Black Acorn Lug Nut Kit; 12mm x 1.5 doesn't fit with SR5 wheels?
Discussion in 'Wheels & Tires' started by PolakTaco, Aug 30, 2022.
  1. Aug 30, 2022 at 6:47 AM
    PolakTaco
    PolakTaco [OP] Well-Known Member
    FL
    2022 Tacoma SR5 4x4 V6
    Just purchased Black Acorn Lug Nut Kit; 12mm x 1.5 from Extreme Terrain. Their website says it will fit my 22 SR5.
    I was planning to install it today and noticed the stock lug nuts have some sort of a gasket/ring. I don't think Acorn lug nut kit I purchased is intended for SR5 wheels.
    What exact lug nuts should I purchase that will be direct OEM replacement but in black?
    Thanks.
    Pictures attached.
  2. Aug 30, 2022 at 6:53 AM
    Rockbaron1
    Rockbaron1 Well-Known Member
    Pat
    03 Tacoma
    everything
    You bought lug centric nuts and you need hub centric nuts. I don’t know why that website told you they’d fit because pretty much all new cars and trucks are hub centric from the factory. Also your not going to find an acorn nut that’s hub centric so if you really want to run them your gonna need different wheels.
    PolakTaco[OP] likes this.
  3. Aug 30, 2022 at 6:58 AM
    PolakTaco
    FL
    Thanks.
    I'm still a noob. Just picked up this truck last week.
    All I want is black lug nuts to match with my wheels.
    I happened to order acorn lug nuts because I saw it came in black and it supposedly fits according to their website.
    I'm going to return what I ordered.
    What exactly do you recommend to get for black lug nuts that will work with my stock wheels? Anything specific?
    Just concerned I'm going to order wrong lug nuts again :anonymous:.
  4. Aug 30, 2022 at 7:01 AM
    AugustaTaco
    AugustaTaco Well-Known Member
    Josh
    Augusta, GA
    2015 DCSBXSPX4X4 2017 GX460
    "Getting out of hand" - Wife
    Quick google of “oem Toyota black lugs” turned this up on eBay. That style is what you need
  5. Aug 30, 2022 at 7:02 AM
    AugustaTaco
    Josh
    Augusta, GA
    There’s also some below in the products discussed section :thumbsup:
  6. Aug 30, 2022 at 7:04 AM
    Siblue
    Siblue Well-Known Member
    So Cal
    25 Tundra TRD pro
    The lug they sold fits the SR5 fine but flat seat is need to fit the wheel.
    OEM is PN-PT076-60200-02 and need 4 packs of 6.
    I just sold a set.
  7. Aug 30, 2022 at 7:12 AM
    PolakTaco
    FL
    Awesome, thanks for your help :cheers:.
