Blind Spot Monitor Issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tpete, Mar 17, 2023.
  1. Mar 17, 2023 at 11:02 AM
    tpete
    tpete [OP] Member
    Tom
    2019 TRD Sport
    While driving on the hwy, I received a BSM warning light, so I just turned them off until I got home. After reading thru the owner's manual, it said you should clean off the sensors, which I did. The warning light is still coming on........any suggestions???
  2. Mar 17, 2023 at 11:06 AM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    The switch is off and the warning light is still on? Is it on permanently or only when somebody is in your blind spot? What is wrong with having your blind spot being monitored, and a little light flashing occasionally?
    Stevie17 likes this.
  3. Mar 17, 2023 at 11:11 AM
    tpete
    tpete [OP] Member
    Tom
    2019 TRD Sport
    I turned the BSM off because it did not operate and the warning light stayed on. The warning light goes off once the BSM is switched off, but it is my wife's truck, and I want her to have the BSM working properly. Sorry if I did not make that clear in my original post.
  4. Mar 17, 2023 at 11:34 AM
    Anchovy
    Anchovy Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    Could be a broken wire, bad sensor, bad connector, etc.
  5. Mar 17, 2023 at 12:30 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Did you spray backside of rear bumper really well? Especially corner, pressure washer, self wash car war wash.
  6. Mar 17, 2023 at 12:33 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    Make sure you clean the right sensors. Lots of people confuse the little dot parking sensors for the BSM ones. The BSM sensors are inside/behind the plastic bumper corners and are a bit bigger than a deck of cards. The dot sensors are only for parking.
    Koolbreeze7, AZ Pete, Barsoom and 2 others like this.
  7. Mar 17, 2023 at 2:43 PM
    DrBarGnarLovesTacos
    DrBarGnarLovesTacos To Each His Own
    Orange County, CA
    2020 Cement TRD OR DCSB 4X4/Snugtop Camper
  8. Mar 17, 2023 at 2:56 PM
    dewelrTX
    dewelrTX Well-Known Member
    Dewel
    SAN ANTONIO, TEXAS
    2019 Tacoma TRD Off-Road 4x4 DCLB
    Do you have to remove the caps to get to clean them? If so what is the best way to get the caps off?
  9. Mar 17, 2023 at 3:40 PM
    DrBarGnarLovesTacos
    Orange County, CA
    I would suggest having the dealership take care of it if it's under warranty so you don't have to deal with it. Something always seems to break when taking tabs out. At least for me. Found this thread. Hope it helps.
    https://www.tacomaworld.com/threads...nd-cap-cover-removal-and-installation.734288/
    dewelrTX[QUOTED] likes this.
  10. Mar 17, 2023 at 4:19 PM
    dewelrTX
    Dewel
    SAN ANTONIO, TEXAS
  11. Mar 17, 2023 at 4:29 PM
    na8rboy
    WI
    No, just flush with hose or power washer. Either reach under bumper or between bumper and bedside. Here in north, snow and road dirt get packed up in bumper. Blast is and they are working again.
  12. Mar 18, 2023 at 5:55 AM
    tpete
    tpete [OP] Member
    Tom
    2019 TRD Sport
    Thank you everyone for the suggestions! I am going to clean the "correct" sensors this time and hopefully that works.
    50Buck likes this.
  13. Mar 20, 2023 at 7:58 PM
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    What error message are you getting on the dash? Or what warning light ?
  14. Mar 21, 2023 at 10:50 AM
    tpete
    tpete [OP] Member
    Tom
    2019 TRD Sport
    It shows the yellow triangle with a message on the dash saying the BSM is being shut off due to an error or something along those lines. Tomorrow I'll be able to spray the sensors off and see if that solves the problem. If not, then I'll have to take off the bumper caps and check everything out.
  15. Mar 21, 2023 at 11:02 AM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    If there's an error being reported, it will probably require Techstream to clear, assuming whatever caused the issue to begin with is resolved. Mine had the same issue after the sensors became packed with snow driving across I-80 in Wyoming during a blizzard. A few weeks later, after running the truck thru the car wash, I pulled the caps and cleaned the sensors, unplugged, replugged everything and the issue was still present. A regular code scanner didn't find any codes, but once I connected Techstream to it, I found some codes and cleared them. Took about 10 miles of driving afterward for the system to go back to normal.
    My guess is there was no need to clean anything and all that needed to be done once the snow melted was clear out the errors using Techstream.
  16. Mar 21, 2023 at 1:35 PM
    brian.gonz
    Brian
    Manor, Texas
    You may need to check that the connector is fully seated. I've ran into a couple toyotas where the rubber grommet inside the connector hardened a bit and caused intermittent connection throwing a code/ error light. I would start there. If you've been hit and had the car in a bodyshop the bsm could be out of alignment. Calibration can be performed and even pass within spec but throw a code later for misalignment on the vertical axis.
    Definitely start by checking the plug is fully seated then clean the sensor but be gentle. The brackets aren't super strong and you don't want to disturb the angle. If that doesn't resolve your issue then you may need to have someone with techstream or aftermarket jbox diag tool hookup and find out what fault codes are present to farther diagnose the issue
    AZ Pete likes this.
  17. Mar 21, 2023 at 1:38 PM
    brian.gonz
    Brian
    Manor, Texas
    You have to remove the bumper covers to access the sensors. The visible sensors are your parking sonars that won't have any affect on the bsm
  18. Mar 21, 2023 at 5:13 PM
    tpete
    tpete [OP] Member
    Tom
    2019 TRD Sport
    Thanks for the advice! I'll provide an update once I figure it out.
  19. Mar 21, 2023 at 5:23 PM
    Shades_Of_Red
    Shades_Of_Red Well-Known Member
    Lou
    Pittsburgh, PA
    2019 Tacoma TRD Off Road Premium Cavalry Blue
    A few.
    Were u driving on snow covered roads and/or heavy snow when this happened?
  20. Mar 21, 2023 at 8:33 PM
    riggityj
    riggityj Well-Known Member
    James
    Tejas
    2020 TDROR DCLB VDB
    Stock AF
    Who knew they could get so dirty. I just changed by bumper out and during disassembly of the oem I discovered the bsm sensor was caked in west Texas dirt. White dust was from a trip to big bend and must have been stuck up there for 3-4 months and multiple car washes. Wild stuff, surprised I didn’t get an error.
