Bilstein 5125 techical question.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sdcrofts, Jan 21, 2018.
  1. Jan 21, 2018 at 1:03 PM
    sdcrofts
    sdcrofts [OP] Well-Known Member
    Scott
    2015 Tacoma XSP-X
    OME 887; Bilstein shocks; LR UCA; Wheeler's AAL; Debadge
    2015 Tacoma XSP-X 4X4.
    When I was going back together with my Wheeler’s AAL I attempted to install my new Bilstein 5125’s. To my surprise the bushings installed on the shock and both sleeves are too wide for the lower mounting bracket. I tried searching multiple threads here and online for an install and/or FAQ section, but couldn’t find anything useful. Am missing something or did they send me 5125’s for another vehicle?
  2. Jan 21, 2018 at 1:05 PM
    DrFunker
    DrFunker Well-Known Member
    Had the same issue with mine. :thumbsup: They are in now. :D Have been for 2 years. No issues.
    @tacobell007 Do you remember how much of a pain in the ass it was to get those in?
  3. Jan 21, 2018 at 1:07 PM
    tcjacado
    tcjacado Well-Known Member
    How much wider is it?? Sometimes you need to spread(bend) the slot open little.
    DrFunker likes this.
  4. Jan 21, 2018 at 1:11 PM
    sdcrofts
    Scott
    2015 Tacoma XSP-X
    Like an 1/8th of an inch maybe. I considered tweaking it, but wanted to check around to make sure. Anyone know why they include 2 different sleeves....one stainless looking and one dark?
  5. Jan 21, 2018 at 1:12 PM
    DrFunker
    We tweak mine. Didn't get two sleeves.
    tcjacado likes this.
  6. Jan 21, 2018 at 1:12 PM
    tcjacado
    That I don't know. I have never purchased new shocks. Lol
    @eccracer104 might know? Mikey knows everything:rofl:
  7. Jan 21, 2018 at 1:16 PM
    sdcrofts
    Scott
    2015 Tacoma XSP-X
    The upper bushings they sent seemed too thick as well. I’m probably just going to use the old bushings off my shocks, as they have under 40k on them AND they fit.
    Net between 1.5-2.0” on the AAL. After I put in the OME/5100’s/UCA’s up front I should have a 1” take with a 2.5-3” lift.
  8. Jan 21, 2018 at 1:16 PM
    Pigpen
    Dan
    Northwest Montana
    Normal.
    You can widen the bracket, or just massage it in. I used a 3lb hammer with a piece of wood as a buffer. A dead blow hammer would be a better choice.
  9. Jan 21, 2018 at 1:18 PM
    Pigpen
    Dan
    Northwest Montana
    The new bushings will work fine once everything is together. Just crank that top nut down to squish the bushing.
  10. Jan 21, 2018 at 1:18 PM
    DrFunker
    Tool of choice for us. :thumbsup:
  11. Jan 21, 2018 at 1:20 PM
    Pigpen
    Dan
    Northwest Montana
    BFHFTMFW!!!
    DrFunker[QUOTED] and tcjacado like this.
  12. Jan 21, 2018 at 1:21 PM
    DrFunker
    :amen:
    I use that shit on everything. :D
  13. Jan 21, 2018 at 1:22 PM
    tcjacado
    They are new so it might need to be spelled out for them. Big Fawking Hammer For The Mother Fawking Win.... follow The caps. :thumbsup:
    MrChoda and DrFunker like this.
  14. Jan 21, 2018 at 1:23 PM
    Pigpen
    Dan
    Northwest Montana
    :thumbsup:
  15. Jan 21, 2018 at 1:24 PM
    tcjacado
    Different diameter and lengths I believe
  16. Jan 21, 2018 at 1:39 PM
    Pigpen
    Dan
    Northwest Montana
    Same diameter, as far as I know.
    5100 is an upgrade for lightly modified vehicles - up to 3" lift on stock leaf springs. 5125 is an extended length 5100 for aftermarket leafs. B110 is an extended length 5100 for trucks with 4-6" lifts. 5160 is an extended length 5100 with a reservoir.
  17. Jan 21, 2018 at 1:43 PM
    R242
    R242 I have a tortoise
    Rick
    Indianapolis, IN
    2024 SR 4x4 6 spd
    I used an exacto knife and cut an 1/8" off each side of the bushing(lower) after installing the bushing. This has been done numerous times, I read where others had done it.
  18. Jan 21, 2018 at 1:46 PM
    Pigpen
    Dan
    Northwest Montana
    Bushings are supposed to fit snug.
    It's Hammer Time!
    DrFunker and tcjacado like this.
  19. Jan 21, 2018 at 3:20 PM
    tacobell007
    tacobell007 Western Mass Automotive Coatings
    Drew
    Western MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets, 5.29 Nitro gears, ARB front air locker, Detroit locker in the rear
    Slightly, i think there was some slight bracket bending and some pry bar action lol
    DrFunker[QUOTED] likes this.
  20. Jan 21, 2018 at 3:22 PM
    DrFunker
    :thumbsup:
    Massaging.
    tacobell007[QUOTED] likes this.
