Bilstein and lifting the rear on 2024 Sport
Discussion in '4th Gen. Tacomas (2024+)' started by njweekends, Apr 11, 2024.
  1. Apr 11, 2024 at 7:57 AM
    njweekends
    njweekends [OP] Member
    2024 Tacoma Sport MT
    Sorry if this has been asked, I did a search and didn't see it though. Also, please ignore my ignorance on the subject of lifting, I’ve never modified a truck before.
    I’ve done some research and on previous gens a recommended set up for a small lift was Bilstein 5100 in the front and a block or aal in the rear. The 4g Sport does not have leaf springs and the Bilstein site doesn’t list a height adjustment shock for the rear. So, I’m not sure if I should assume its not a product released yet or there is a mechanical reason why that wouldn’t work. I appreciate everyone’s patience with my lack of knowledge. I was thinking I’d like a slight lift to my MT Sport but keep the rake. I appreciate your input.
    BoBsworld21 likes this.
  2. Apr 13, 2024 at 7:10 AM
    BoBsworld21
    BoBsworld21 Well-Known Member
    BoB
    2024 Tacoma Sport 4x4
    My 4th gen is fully stock, there are few upgrades as of yet, give it a month or two I have contacted, N-Fab and Diamondback, and both are working on the redesign. Bilstein is surely having to redesign with the new rear suspension. I had 5100 on my Gen 3 and look forward to upgrading again as well.
  3. Apr 13, 2024 at 7:15 AM
    Bishop84
    Bishop84 Well-Known Member
    The solution for rear coil lift is usually a small spacer to start.
    The problem is, unlike leaf springs there's more detriment to geometry to coil/multilink as you lift it. So 1" will likely be the soft limit.
    When you lift multilink it makes the wheel base shorter, it brings the axle forward and because of the panhard bar, it shifts the axle.
    We'll see how it goes, but solutions are definitely coming.
    Tundra has spacers, coils and air bags in plenty supply now.
  4. Apr 13, 2024 at 4:53 PM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
    There will be options soon. The new tundra, previous gen 4Runners and 4g taco all share a nearly identical 5 link suspension system.
  5. Apr 18, 2024 at 6:50 PM
    njweekends
    Bilstein gave an update on where they stand for those interested.
    "The 2024+ models of the Toyota Tacoma have undergone a suspension change with their latest generation. Bilstein will be starting projects to build 5100’s and other series for these vehicles but this project and production will likely see us through the end of this year at least. Please use the link below to check back periodically to see if products have become available for this chasses. Thank you."
    mmessier2 likes this.
  6. Apr 19, 2024 at 8:43 AM
    slater
    slater Well-Known Member
    San Diego
    24 white Tacoma TRD Sport 2wd
    Theres lots of lifts already available for the 24's
    search:
    westcott design
    peak suspension
    readylift
    westcott has a ton of utube videos
    peak may also, not certain
    many options.
    you could just lift / level the front & leave the rear.
    front lift theres, 1.5" 2.0" 2 1/4" 2 1/2"
    rear:3/4" 1/0"
    from various manf i mentioned
    From my understanding, from me reaching out to peak & westcott, the rake is built into the truck & their actual front & rear lift packages will not totally level your truck, it will still have a rake.
    My issue is, I dont want a rake & we all know we can stuff big tires under it without a crazy lift.
    So how high to take in the front is the issue....?
  7. Apr 22, 2024 at 2:44 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Adjustable panhard bar would be nice because I see when lifting the rear you may see the wheels kick out to one side.
  8. Jun 20, 2024 at 11:33 PM
    watkins303
    watkins303 Well-Known Member
    Travis
    Orange
    2017 White Sport
    @slater you mentioned that there are front lifts ranging from "1.5" 2.0" 2 1/4" 2 1/2""
    I've looked at all the options from westcott design, peak suspension, readylift, to even Toytec, and Rough Country.
    Maybe I'm missing something but I'm not seeing a 2.0 front lift, do you know which lift kit provides a 2.0 front lift because I am looking for one if so.
    Thanks,
  9. Jun 25, 2024 at 10:19 AM
    slater
    San Diego
    I dont recall if it was an readylift or lift master, they had 2 differnt lift heights, maybe im mistaken on the height. If youre looking for 2" might as well go with peak & get the 2 1/4"
    my guess is there still may be some very slight rake, maybe...
