Bilstein 5160’s - Left & Right interchangeable?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by KY_Rob, Aug 12, 2023.
  1. Aug 12, 2023 at 9:28 AM
    KY_Rob
    KY_Rob [OP] Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    Long story short, I ordered a Bilstein 6112/5160 kit. When I received the kit, what I got for the 5160’s were (2) shocks marked as 25-242539 Right Rear.
    After some digging, I’ve found that Bilstein also has part number 25-242379 for the Left Rear. I’ve been able to ascertain from several other TW posts, that the Left side shocks at one point were somewhat difficult to find, and that some folks have used (2) right side shocks. No mention that I could find about how using (2) rights might have worked out. Anyone have anything specific to contribute on how this has worked out?
    I’ve also found that Bilstein part numbers 25-242539 & 25-242379 have both been discontinued, and replaced with a single common part number 25-311259. If I were to guess, the only difference between the discontinued product numbers and the new product numbers would be labeling that removes the right & left wording, but I don’t know that for sure. Anyone able to provide further insight?
  2. Aug 12, 2023 at 9:46 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    KY_Rob[OP] likes this.
  3. Aug 12, 2023 at 9:51 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The “old” 5160s are side specific because they come with reservoir mounting brackets that are side specific and attach to the vehicle frame. The shocks themselves are the same as far as valving, but the direction/angle in which the reservoir comes off is different as well if memory serves me correctly.
    The “new” 5160s all come with billet reservoir mounts which attach the remote resi to the main shock body. As a result, there was no longer a need for side specific.
    giddie, =JSG=, Junkhead and 4 others like this.
  4. Aug 12, 2023 at 11:10 AM
    KY_Rob
    Rob
    North East Ohio
    If I understand you correctly, I’d need to make a modification or 2, in order to use 2 right side shocks?
    If that’s the case, I hope the place I bought them from makes it right by either sending me a proper left side shock OR a pair of the “new” 5160’s…and provide return shipping for the incorrect stuff. No way should I have to make changes to how things mount because of a lack of proper inventory. They should’ve asked before shipping, or made some sort of effort to inform me. I just sent them an email this morning (it’s Saturday), so I don’t really expect to hear anything until early next week. We’ll see how it goes.
    Thanks for the info! Should’ve just reached out to you guys straight away. Lesson learned.
  5. Aug 12, 2023 at 11:22 AM
    Chew
    Chewy
    Midwest
    19 TRD OR
    Yeah, they should make it right. I wonder how long ago this change was made; at certain point, you’d think a trailer would advertise as “discontinued inventory” at a reduced price. But, that still doesn’t justify trying to pack a “kit” with two right side shocks.
  6. Sep 2, 2023 at 8:34 AM
    TacoTomek
    TacoTomek Well-Known Member
    2021 TRD OR
    I installed 5160’s about a year ago and just realized I swapped left and right. It didn’t even occur to me they would be side specific. Easy enough to switch. Add that to my next oil change to-do’s :)
  7. Sep 2, 2023 at 8:51 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    The only difference is the right side shock comes with the extension bracket for the brake lines. Every thing else is identical on the older shocks.
  8. Sep 7, 2023 at 6:48 PM
    chasecmc
    chasecmc Well-Known Member
    Chase
    2017 DCSB TRD OR
    GFC
    My 5160’s showed up today but came with mounts for the frame, not to the shock body. They don’t appear to be labeled as left/right side on the shock body like I’ve seen on older versions.
    I wonder if I also get an older set or if they changed back?
    I didn’t see a brake line spacer like the drivers side used to include, anyone have experience with that?
  9. Sep 7, 2023 at 6:58 PM
    memario1214
    Colton
    Missoula, MT
    You got them from us, right? Shoot me some pics of what you received! We don’t send any old ones out unless our distributor tried to pull a fast one on us. Do they have black labels? Or blue?
    chasecmc[QUOTED] likes this.
  10. Sep 7, 2023 at 7:15 PM
    chasecmc
    Chase
    2017 DCSB TRD OR
    GFC
    yes I did! I’ll grab some pics when I get a chance - they are black labels though.
  11. Sep 7, 2023 at 7:33 PM
    chasecmc
    Chase
    2017 DCSB TRD OR
    GFC
    Just emailed you some photos, Colton. Looks like the new part number on both! But, a frame mount if I’m not mistaken. Which I’m cool with actually.
    the brakes for factory brake lines was to extend the reach a little though, right? Getting that on the old ones would prevent the need for new lines if I’m not mistaken?
  12. Sep 7, 2023 at 7:36 PM
    memario1214
    Colton
    Missoula, MT
    Black labels is correct so that part is good. I’m wondering if Bilstein made some rolling change and started doing frame mounts instead of shock body mounts? Or possibly it was a mispack.
    As for the brake line relocate, most people just bend the tab down.
    I replied to your email, and will see what you send back in the morning :thumbsup:
  13. Sep 7, 2023 at 7:38 PM
    chasecmc
    Chase
    2017 DCSB TRD OR
    GFC
    Sounds great, thanks for the help!
  14. Sep 7, 2023 at 7:48 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    The 5160s I bought from you end of April have black label and frame mount. I’m not familiar with the other style, but these are very nice, I’m happy with ‘em.
  15. Sep 7, 2023 at 8:38 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Yep they are the same, don't sweat it.
  16. Sep 8, 2023 at 5:34 AM
    KY_Rob
    Rob
    North East Ohio
    Not to highjack the thread, but what was the point of the brake line spacer anyway? I just installed it on my truck this past weekend, and was wondering what the need for it is. Seems to lift the existing bracket about a 1/4 inch, the best I can tell.
  17. Sep 8, 2023 at 7:09 AM
    CaptainBart45
    Bart
    Work in progress...
    Are you talking about the brake line clamps that attach to the factory leaf springs?
    KY_Rob[QUOTED][OP] likes this.
  18. Sep 8, 2023 at 10:00 AM
    memario1214
    Colton
    Missoula, MT
    :boom:
    Just can't believe I didn't know that! We just don't usually have a reason to crack open the 5160s since they don't require anything from our end. I made a call to Bilstein and can confirm it was a rolling change.
    BillyE and Chew[QUOTED] like this.
  19. Sep 8, 2023 at 11:35 AM
    PTSDTherapy
    PTSDTherapy Well-Known Member
    22 SR5 DCSB
    Glad I stumbled on this. I have been looking at these but now that I know they went back to frame mount I have to see if I can still use them. Sometimes reading little shit like this saves so much time. Thanks @memario1214
    KY_Rob[OP], memario1214 and Chew like this.
  20. Sep 8, 2023 at 3:18 PM
    KY_Rob
    Rob
    North East Ohio
    I wasn’t, but now that you mention those, that was also a head scratcher…
    I was talking about the little spacer block that came with the shocks, for use on the drivers side. Was a bit of a pain to install, as a 3rd hand was almost required. Not sure why it’s needed, as it only seems to raised the Y-bracket up about a 1/4 inch, but I installed it anyway.
    Back to those brake line clamps that attach to the factory overload springs (that are no longer present because they were replaced with the ICON AAL)…there’s literally no place to mount them now, as they put too much tension on the lines when connected to the AAL’s. I’m pretty sure they can be cut off and disposed of, but that’s a one and done kind of thing. I’d rather be 100% certain before doing that. As of now, they’re just rattling around doing nothing.
