Bilstein 5125 rears
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTim85, Jan 17, 2021.
  1. Jan 17, 2021 at 7:45 PM
    TacoTim85
    TacoTim85 [OP] Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    Haven't seen much talk lately about anyone installing Bilstein 5125s on the rear with a lift.
    Wheeler's site says they measure 15.01" collapsed and 24.38" extended. That's about 1.5" longer extended than stock and about 1 inch longer compressed. Would need to extend/replace bump stops and extend the brake lines (or maybe use a small spacer at the brake lines bracket on the axle).
    I know I've read threads where people installed these, and I think there were issues with the lower shock eyelet fitting into the factory lower bracket or something. Shock lower eyelet too wide maybe?
    Anyone done this lately?
  2. Jan 18, 2021 at 6:20 PM
    PNWTacoAdventures
    PNWTacoAdventures Well-Known Member
    Washington
    2020 Super White Tacoma TRD OffRoad
    Didn’t have to do anything special with my 5160’s. Just added an Icon AAL
    FlavorChef7 likes this.
  3. Jan 18, 2021 at 7:10 PM
    TacoTim85
    Was asking about 5125s.
    kahanabob likes this.
  4. Jan 18, 2021 at 7:24 PM
    PNWTacoAdventures
    Washington
    I am aware - I can read. Just giving you the 5160. Do with it what you want. Seems like a lot of work to put 5125’s in.
  5. Jan 18, 2021 at 7:31 PM
    TacoTim85
    Didn't ask if you could read either.
  6. Jan 18, 2021 at 9:42 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
  7. Jan 18, 2021 at 10:07 PM
    TSmoove
    TSmoove Well-Known Member
    Trevor
    Atlanta, GA
    2017 Tacoma
    I have them on mine. The rubber bushing was too big for lower mount so I trimmed it to fit. Took like 2 minutes.
    TacoTim85[OP] likes this.
  8. Jan 18, 2021 at 10:24 PM
    TacoTim85
    How have they worked out for ya? Just used a razor knife to trim each side of the bushing or what?
    Thinking if I lift the rear 1.5 inches with an AAL it would be nice to regain that down travel with longer shocks. The trick is I don't know if the AAL will allow the leaf packs to flex down more than stock. The stock leafs are what limits the droop (not the stock shock length).
    Lower shock bolt removed:
  9. Jan 19, 2021 at 8:13 AM
    TSmoove
    Trevor
    Atlanta, GA
    2017 Tacoma
    Yeah, just used a knife. I’ve had them on for a year, no issues, ride great. Another option would be the extended version of the 5100.
    https://www.headstrongoffroad.com/s...Extended_Length_Rear_Shock_(PAIR)_-_B110.html
    TacoTim85[QUOTED][OP] likes this.
  10. Jan 19, 2021 at 12:58 PM
    OregontoBajaCA
    OregontoBajaCA Well-Known Member
    2017DCLBOR
  11. Jan 19, 2021 at 2:40 PM
    TacoTim85
    Use your words.
    MrChoda likes this.
