Blackvue GoPro Mount for DR900S 900X Dashcam - Gen3 2016/2017/2018
Discussion in 'Audio & Video' started by cameleon50, Dec 27, 2018.
  1. Dec 27, 2018 at 5:01 PM
    cameleon50
    cameleon50 [OP] Well-Known Member
    Weatherford, Tejas!
    YotaWerx'd 2017 TRD PRO CEMENT
    Hammer Hanger, Kings 2.5, ICON Leaf + UCA, Marlin, OEM Audio Plus, OVTune, Nitro 5.29, MESO, Victory 4x4
    I edited an existing BlackVue mount sleeve for a GoPro adapter. I just got it printed via shapeways and it fit like a glove. I made it to fit the DR900S 36MM diameter and is perfectly. Not to tight and slides on with just enough resistance to have a good hold. (+NSFW) I tested this build at a local 3D print shop but found www.ShapeWays.com to be the best. The local print shop was off on their printing as it was too small. Shapeways print quality was much better so I recommend them.
    I posted this to Thingverse so download and enjoy. I posted a slotted and a solid STEP version. The slotted version did cause some heart burn with shapeways but they printed it anyways. In the end, it worked great. Either should be perfect for you.
    If you want the STEP & STL files they are posted here - (Updated New Link - July 15th, 2019) - https://web.tresorit.com/l#50Mmq7o2U89vszftCS0o8A
    https://www.thingiverse.com/thing:3317491
    Credits: I got a few people to help me in doing this. I am novice but figured most of it out with Fusion360 and FreeCAD. TacomaWorld @RushT gets a lot of the credit along with many others that have posted on this forum and Thingverse. I simply made the adjustments for the newer Blackvue dashcam.
    NOTE: This is for a Blackvue DR900S Front Dashcam. If you have the 2-Channel, just use this for the front GoPro Mount. Update: Jan 1st, 2021 - I see the 900X is out and should be the same dimensions.
  2. Dec 27, 2018 at 6:12 PM
    RushT
    RushT Amateur Everythingist
    North Texas
    '18 DCSB TRDOR Inferno
    Thanks @cameleon50,
    You may have accidentally returned the favor since I now can use this if I upgrade to the 900 series. Thinking about it for my cayman. Would just need a window sticky. But hmmmm, if I’m going to stick to the window I might as well use the blackvue sticky mount. Well, if I upgrade the taco I’ll use it. :)
  3. Feb 19, 2019 at 5:42 PM
    porterx
    porterx Well-Known Member
    I am liking this but not crazy about the color matching. I have a ton of Gopro mounting accessories. Maybe I have one that's flat. I could mount the Blackvue to that. If I can't figure it out, do you have a link to this on Shapeways.com? The Thingverse is if I wanted to print it myself right? I've used Shapeways before to get an on/off switch made for my LG HBS730 Bluetooth Wireless Headset. They were so small, you get 4 of them.
  4. Mar 8, 2019 at 8:34 AM
    cameleon50
    Weatherford, Tejas!
    Just use Shapeways and upload my new files. If you choose the 'Versatile Plastic' material, it has many colors to choose from. Here is the link to what I did - https://www.shapeways.com/model/upload-and-buy/8483548. I selected Fine Detail Plastic. The old version with the cut out gives Shapeways people a head ache because the printers have trouble with these.
    porterx[QUOTED] likes this.
  5. Mar 8, 2019 at 8:43 AM
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    Could you post a picture of how this looks from the drivers seat (like full windshield) thinking about getting a dashcam but dont love having a huge camera up there and trying to understand how big it is when up there. Would really prefer something that integrates around/behind the rearview mirror.
  6. Jul 10, 2019 at 10:35 AM
    Ruminator
    Ruminator Chairman of the Bored
    Mark
    Northern Illinois, USA
    2017 Red TRD-Sport, ACLB, MT!!!
    Alright doll-face, c'mon and bore me!
    Resurrecting old thread here...
    @cameleon50 , your Shapeways link gives a 404. This isn't yours, is it? https://www.shapeways.com/product/CJPHXUJNY/blackvue-dr590-2ch-gopro-v1-3
    It says it's for a DR590, not a 900, and I don't know if they're the same diameter.
    There's a bazillion GoPro adapters on the site, but I could only find that one with "BlackVue" in the title.
    I need to finally get my camera mounted (I've only had it a year), and using the GoPro mount seems to make the most sense.
  7. Jul 10, 2019 at 12:42 PM
    RushT
    North Texas
    That’s my link, something I put up over a year ago. Is it not opening for you? It opened for me.
