Blind spot add-on mirrors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Spacecoast, Apr 7, 2022.
  1. Apr 7, 2022 at 11:05 AM
    Spacecoast
    Spacecoast [OP] Well-Known Member
    2022 White SR5 2.7L
    Trailer wiring kit, hitch, seat risers
  2. Apr 7, 2022 at 11:13 AM
    Millhouse516
    Millhouse516 Traveling by Tacoma
    San Diego
    Silver 2019 DCSB SR5
    5100's - Icon AAL - RTT - DIY Awning - DIY Mods
    Scotty61, gators22 and HisDad like this.
  3. Apr 7, 2022 at 11:13 AM
    howtowakeakar
    howtowakeakar Well-Known Member
    2022 White TRD OR DCSB 6MT
    I haven't used these exact ones, but the round blind-spot mirrors work great. They're one of the first things I'll put on my OR when it comes in.
    monoman likes this.
  4. Apr 7, 2022 at 11:32 AM
    E.J.
    E.J. International Overlander
    Josh
    NWA
    2017 White Tacoma TRD Off Road
    mtip, BRFab, VaToy and 3 others like this.
  5. Apr 7, 2022 at 1:30 PM
    Spacecoast
    2022 White SR5 2.7L
    Could you give me the dimensions of the Rav4 blind spot mirror section?
  6. Apr 7, 2022 at 2:05 PM
    Spacecoast
    2022 White SR5 2.7L
    Looking in my miscellaneous auto parts bin I found one of those cheap blind spot mirrors. Probably back when I our son got his new car a few years ago. This will work for now but I'm not a fan of the poor non-glass mirror properties. What is nice is that it rotates, but with force and nice position clicks so its not loose. Package says its for RV's. I'm sure I picked it up at Walmart years ago.
  7. Apr 7, 2022 at 2:12 PM
    Spacecoast
    2022 White SR5 2.7L
    Actually for me it was more of a "turn off" than anything else. And some of the product reviews were not very positive.
  8. Apr 7, 2022 at 5:51 PM
    E.J.
    Josh
    NWA
    AM-JKLV76s4T0SE8KQThrTIgMqzd6ycErdlU4Gon_8a05399de2f43942b1b9e5afb7ab2007cb22bcbe.jpg
    AM-JKLUfyPtNSh2A68bqzMyVsJ_n4Uvithi0FtOx_f6b440b2d49805f2977e96f794a2cb522e0b9eb4.jpg
    Hope that helps. Sorry about the dirt.
    Malvolio and tuna like this.
  9. Apr 7, 2022 at 7:16 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Yeah I have the Rav mirrors as well. Work well enough for blindspot usage.
  10. Apr 7, 2022 at 8:12 PM
    Spacecoast
    2022 White SR5 2.7L
    Thank you E.J.
  11. Apr 8, 2022 at 5:07 AM
    kasberry
    kasberry Well-Known Member
    Kyle
    Kentucky
    2019 Cement TRD Off-Road
    I went with the Rav4 mirrors. They work great for what they are intended.
    They are really good blind spot mirrors, but that portion is fixed in place so you can't angle it to see your tires or trailer without moving the entire mirror.
    I feel huge in the Tacoma and literally couldn't see to change lanes with sort of bending down in my seat before. Now I can confidently switch lanes, so overall I'm happy, just wish they were a little cheaper.
    I found these after I had already installed my Rav4 mirrors, but looks like a great option as well. They have them with and without BSM from the Tech Package.
    https://spottermirror.com/p/toyota/2016-2022-tacoma-with-bsm/
  12. Apr 8, 2022 at 6:39 AM
    Spacecoast
    2022 White SR5 2.7L
  13. Apr 8, 2022 at 7:26 AM
    carlk
    carlk Well-Known Member
    Virginia
    2022 MGM SR 2.7 Access Cab Utility Pkg
    I found this on you tube on adjusting your side view mirrors to maximize you view of the road. The video also shows a convex mirror to replace your existing side view mirrors on the Tacoma to further reduce blind spots.
    https://www.youtube.com/watch?v=OtmXEkO6Q84
    Rock Lobster likes this.
  14. Apr 8, 2022 at 8:35 AM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
  15. Apr 8, 2022 at 8:44 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  16. Apr 8, 2022 at 8:46 AM
    Spacecoast
    2022 White SR5 2.7L
    AZPhys13....Did you use the "adjustable base" or fixed mount?
  17. Apr 8, 2022 at 9:07 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    :notsure:
    I've never had a blind spot in any vehicle I've owned, and only a very few number of large trailers I have driven. I angle mine down and away so that I'm staring between the other cars' door handle to rocker panel. Don't need to look them in the eye, nor do I need to overlap what the rear view sees (or what it would see on the days it's obscured.)
    The default is to be able to see the entire width of the lanes directly perpendicular of your rear wheel at a glance. Then you move your head and look out the rear-view and windows to check if anyone is approaching that zone.
    When I'm towing or hauling and I want to use the sides to look rearward, that's when I duck down/use body positioning to shift my viewing angle in the mirror. But the default mirror setting at my normal driving position is always pointed down and to the side.
  18. Apr 8, 2022 at 9:10 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I hear you there. I broke a couple on my OE ones in the cold, installing them the evening before a trip. I should have listened to the instructions and heated them up. That said, I could toss the stock ones in the trash at this point. There's no going back.
    You can hit them with a hair dryer for a minute or a heat gun on a low setting.
    DLyman[QUOTED] likes this.
  19. Apr 8, 2022 at 9:13 AM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    When I built my camper I replaced my stock mirror with something like the mirror below.
    One benefit I didn't expect is the field of view is so wide there are no blind spots. My view from the camera is far better than the view I had with my stock mirror and nothing in the bed of my truck (this is for a 1st gen, 3rd gens are probably differant)
    Replacing your rear view camera is probably more complex than a 1st gen too. It has no electronics. Not sure if a 3rd gen does.
    https://www.amazon.com/WOLFBOX-Mirr...s=dash+cam+mirror&qid=1649434195&sr=8-1-spons
  20. Apr 8, 2022 at 9:16 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    We all have wide angle back up cameras that are easily modded to anytime. They do give a lot of coverage.
    That said, I installed one of those on our daughter's Mazda that didn't have a back up camera. It is one of those gizmos that are kinda necessary these days with crazy drivers and too tight of parking spots. It has worked very well.
    otis24[QUOTED] likes this.
