Bilstein 6112/5160 vs Eibach Pro-Truck Stage 2R vs Fox 2.0
Discussion in 'Suspension' started by KamiumiTV, Jan 10, 2024.
  1. Jan 10, 2024 at 8:02 AM
    KamiumiTV
    KamiumiTV [OP] New Member
    2023 Toyota Tacoma Trail Edition
    Hello everyone,
    I'm super new to the whole truck scene (I'm the first in the family to get one).
    So please forgive me, as my questions can be rather stupid.:duh:
    I have a 2023 Tacoma Trail Edition DCSB and want to do a quick lift (to fit a 33" KO2). After a lot of research for "affordable" options, I concluded with these 3.
    My truck is mainly used as a daily commuter; probably 80–85% of it is driven on the freeway in Socal. But I do want to eventually pick up some easy trails.:mudding:
    As for weight, I plan on adding a Southern Style Full Plate Front Bumper (with Bullbar) with no winch.
    Thank you so much in advance, and I'm looking forward to your reply.
  2. Jan 10, 2024 at 11:41 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    SE Wisconsin
    2015 Toyota Sienna with rear locker
    Welcome to Tacoma World. Any of those options are probably fine for just commuting and light trails. heck, stock shocks are fine for that.
    Bilstein 6112 have a 60mm body which comes out closer to 2.3". Bigger is generally better for a few reasons. The other two options are a 2.0" shock body. Having previously used 6112/5160 combo myself before I can say they are quality parts and I'd run them again.
    Lift does not equal clearance. 3rd gen you may be able to fit a 33" tire already with very minimal clearancing. Your Trail edition already has a small amount of lift anyways, no?
    Adding a bumper later should be fine but you may have to adjust front coil preload if it sags.
    TVH475 likes this.
  3. Jan 12, 2024 at 7:20 AM
    KamiumiTV
    Thank you so much for the warm welcome @wi_taco !
    I think the 6112/5160 combo offers the best bang for the buck like you said with the 2.5 in body and requires almost no maintenance (especially for a newbie like myself)
    The Trail edition has an extra 1.1" lifted in the front (longer spring) and a 0.5" lifted in the rear (block)
    wi_taco likes this.
  4. Jan 19, 2024 at 8:56 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    All 3 are quality setups. Here's been my experience with them all having sold them all and been in vehicles with them all on many, many different occasions.
    Bilstein 6112/5160 - I currently hold this setup as the best setup for the money in most cases. You get a solid amount of oil capacity as @wi_taco alluded to, a shock that doesn't ask for a rebuild after 40k, and a very solid all-around ride quality.
    Eibach 2R - Also an excellent setup. The ride profile is very similar to Bilstein, but the Eibachs ride a little softer in my experience. The downsides to them are that they are a smaller body up front so they are going to be more susceptible to shock fade when pushed. They also have shock bodies that I have found to be more susceptible to the elements. Our salt belt folks have been finding that the body finishes are tired after a couple of winter cycles. That said, we've never had one come back for breakage or seals failing so we're good there! Just a visual "note"
    Fox 2.0 - We pretty much don't recommend these for daily drivers anymore... unfortunately. IMO you're largely paying for the name with the 2.0. For daily driven use they tend to ride quite firm (contrary to what their progressive valving nature would lead you to believe). Then, to top it off when you really push them they don't have the oil capacity to keep up. :notsure: If you're going to run Fox my two cents is to push to something like the performance elite series where you'll get to truly feel the Fox benefits.
    We've got everything that you've been eyeing here on the shelves at Hotshot Offroad. If you have more questions, or just want to chat through build ideas shoot me a pm or give us a buzz! 406-936-0206
    MrChoda, Daulll and clenkeit like this.
  5. Feb 12, 2024 at 9:05 AM
    Bakwoodz
    Bakwoodz Member
    SW Idaho
    2022 SR5 Crew Cab Long Bed
    SDHQ Hidden winch mount Warn VR EVO 10 Winch SDHQ Built A-Pillar Light Mounts Baja Designs Squadron Sport LED ditch lights Baja Designs Squadron Sport Fog Baja Designs 30" S8 LED Light Bar Expedition essentials switch pro panel bracket Switch-pro 9100 OTT tune by Taco Vinyl
    With the 2R do you recommend an AAL or new rear leaf pack with a topper installed? Also, what tire size is recommended with this set up?
  6. Feb 12, 2024 at 9:41 AM
    memario1214
    Colton
    Missoula, MT
    Since you have some weight back there I'm almost always going to recommend adding in some steel to address it. A progressive AAL will certainly do the job and not punish you from a ride quality perspective. That said, if the budget allows for it you'll definitely get a little better ride quality/articulation out of a full replacement pack.
    33s are a pretty common pairing with something like this on the Taco, but a lot of factors come into play like wheel offset, your aversion to cutting some metal/plastic, etc. If you want to stay on the safer side then I would say to look around a 32"-not quite 33" tire if you don't want to have to clearance much.
    MrChoda, wi_taco and Bakwoodz[QUOTED] like this.
  7. Mar 1, 2024 at 5:20 PM
    23trdsportpali
    23trdsportpali Member
    2023 Tacoma TRD SPORT ACLB Lunar Rock
    Bilstein 6112 5160s, Icon Rxts, 265/70/17 Wildpeak At4w
    Are there any full leaf replacement packs you recommend?
  8. Mar 1, 2024 at 5:25 PM
    memario1214
    Colton
    Missoula, MT
    For the money we still really like Icon RXTs. You'll want to do a bit of squeak mitigation before install, but we have sold a ton of them, and they perform quite well. We actually even have them on sale starting today! If you pick them up with some shocks or other bits we'll ship them for free too.
    https://hotshotoffroad.com/products/icon-2005-toyota-tacoma-multi-rate-rxt-leaf-pack-w-add-in-leaf
