhead like this.
  17. Dec 30, 2019 at 8:24 AM
    fajitas21
    fajitas21 XMF - Extreme Mexican Food fo Life!
    Lee
    Collierville, TN
    4Runnerzzz
    Originally not Expo AF! Kinda Expo AF now...lame.
    For what it's worth mine failed when I took it to the beach. Cleaned really good. Went back to beach a year later, immediately failed again.
    I mainly quit going to the beach, but it's still frustrating. Left them off until the day I sold it. Next vehicle didn't have them in bumper.
  18. Feb 5, 2020 at 5:10 PM
    Daddy_Firebird
    Daddy_Firebird Well-Known Member
    Colorado
    2016 TRD Off Road DCSB MGM
    -Toytec Aluma 2.0 -SPC UCAs -Icon RXT Leaf Pack -Front & Rear Durobumps -Cooper ST Maxx Skinnies on Methods -RCI Skids -Leitner Rack -Custom Billet Shift Knob (7r41lbr34k3r) -Stromung "Tucker" Exhaust -Expedition Essentials TTM
    I’m getting the same error on my Taco. I had a good amount of ice around the rear bumper from rain turning to snow/ice but most of it has melted. I’ll have to give it a good cleaning next week and see if that fixes it.
  19. Feb 5, 2020 at 5:16 PM
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    I have never had an issue with mine. After reading this it sounds like I should take them off, sell them on eBay and put that money towards a nice metal bumper.
  20. May 17, 2020 at 4:04 PM
    fool41day
    fool41day New Member
    http://www.ttguide.net/blind_spot_monitor_system-386.html
    full toyota service manual page for everything with the BSMS system including tech troubling shooting procedures, key component locations, and if you were even bold enough and you had a tech steam you could recalibrate the sensors on your own.
    RMG2, GaryLaurenLogan and Kev250R like this.
