Bilstein 5100 shocks/coilovers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Devilfan, Mar 3, 2024.
  1. Mar 3, 2024 at 12:05 PM
    Devilfan
    Devilfan [OP] Well-Known Member
    So I've been reading a lot about lifts here and a lot of guys like the 5100 shocks.
    One thing that I am confused about is that I read quite a few saying the 5100s were designed to be used with the OEM springs.
    If I decided to just get the 5100 coilovers with the OME springs built into it, does that mean it won't as well as just replacing the shock since they aren't the OEM springs?
  2. Mar 3, 2024 at 2:31 PM
    TacoTuesday1
    FL
    I had 5100 with OME springs. It was not good. It was pencil thin and cheap. That is why.
  3. Mar 3, 2024 at 3:28 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    From what I understand, is that the 5100 is best paired to have the stock OEM springs.
    Others have put Old Man Emu springs installed with various accounts of success and failures, you can goggle them.
    If you do decide to put on Old Man Emu springs on 5100, do not rely on the documentation regarding the circ-clip.
    And your mileage will vary, and experiences / support with them is limited.
    It would be best to just set it up with 5100 with stock springs, or full (insert Vendor name here) Shocks w/springs, so you dont need to think about it.
  4. Mar 3, 2024 at 3:44 PM
    Devilfan
    I will most likely just use the stock springs and replace the shock.
    Would that be better than removing the stock springs and shock and just replacing it with the Bilstein 5100 ride height adjustable coilovers?
  5. Mar 3, 2024 at 3:53 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    You can use OME springs on the 5100s.
    But you need to leave the shock set at the factory height.
    The lift will be done by the springs, and not the shocks, if using OME springs.
    BluberryBCtaco likes this.
  6. Mar 3, 2024 at 11:23 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Had 5100 on my 2gen for over 100k miles so far with stock springs set on 3rd notch which is 1.75 lift approx. Bottom notch is 0 lift, 2nd is 0.85, and top 4th is 2.5. At 2.5 you need aftermarket UCAs.
    So yes stock springs work but ride may be stiffer for you but alignment can be set on lower 3 notches. Believe Bilstein does not even list the 5100 for front now want you to buy newer more expensive 6100 series. I run the OME heavy duty rear leaves so about 3" lift back there. All depends on $$ as usual.
