Bilstein 6112 Install
Discussion in 'Suspension' started by 12ProTaco, Apr 18, 2015.
  1. May 18, 2015 at 1:19 PM
    TacoDeLaPlaya
    TacoDeLaPlaya Total Automotive Performance Sleeper Cell
    Bobby
    Del Mar, CA
    06 Silver Access cab
    Custom sotoshi deep dish grill 6112 front 5100 rear Leer 100xl
    Ride is great on the front with 6112. If your rear springs are saggy and you bottom out occasionally then you will need to upgrade your springs to really push 6112 offroad. I love the way the car drives now on the middle setting. I would recommend this to anyone who wants a lift, and as cliche as it sounds, it drives like stock when your cruising on smooth road. Every other situation is even better then before. The ride is not overly stiff or jarring in anyway provably due to the control gained by the massive shock.
  2. May 18, 2015 at 1:32 PM
    NateMob
    NateMob Well-Known Member
    Nathan
    South Ogden
    1997 Land Cruiser
    Triple Locked
    Icons are 650lb coils standard, 700s are optional.
  3. May 18, 2015 at 4:40 PM
    619rockstar
    619rockstar Well-Known Member
    Ray
    San Diego
    2015 DCSB TRD_OR MGM 4X2
    6112 Bilsteins
    you said middle setting, is that at 1.75?
  4. May 21, 2015 at 5:20 PM
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
  5. May 21, 2015 at 5:36 PM
    Josh828
    Josh828 Well-Known Member
    Josh
    Avery NC
    14 White TRD Off road, Mid travel mountain truck
    FOX 2.5 extended travel, Fox 2.0 rears, LR UCA, XSPX rims, some light bars, and switches
    So the #5 setting is really more like over 3in of lift? would mean if I want around 2.5in of lift to go with #4?
  6. May 21, 2015 at 6:39 PM
    Yota64
    Yota64 Professional Threadjacker
  7. May 21, 2015 at 8:16 PM
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    I have a 2wd so if your 4wd your results will vary. I got 2.25 left front and 2.5 right front. This was on the third setting which should be less than 2 inches. In general i would say up to half an inch higher than the chart says. Im not sure if the effect is consistently .5 more it may be more true to the chart if using the lower perches and exaggerated even more on higher ones. I dont know.
    There is no zero lift setting. They will keep making 5100
    However, most men will take a free inch gladly. It will only enhance the looks and performance unless your trying to run nastruck. The 5100 would be a hefty sacrifice just bc of the lift in my opinion.
  8. May 21, 2015 at 8:17 PM
    Yota64
    Yes of course, agreed on all points, unless you're already running a 4" spindle lift, you know?
  9. May 21, 2015 at 8:20 PM
    Skootter14
    Skootter14 Upon my signal, unleash Hell
    Jeremy
    '11 TRD Sport 4D LB 4x4 Metallic Grey
    "a lot of stupid stuff" -Wife
    why couldnt I find these on the DSM website under tacoma bilstein. I just saw a lot of 5xxx series. I was trying to find a cost for a set (front and rear)
  10. May 22, 2015 at 7:27 AM
    Chaz84
    Chaz84 Well-Known Member
    Dr. Chase
    GA
    09 blk Tacoma TRD OR 4x4
    FOX 2.0 coil-overs, rear 2.0 RR's CD adj & roost shield, Wheeler's Off Road progressive 1.5" AAl's & Super bumps front & rear, 1' angled block, airlift bags w/ in-cab control & under hood compressor, trailer brake controller, Warn 1st gen M8000, U.S. Off Road hidden winch mount, Body Armor rear bumper, Trail Gear sliders (all Bullet-lined & welded), Sony touch screen dvd, JL Audio Stealthbox, 500/1 amp, Helix tbs, URD intake w/shield, 4 D-rings, in-cab wEnch controls (pics), door sill guards, weather tech mats, black-out headlights, LED cab/backup/bed/ trail/tag lights w/ hidden in-cab switches, PIAA yellow xenon fogs and PIAA extreme white plus headlights, AVS bug & vent visors, red Devil Horns, Undercover tonneau cover, two 30ft straps, tree saver, snatch block, tire plug kit,125psi compressor w/ 1.5 gal tank, 4 5k lb tie-downs, Mag light Pro w/glass breaker seat mounted (drvr&pass), diff breather mod (behind driver tail light), anytime locker mod, Mobil 1 diff oil, Mobil 1 extended performance oil and filter, 840 amp Energizer battery, 285/70/17 XD's, Nittos, 2x2 Cali Raised hyper spot ditch-light pods. CMC
    Yeah, you're on point... Was referencing my buddy's set up with the 700lb coils being necessary to not run the sway bar. My fault for not being clear. Preciate the clarification.
    Also, note that he added uniball upper arms and 1"wheel spacers to widen his stance and says it made the truck more stable.
  11. May 22, 2015 at 7:15 PM
    619rockstar
    Ray
    San Diego
    6112 Bilsteins
    was gonna pull the trigger on some 6112s but now Im considering 5100s with OME 884s, I only want to lift 2 inches in the front and leave rear stock.
  12. May 22, 2015 at 8:00 PM
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    Still would rather have an inch of lift and a lot larger shock
  13. May 22, 2015 at 8:07 PM
    Yota64
    Why not get the 6112s and their replacement coils?
    Just saying so of us don't want 5" :notsure:
  14. May 22, 2015 at 8:25 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    I have the 5100/884 setup. You will be nose high without rear lift.
  15. May 23, 2015 at 2:39 PM
    #35
    619rockstar
    Ray
    San Diego
    6112 Bilsteins
    6112s are a little pricey, and from what I hear the 884s with 5100s is a good set up and cheaper
  16. May 23, 2015 at 3:11 PM
    #36
    619rockstar
    Ray
    San Diego
    6112 Bilsteins
    I like your set up, very nice rnger, I think I will also go with Progressive AAL
  17. May 28, 2015 at 6:31 PM
    #37
    619rockstar
    Ray
    San Diego
    6112 Bilsteins
    Finally decided to go with the 6112s, ordered today, hopefully I get them tmrw, so I can install over the weekend
  18. May 29, 2015 at 8:38 AM
    #38
    TacoDeLaPlaya
    Bobby
    Del Mar, CA
    Awesome. Hope they come quick! Where did you order from?
  19. May 30, 2015 at 3:14 PM
    #39
    619rockstar
    Ray
    San Diego
    6112 Bilsteins
    Socal Suspension, in El Cajon, I was hoping I would have them for the weekend, won't have them till Monday
  20. May 30, 2015 at 3:18 PM
    #40
    Yota64
    Since these are 60mm does that mean they'll perform better than other companies 2.0 (2 inch) coilovers?
