Bilstein B 5160
Discussion in '2nd Gen. Tacomas (2005-2015)' started by REAL_OG, Jan 24, 2023.
  1. Jan 24, 2023 at 10:31 AM
    REAL_OG
    REAL_OG [OP] Well-Known Member
    I see these shocks don’t come with a dust cover or boot from the factory, how critical is it to have one?
    anyone have any negative experience due to not having one?
  2. Jan 24, 2023 at 10:55 AM
    Watermallon
    Watermallon ID Tacooo
    Zach
    Idaho
    2006 TRD Sport
    Not 100% necessary to have but could give you peace of mind having one and not hard to put on. There’s always potential for a rock/debris to make a chip in the shaft big enough to tear up the seals on the inside of the shock, but id say the likelihood of that happening is fairly slim. But like I said, they’re easy to put on and cheap so it’s up to you.
  3. Jan 26, 2023 at 9:09 AM
    Steadfast Rocky
    Steadfast Rocky Well-Known Member
    Rocky
    2012 DCSB TRD BAJA
    They are 20 bucks or so and worth their weight in gold. The main issue is the shaft taking gravel dings and then damaging the shock seals. And while the rears are not hard or expensive to replace why create an unneeded expense.
  4. Jan 26, 2023 at 9:34 AM
    jaymac10
    jaymac10 Well-Known Member
    Kelowna, BC
    2013 TRD Sport
    OEM Baja Kit
    One of my rear shock (boot) covers has ripped at the top and is now exposing the shaft. Is there a replacement product that allows it to be put back on without un-bolting the stock?
    Also, I'm pretty sure they all come with boot's, they just don't show it in the pictures?? I could be wrong though...
  5. Jan 26, 2023 at 9:38 AM
    Watermallon
    Zach
    Idaho
    2006 TRD Sport
    I don’t think so, but you don’t even need to jack up your truck to remove the shock. It’s just 2 bolts, takes maybe 5 min to get it off and slip on the new cover.
  6. Jan 26, 2023 at 10:10 AM
    Martian__
    Martian__ Well-Known Member
    Southern California
    They don’t come with covers but you honestly don’t need them. Even the serious off-road ultra 4 trucks don’t run them. Maybe in snow states where seals and suspensions components rust due to salt but not for anything else. D38C6DCE-76FE-433D-9C32-7F94BF402F28.jpg
  7. Jan 26, 2023 at 1:14 PM
    TacoTuesday1
    FL
  8. Jan 26, 2023 at 5:42 PM
    REAL_OG
    Yea after I pulled my 5100, they were full or dirt on the inside the boot. They might do more harm than good. Or just not significant enough protection and why Bilstein doesn’t include them out of the factory
    TXpro4X4 likes this.
  9. Jan 26, 2023 at 5:50 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    I had the same. The boot can trap dirt and make things worse
  10. Jan 26, 2023 at 6:28 PM
    TacoTuesday1
    FL
    I mean if they make Fox and 5160 without it
    then it’s probably for a reason
  11. Jan 30, 2023 at 1:51 PM
    REAL_OG
    All , they are designed to not have one per Bilstein
