Bison Off-road Cam Tabs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JeffBoyardee, Nov 22, 2020.
  1. Nov 22, 2020 at 1:20 PM
    JeffBoyardee
    JeffBoyardee [OP] Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    I'm replacing LCA bushings, so while they're out, I'm installing bison cam Tabs. If I understand correctly, the bison tabs limit you to 8 levels of adjustment for caster/camber, rather than the infinite, or gradual adjustment of the round tabs, is that correct? So according to the video, I should install them in the position closest to where they are now?
    What threw me off is in the video he said he marks them to readjust if something moves. Is there more adjustment beyond the 8 flats?
    Video: https://youtu.be/OCtB_IbvVb8
    Product: http://www.bisonoffroad.com/toyota-tacoma-05-15-4runner-2003-2009-stop-cam-kit/
  2. Nov 22, 2020 at 1:25 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Kolter45 likes this.
  3. Apr 16, 2021 at 11:34 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    Crickets........
  4. Apr 17, 2021 at 3:17 AM
    JeffBoyardee
    Jeff
    Seminole, FL
  5. Apr 17, 2021 at 4:54 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Correct, it's not longer "infinite" adjustability. Place them in position that most closely aligns w/ the current position of the cam tab bolts so you're not way off when you go to the alignment shop. It should be pretty close. I don't have bison, but another brand and I had to make one adjustment after installation and alignment. Mark them after final alignment if you want to ensure they don't move or the bolt isn't backing out. I guess that's the only reason. Otherwise no reason.
  6. Apr 17, 2021 at 6:35 AM
    Beer-toe
    Beer-toe Well-Known Member
    Berto
    Menifee
    Dad Mobile
    Stickers
    They are not so active on here but they answer phones and customer service is great
    Kolter45 and blu92in99 like this.
  7. Apr 17, 2021 at 7:47 AM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    Look at the way the hex cam is contacting the cam tab on the frame, one tiny point of contact. I wouldn't use these things personally. It's not the alignment cams that move during hard off-road use, it's the beer can thin flimsily metal Toyota used for the cam tabs that get bent.
    Kolter45 and 6 gearT444E like this.
  8. Apr 17, 2021 at 5:59 PM
    TacoTuesday1
    FL
    the stock bolts are expensive and allow for losing alignment during an off road trip or knock flipping them.
    bison off road is meant to *try* and prevent that by not being circular.
    The tabs can also bend and products exist for that such as
    -Marlin crawler LCA gussets
    -total chaos cam tabs
    and who knows what else
    JD Fab lower pivot arms replaces the whole thing and claims to hold it in position stronger
    all of these products vary in price point
    what you choose is up to you
    Heavily Meditated and Kolter45 like this.
  9. Apr 17, 2021 at 6:08 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    I wouldn’t use those things. If I was worried about losing my alignment I’d throw on some tack welds or drill I small hole through the lobe and tab for a pin to hold it in place
  10. Apr 17, 2021 at 7:44 PM
    6 gearT444E
    Deep South
    Herculiner Hootus
    Just mark the tabs on the frame. If it gets knocked out loosen and put back where they were.
    TacoPandaTRD and blu92in99 like this.
  11. Apr 18, 2021 at 7:12 AM
    Taylorbarton1
    Taylorbarton1 Well-Known Member
    Taylor
    Hotlanta
    2011 TRD off-road
    6 inch lift. 35's.
    yup.....its that easy :amen:
