Bilstein 5100 tire size?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Chasingpro, May 31, 2020.
  1. May 31, 2020 at 4:51 PM
    Chasingpro
    Chasingpro [OP] Member
    Chase
    2018 Tacoma SR 4x4
    I’m sure there is already a thread, if so please point me in the direction.
    I am looking to do the bilstein 5100 kit. I don’t want to do uca because I’m on a budget. What tire size will I be able to run without rubbing or cutting, and what height setting?
    ScooterFunPants likes this.
  2. May 31, 2020 at 5:25 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    265/75R16 or 265/70R17 at any setting. This is the largest size at stock height and with a lift without cutting.
    255/86R16 also work, we call them pizza cutters. Bigger but skinny.
    Anything larger requires cab mount chop (CMC) or other cutting/modifications to fit.
    Now you have all info you need to search further through forums. Let us know if you have more questions. And welcome
  3. May 31, 2020 at 6:20 PM
    BravoSix
    BravoSix Well-Known Member
    2017 MGM SR5 DCSB 4x4
    Seat jackers, Tonneau, Toyo AT3 235 85 16.
    I have 235 85 16 and they dont look as skinny as people make them sound. They look normal to me like they should come on Tacomas stock. I have no lift but want to upgrade suspension at some point. I don't care about lift. I want good suspension.
    BalutTaco likes this.
  4. May 31, 2020 at 6:21 PM
    Jasonstacoma
    Jasonstacoma Well-Known Member
    2019 dcsb Barcelona red
    Stock
    I did 265 75 16 and never rubbed at full flex. Now I'm onto 285 75 16s and am doing ucas, cmc, and trimming.
    71tattooguy likes this.
  5. May 31, 2020 at 6:22 PM
    Jasonstacoma
    Stock
    U can do 5100s w the ome 887s and be fine. Over 2 in and u will have shit angles on the front cvs.
  6. May 31, 2020 at 6:30 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    DFC65743-7270-4022-9C32-BDDB2EF9F70A.jpg 5100’s 1.5” front lift oem coils / rear 1.5” wheelers aal. Factory rake. Ride is stiffer in a good way. Just my 2cents. Welcome to the forum bro
    BravoSix and jmauvais like this.
  7. May 31, 2020 at 6:38 PM
    ivanbruhhh
    ivanbruhhh Active Member
    Ivan
    08 Silver Tacoma
    3 inch lift from supreme suspension. 265/70/16 wrangler Kevlar at on trd off road wheels.
    Yeah I ran 265/70/r16’s and upgraded to a 3 inch lift to fit 285’s/33s oem UCAs.
    not regretting it one bit. If you want bigger tires I’d just do a 3 inch lift and save up. Technically from 265 to 285 it’s just a $100 upgrade on most tire/wheel companies.
    but if you’re just trying to save I would do 265 the safest bet. No rub and no trimming needed.
  8. May 31, 2020 at 6:42 PM
    BravoSix
    This is what I'm looking at doing also.
    71tattooguy[QUOTED] likes this.
  9. May 31, 2020 at 6:45 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Thanks bro. Yeah very subtle lift but rides great and 265/75/16 still look good. Great light off-roading and camping etc ... I use it it’s a truck. Glad I went this route. No complaints
    BravoSix[QUOTED] likes this.
  10. May 31, 2020 at 6:47 PM
    BravoSix
    Exactly. It looks great and is very functional. I carry heavy gear in the bed much of the time, pull a boat, pull an atv on a trailer etc. I want a stiffer ride that can absorb the extra weight and bumps without having to alter CV joints, shafts, or anything like that.
  11. May 31, 2020 at 6:50 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    With towing that much weight maybe look into a leaf pack instead of an aal. Other members definitely know more about leaf packs. Or you could do Progressive leaf pack and leave overload spring in. Just a thought
  12. May 31, 2020 at 6:52 PM
    BravoSix
    I've been reading up on all the info on the forum
    I think I saw the 5100 OME kit with Dakkar (spelling) all for around $1200? I'm looking for something I can install myself and just get an alignment and roll.
  13. May 31, 2020 at 8:01 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    That’s a good kit bro. Think it will be perfect
    VaToy and BravoSix[QUOTED] like this.
  14. Jul 13, 2021 at 8:17 PM
    MNYota
    MNYota Member
    David
    Minnesota
    2001 Toyota 4Runner SR5, 2010 Tacoma SR5 Sport
    Work in progress
    Sorry to dig up an old thread, but I have a bone stock 2010 access cab, V6, 6-speed manual. Currently on 265/70/17’s. I’d like to lift it a little, maintain a decent on road ride and put taller tires on it. Thinking Falken Wildpeaks somewhere around 255/85/16 or 265/85/16. Also looking for some cheap black wheels. Would 5100’s get me there without the CMC and trimming? No off reading, just a daily driver.
    Thank you guys! I will appreciate any help or advice you can offer.
  15. Jul 13, 2021 at 8:55 PM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    https://www.bilsteinlifts.com/shop/Toyota-tacoma/1995-2004/lift-kits/bilstein-5100-height-adjustable-front-shocks-for-1995-2004-toyota-tacoma/
    This will be perfect depending on front lift adjustments you could also get a 1” block or AAL add a leaf.
    Good luck
  16. Jul 13, 2021 at 10:08 PM
    MNYota
    MNYota Member
    David
    Minnesota
    Work in progress
    Thank you for the reply! Unfortunately those are for a 95-04 Tacoma. You think those 5100’s would give me enough height to fit 255/85/16 or 265/85/16 without any trimming or CMC? Definitely considering the AAL though. Thanks for your help!
