Black Rhino Armory wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by demogorgon217, Mar 27, 2021.
  1. Mar 27, 2021 at 10:15 PM
    demogorgon217
    demogorgon217 [OP] Well-Known Member
    gordon
    Louisiana
    Gloria
    auto zone valve stem covers
    can anyone tell me if this will fit a 2015 with no lift?
  2. Mar 27, 2021 at 10:30 PM
    demogorgon217
    gordon
    Louisiana
    Gloria
    actually will be going for the 17s hopefully those will fit without a problem
  3. Mar 27, 2021 at 10:57 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I assume you have 6 lugs so no...
    The lug pattern on these trucks is 6x5.5/ 6x139.7.
  4. Mar 27, 2021 at 11:44 PM
    demogorgon217
    gordon
    Louisiana
    Gloria
  5. Mar 28, 2021 at 5:32 AM
    demogorgon217
    gordon
    Louisiana
    Gloria
    in case anyone is coming from a google search, they do make these with a 6 5.5 bolt pattern that will fit a 2015.
  6. Mar 28, 2021 at 6:24 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You will need hub bore adapter rings as the Tacoma is 106 and those wheels say they are 122.1.
  7. Mar 28, 2021 at 6:48 AM
    demogorgon217
    gordon
    Louisiana
    Gloria
    this has me so confused. i get places that say it’s a guaranteed fit and then information that contradicts it
    how do people even buy wheels :annoyed:
  8. Mar 28, 2021 at 6:58 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    That is why I just use OEM Wheels. I know they will fit properly and have been vetted for the Tacoma. They make wheels to fit a large variety of vehicles to keep production cost down. They will fit a large population of vehicles somewhat. Tacoma wheels are made specifically for Tacomas and vehicles with the same specifications.
    The Tacoma Hub is 106 mm what you have on this post says 112.1 mm. If you don't use hub adapter rings you will most likely have vibrations due to the wheel not sitting correctly on the hub.
  9. Mar 28, 2021 at 7:11 AM
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Don't tapered lug nuts serve the same function? When I changed my wheels, I went back and forth, but after looking at how much surface rust and stuff is on the hub ring, I'm sure the tapered nuts must be doing just as well for centering it.
  10. Mar 28, 2021 at 7:17 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    It depends on how well they wheels are made. If you want to take a chance, that is up to you.
  11. Mar 28, 2021 at 7:20 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    I guess so. Mines been centered with conical lugnuts for a year, and 20,000+ miles.
  12. Mar 28, 2021 at 7:21 AM
    Jimmyh
    SC
    2012 Prerunner SR5
  13. Mar 28, 2021 at 7:23 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    What is the bore size of your aftermarket wheels?
    If it is 106 then it is aligned with the hub centric.
    If it is larger than 106. Then good you got lucky.
  14. Mar 28, 2021 at 7:26 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    I know how hub centric wheels work. I know that if the bore was 106, they would be located on the hub. I didn't get lucky. I knew that the wheels had an oversized bore, so I used conical lugnuts. Which is what OEMs all over the world do. I'm pretty sure the majority are actually lug-centric. There's more than one way to skin a cat.
    Edit - looks like I was wrong by saying the majority. But many still are, and I'm good with that.
    My issue with the hub centric rings, is the ones that came with my wheels were a janky piece of stamped out brittle plastic. I, personally trust 6 tapers more than that piece of plastic. I'm a machinist, and after working with different styles of tapers for years, I can say that a taper is a hell of a system. I'm sure the ring can't hurt though.
  15. Mar 28, 2021 at 7:32 AM
    demogorgon217
    gordon
    Louisiana
    Gloria
    so can i have these wheels or no ._.
  16. Mar 28, 2021 at 7:38 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    As long as you order the right bolt pattern, sure. Just make sure you check what type of lug seat they have, probably conical. So replace your lugnuts, and get a hub-ring, because it can't hurt. As far as offset and rubbing goes, I dunno. Depends on tire size, suspension setup, etc.
  17. Mar 28, 2021 at 7:46 AM
    demogorgon217
    gordon
    Louisiana
    Gloria
    well after getting tired of so much conflicting info i just figured out black rhino has a dealer 2 minutes up the road from me so ima be talkin to them and i’ll figure it out. hopefully i’ll be able to get what i want, if not that’s ok too. thanks for the help guys
  18. Mar 28, 2021 at 7:50 AM
    JeffBoyardee
    Jeff
    Seminole, FL
    Probably your best bet
  19. Mar 28, 2021 at 10:33 AM
    badger
    badger Well-Known Member
    07 SR5
    Just be aware that just because something bolts on doesn't mean it will perform properly. The aftermarket is buyer beware. I bought a suspension kit for another vehicle and I'm having to custom build all kinds of parts to actually make it work, and this is typical. The shocks they provided have only 1" of rebound travel!, but yep, they fit right on. I'm another fan of Toyota factory wheels.
  20. Mar 28, 2021 at 10:36 AM
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
    Not picking on anyone, but I have never understood the reluctance to use hub rings. They are cheap as hell and easy insurance to avoid vibrations.
