Bilstein vs Fox!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MGMyota93, Feb 4, 2018.
  1. Feb 4, 2018 at 2:49 PM
    MGMyota93
    MGMyota93 [OP] Member
  2. Feb 4, 2018 at 5:37 PM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Depends on what your plans for the truck. If plan to wheel a lot then Fox all the way. Occasionally wheeling then Bilstein are still a good choice.
    Too be honest King shocks is the way to go but that's me ;)
    tcjacado and BassAckwards like this.
  3. Feb 4, 2018 at 5:43 PM
    AlexOntTheFly27
    AlexOntTheFly27 Well-Known Member
    2013 dcsb Trd OR
    I’m in the same exact boat. What I don’t understand is it says the fox is preset for 2 inches. That can be adjusted right? If so can you get 3 inches out of them? Can’t find answers
  4. Feb 4, 2018 at 6:20 PM
    MGMyota93
    That's a sick setup man! But sadly King's cost more than I want to spend. I live in SC so there won't be any rock crawling or running through deserts at high speeds for me.
  5. Feb 4, 2018 at 6:21 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Yes and yes. 3" lift is not a comfortable ride. All King, Fox, Icon, etc... are tested and tuned at 2" lifted any higher is at your own risk.
    tcjacado likes this.
  6. Feb 4, 2018 at 6:22 PM
    MGMyota93
    From what I have read is that the fox can go higher. But man, I'm just surprised at the lack of info on both of these kits.
  7. Feb 4, 2018 at 6:23 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Thanks! Bilstein are still a good choice and also OME
  8. Feb 4, 2018 at 6:23 PM
    AlexOntTheFly27
    2013 dcsb Trd OR
    Exactly my problem! This is a lot of money. I want either of these kits leaning more towards fox but want to know if they can atleast go up to 2.5
  9. Feb 4, 2018 at 6:25 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Both Fox and King can go higher but it will compromise ride quality and wear out the CV joints due to the extreme angle of the 3" lift.
  10. Feb 4, 2018 at 6:26 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Yes
    My Fox at 2.5" lift
  11. Feb 4, 2018 at 6:27 PM
    AlexOntTheFly27
    2013 dcsb Trd OR
    Is the fox 2.0 kit?
  12. Feb 4, 2018 at 6:28 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    2.5 in the front, 2.0 in the rear
  13. Feb 4, 2018 at 6:31 PM
    AlexOntTheFly27
    2013 dcsb Trd OR
    Ok do you know if the level 1 and two are the same as 2.5? As far as adjustability?
    Lord Helmet[QUOTED] likes this.
  14. Feb 4, 2018 at 6:34 PM
    Lord Helmet
    Nick
    '24 X3 M40i
    Level one just doesn't have the remote reservoir and is 2.0" the level 2 is 2.5" and has the reservior :thumbsup: I recommend @HeadStrong Off-Road if you plan to buy the Foxes :thumbsup:
  15. Feb 4, 2018 at 6:35 PM
    AlexOntTheFly27
    2013 dcsb Trd OR
    I am more than likely going with head strong level 2 is what I will probably be going with and a 1/4 inch spacer to make it a full 3 inch of lift. How does the front ride maxed out?
  16. Feb 4, 2018 at 6:36 PM
    AlexOntTheFly27
    2013 dcsb Trd OR
    Also dumb question what is the difference between standard and extended?
  17. Feb 4, 2018 at 6:40 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Extended travel gives you another 1/2” or so of droop. You have to run aftermarket uniball ucas with ext travel
  18. Feb 4, 2018 at 6:40 PM
    AlexOntTheFly27
    2013 dcsb Trd OR
    Awesome. So only uniball? Light racing wouldn’t work?
    BassAckwards[QUOTED] likes this.
  19. Feb 4, 2018 at 6:42 PM
    BassAckwards
    As far as i know uniballs are required because the ball joint in light racing or oem ucas become the limiting factor on the downtravel and put them in a bind
    Edit: i know this is the case with Kings, this may be different with the foxes
  20. Feb 4, 2018 at 6:43 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Extended travel has more travel. You have to run aftermarket UCAs and remove the sway bar to take advantage of it.
    Im running the LR UCAs with my setup...no need to run uniballs