  8. Jul 10, 2019 at 1:04 PM
    Ruminator
    Mark
    Well, I'm a bit confused. I tried the link that @cameleon50 posted a few posts back and got the "page not found" message. I then searched for "GoPro BlackVue Adapter" and found what is apparently your part. What confuses me is this from the first post of this thread:
    "Credits: I got a few people to help me in doing this. I am novice but figured most of it out with Fusion360 and FreeCAD. TacomaWorld @RushT gets a lot of the credit along with many others that have posted on this forum and Thingverse. I simply made the adjustments for the newer Blackvue dashcam."
    So it sounds to me like my search should have turned up at least 2 of these parts, yours and @cameleon50 's modified version. The one that I found and linked to (if that's yours) says it's for the DR590. @cameleon50 says he created a part for the DR900 (which happens to be the same 36mm diameter as my DR750).
    So, and please correct me if I'm wrong, but I think I need to find the part that @cameleon50 created, or upload the file if the part isn't offered by Shapeways ( :notsure: I'm not sure how this works).
    <edit> Looks like the file(s) are still available on Thingiverse https://www.thingiverse.com/thing:3317491
    <edit again> ...and... I downloaded the files from Thingiverse and the only .step file has "-SLOT" in the name, while the 3D drawing of the part shows no slots, and the OP did say that the slots were difficult for Shapeways to do.
  9. Jul 10, 2019 at 5:09 PM
    RushT
    North Texas
    I haven’t looked at cameleon’s design. For mine, yes it’s the lower model Blackvue. The ‘slot’ was there for O-rings in case the sleeve was a little loose. Turns out the fit was really good and I didn’t need them.
  10. Jul 11, 2019 at 6:27 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Slight off-topic question:
    I see that you're running the BlackVue upside down; which means that you're also able to change the orientation in the software (yes?) Does the software allow for 90 degree increments (or more) or is it only 180 degrees?
    I'm going to order the mount; thanks for posting the new link.
  11. Jul 12, 2019 at 6:15 AM
    Ruminator
    Mark
    Contacted Shapeways... Looks like I need to convert .step file (downloaded from thingiverse.com) to .stl. Working on it.
    <edit> Never mind. The .stl file was sitting there staring at me. Uploaded and placed order with Shapeways. Around $22 total.
    Rob Daman likes this.
  12. Jul 15, 2019 at 1:57 PM
    cameleon50
    Weatherford, Tejas!
    Yes, you have the option to flip the image and it works just fine.
  13. Jul 15, 2019 at 1:57 PM
    cameleon50
    Weatherford, Tejas!
    Awesome! They had the best quality and tightest measurements.
  14. Jul 15, 2019 at 7:20 PM
    cameleon50
    Weatherford, Tejas!
    I put up a NEW link to all the files. The original post at the top and here has the new link to all the files you need.
    New Link - https://web.tresorit.com/l#50Mmq7o2U89vszftCS0o8A
    I will leave this up for the next year or longer.
    Enjoy -
  15. Jul 16, 2019 at 6:48 AM
    Ruminator
    Mark
    Thank you for creating the part and making the files available. I'll post a pic in a week or so when I receive my copy and get it installed.
    <edit> Just got an email from Shapeways saying the part has shipped. Their customer service has been super.
    Bunk Moreland likes this.
  16. Jul 16, 2019 at 8:06 AM
    Ruminator
    Mark
    BTW, if anyone reading this thread needs the part that slips into the windshield mount, PM me and I'll send you one for the cost of postage. I picked up a pack from Amazon and have 4 left over that I'm never going to use.
    I don't have the thumb screws, though (see the photo in the OP). I'll just be using an M5 x 20mm socket head screw from the hardware store, since I'm not going to be mucking with the camera once it's mounted.
    porterx likes this.
  17. Jul 16, 2019 at 2:09 PM
    LegendaryAcura88
    LegendaryAcura88 Well-Known Member
    2017 Tacoma SR5 V6 DCSB
    Do you know if the dr900s is the same size as the dr750s?
  18. Jul 16, 2019 at 2:10 PM
    Ruminator
    Mark
    Yep, they're both 36mm outside diameter.
  19. Jul 16, 2019 at 2:11 PM
    LegendaryAcura88
    Perfect. Thank you!
  20. Jul 22, 2019 at 7:11 AM
    Ruminator
    Mark
    Got my part from Shapeways last Friday, looks pretty good:
    The part in the OP shows some pattern in the printing, this part is the same texture all around (no additional finishing options were chosen). The cylinder is a bit on the thin side, but it's probably pretty tough material, so I'm not expecting any problems. The fit on my DR750 camera is really snug, to the point that I was *tempted* to open up the ID a few ten-thousandths with some fine sandpaper, but I'm resisting that temptation. A snug fit is good. You set the camera position once and want it to stay there over time while being bounced around inside the cab.
    I wasn't running a lot of errands during the recent heat wave, so I still need to get to the hardware store for the screw to attach this to the "shoe".
