Black Rhino Wheel Issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by lukeroe, Jul 15, 2024.
  1. Jul 15, 2024 at 8:59 AM
    lukeroe
    lukeroe [OP] Member
    2021 SR5 Trail Edition
    Mechanic told me I need spacers in order to install my new black rhino 16x8’s. Anyone else have this problem?
  2. Jul 15, 2024 at 9:22 AM
    Unit59
    Unit59 Keystone State
    Craig
    East Central PA
    2023 Tacoma TRD OR
    I'm no expert but I don't think that's correct, what backspacing and offset is on the black rhino's?
  3. Jul 15, 2024 at 9:22 AM
    guaco.supreme
    guaco.supreme Fk around and find out
    MN
    What offset? Its entirely possible if you bought some with too high of an offset.
  4. Jul 15, 2024 at 9:29 AM
    lukeroe
    lukeroe [OP] Member
    -10 offset
  5. Jul 15, 2024 at 9:30 AM
    lukeroe
    lukeroe [OP] Member
    The wheels are 16x8 -10 offset and 4.1 backspacing
  6. Jul 15, 2024 at 9:32 AM
    guaco.supreme
    MN
    -10 should have zero issues clearing.
    Next question, whats the center bore size?
    Or better yet, link to the exact model wheels
  7. Jul 15, 2024 at 9:38 AM
    lukeroe
    lukeroe [OP] Member
    Perhaps it’s as simple as needing longer lug nuts? I’m bringing them into a shop that does custom work soon.
  8. Jul 15, 2024 at 9:47 AM
    guaco.supreme
    MN
    Only thing I can think is center bore. The taco has a 106.1mm center bore, these wheels are 112.10mm. While these wheels will fit they are not correct for the vehicle, so some shops may refuse to install them for safety reasons. My guess is he meant hubcentric rings to fill that space with the mismatched bore, not actual wheel spacers.
    EDIT: These "should" do it
    https://www.amazon.com/WHEEL-CONNECT-Centric-Aluminium-Hubrings/dp/B09SYV3ZGL?th=1
    JustinFro, lukeroe[OP] and msgs350 like this.
  9. Jul 15, 2024 at 9:49 AM
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    Couple things you can do, hub rings and and extended studs. Can you carry them out and install on the truck yourself?
  10. Jul 15, 2024 at 10:02 AM
    lukeroe
    lukeroe [OP] Member
    thank you! I’m a newbie and I really appreciate your help.
  11. Jul 15, 2024 at 11:27 AM
    lukeroe
    lukeroe [OP] Member
    Would I need extended studs on top of the hub rings?
  12. Jul 15, 2024 at 11:39 AM
    guaco.supreme
    MN
    with hub rings you shouldnt need extended studs. If you ran spacers then you would need extended studs.
  13. Jul 15, 2024 at 11:50 AM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I did need different lug nuts, but that was the only thing.
