Blind spot mirror add-ons?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Foozer, Jan 17, 2016.
  1. Jan 17, 2016 at 5:10 PM
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Looking for some blind spot stick on mirrors, but most of the ones that I have seen are super cheap and look bulky.
    Has anyone found some high quality, more discreet mirrors? Or does anyone have any suggestions on one's that have worked for them?
    Pics are appreciated :)
    Thanks in advance everyone and enjoy the 3 day weekend!
  2. Jan 17, 2016 at 5:23 PM
    G.T.
    G.T.
    CONUS
    Matt, I played with the stick ons in the past and they always frustrated me. Now I use the mirrors I bought from @SMKYTXN. I intend to never go back. Check out his thread here.
    SMKYTXN likes this.
  3. Jan 17, 2016 at 6:05 PM
    Pigpen
    Dan
    Northwest Montana
    I use the $2 stick on ones from any auto parts store. I put them in the upper outside of my mirrors. Been doing it that way for over 20 years and works great.
    seedy_tea likes this.
  4. Jan 17, 2016 at 6:50 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Or just properly adjust the mirrors. Vehicles should enter the side view mirror as they leave the rear view mirror. As they leave the side view they should enter your peripheral vision. If you can see any part of the side of your own truck without leaning quite a bit either left or right you are doing it wrong.
  5. Jan 17, 2016 at 7:27 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Uh Huh.....
  6. Jan 17, 2016 at 7:42 PM
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    Check out the EZView mirrors if you want to actually eliminate your blindspots and not sacrifice your field of view with a stick on convex mirror.
    Videos are better than pics. :D
    https://www.youtube.com/watch?v=fGyIWTCUtMg
    Or, you can use a mirror that doesn't sacrifice the view of the side of your vehicle.
    6xchamps likes this.
  7. Jan 17, 2016 at 7:45 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    I hate the distortion of aspherical mirrors.
  8. Jan 18, 2016 at 12:18 AM
    Boilerman
    Boilerman Well-Known Member
    Brian
    Texas, northwest of the Big Pond
    2010 Prerunner SR5 Magnetic Gray 2.7L
    Side-view mirrors. To adjust the driver's side-view mirror, place your head against the left side window and set the mirror so you can just barely see the side of the car in the mirror's right side. To adjust the passenger's side-view mirror, position your head so that it is just above the center console.
  9. Jan 18, 2016 at 11:11 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Thanks everyone!
  10. Jan 18, 2016 at 3:28 PM
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
  11. Jan 18, 2016 at 4:49 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Yep, same here. Works just fine.
    DustStorm4x4 likes this.
  12. Jan 18, 2016 at 4:53 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    I'll probably try those out for now, thanks for all the input!
  13. Jan 18, 2016 at 6:02 PM
    08TacoTrD
    08 TRD Offroad
    Why not, they are cheap and if you don't like them it's just a little elbow grease to remove them so something else can take their place.
  14. Jan 18, 2016 at 6:05 PM
    TexTac1
    TexTac1 New Member
    Tx
    15 taco
    ^^^^this^^^^
  15. Jan 18, 2016 at 6:32 PM
    omega supreme
    omega supreme Well-Known Member
    2011 TRD sport,lb
    None
    This. Most people don't know how to adjust mirrors correctly. Sad.
    DJE likes this.
  16. Jan 18, 2016 at 6:41 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    True. I estimate that when I pay attention well over half of the people I am behind in traffic can see me (and I can see them) out of the rear view and both side mirrors. That's young and old alike so the ignorance didn't start with the current crop of drivers. Its surprising when I come across someone that knows what they are doing.
  17. May 23, 2019 at 9:44 AM
    Benny123
    Benny123 Kid from the late 70s
    Ben
    South Charlotte, NC
    2005 Speedway Blue Tacoma AC V6 TRD Off Road 4x4
    Replacing everything worn, broken, and rusted.
    Good suggestions above. Had two scenarios that got me thinking about this today. Had a 1990s Toyota truck on my left, and I saw him clearly, but didnt see the Mazda behind it that was tailgating him at 80mph. Later, had a guy in an Accord pass me on the right after sitting in my blind spot a few minutes. Wasnt expecting him to merge back over off of the highway exit lane. Both tricky scenarios, but some mirror adjustments should help.
  18. May 23, 2019 at 9:48 AM
    El Taco Sucio
    El Taco Sucio Well-Known Member
    SoCal (805)
    Silver TRD Sport 4x4
    Mod list... Well, my paint is factory.
    Not to derail the thread but @Foozer, what's your name? Just curious, my normal nickname is n2fooz. Chris McSweyn out of CA.
  19. May 23, 2019 at 10:03 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    My real name is Matt. But the first concert I ever went to as a kid was a Weezer / Foo Fighters concert in Oakland (the "Foozer" tour) and I loved both bands so much after that I started using Foozer for my online handles
  20. May 23, 2019 at 10:10 AM
    El Taco Sucio
    SoCal (805)
    Haha cool. I thought it may be for foosball like mine.
    I saw the Foos in January at a private event. It was a great show. I was about 5ft away from Dave when he fell off the stage. My buddy's video was used in this story:
    https://youtu.be/E2Ma-0XMqy0
    KTM753 likes this.
