Bilstein 5100 install - upper bushing?
Discussion in 'Suspension' started by omg_miiiike, Jul 21, 2018.
  1. Jul 21, 2018 at 11:32 AM
    omg_miiiike
    omg_miiiike [OP] Well-Known Member
    Maryland
    2017 Tacoma TRD Off Road | DCSB
    Hey guys, I had someone install my Bilstein 5100 on my 2017 TRD OR yesterday. The back looks right, but the fronts do not.
    The driver front sounds like washer jingle when you hit a bump, and the upper bushings (unsure of exact name) are not compressed as they appear in many others photos.
    I attempted to tighten it up myself to see if I could get the bushings to compress a little, it tightens when I hold the top with a cresent wrench and tighten however I can take the wrench and still turn the bolt and assembly once I remove the cresent wrench.
    Attached are photos, the installer plans on taking a look at it today however at this point I'm hearing he's saying everything is correct and something needs to be tightened.. Just looking to the 'what ifs' and what it could be from the photos.
    37611955_10157917310178508_3659799692289_695a2c8977a65971e09d7a0d026017f840907ddf.jpg
  2. Jul 21, 2018 at 11:33 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Yes - that bushing should compress to roughly the size of that upper washer/retainer. Try vice grips on the top stem.
  3. Jul 21, 2018 at 11:34 AM
    omg_miiiike
    Maryland
    Copy, as I figured.
    What components could be making it that I cannot compress it at the moment?
    Sig45[QUOTED] likes this.
  4. Jul 21, 2018 at 11:36 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
  5. Jul 21, 2018 at 11:37 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Older picture but you can see how compressed the top is
    Rzilla80 and omg_miiiike[OP] like this.
  6. Jul 21, 2018 at 11:38 AM
    Sig45
    Mark
    Maine
    I'm not quite sure what would cause the entire assembly to spin. Others may know more.
  7. Jul 21, 2018 at 11:38 AM
    omg_miiiike
    Maryland
    Got it, just wondering what may be missing at this point in case this guy says 'looks good to me'.
  8. Jul 21, 2018 at 11:39 AM
    Sig45
    Mark
    Maine
    He's wrong.
  9. Jul 21, 2018 at 11:40 AM
    omg_miiiike
    Maryland
    When I say assembly spin, I mean the actual 'piston' part of the shock. Sorry for the newb language, it's been a long week at work and still continuing.
    Also, I attempted to find this - but does anyone have a diagram as to the order of the hardware?
    Other than this, everything rides great.. What a difference (to me) the 5100's have made, I don't feel like I'm going to shatter my teeth hitting a speed bump.
    Just hoping to get this situation figured out as soon as possible as this is my only vehicle for now and I have to rely on it to work and back.
    Thanks for all of your fast replies, happy to be part of this forum.
  10. Jul 21, 2018 at 11:42 AM
    Sig45
    Mark
    Maine
    Vice grips should prevent any spinning. Just make sure you get a good grip on the flat part.
  11. Jul 21, 2018 at 12:16 PM
    omg_miiiike
    Maryland
    That's what I did,it tightened up with the grip on the top. I got it as tight as I could but spun it without the grip on the top and it still spins.
    The truck is at the shop now, the guy showed me a photo he took when he completed it and the bushings were in fact compressed as they should be
    Unsure what caused them to come loose or whatever.
  12. Jul 21, 2018 at 12:56 PM
    Sig45
    Mark
    Maine
    Hmmmm...keep us posted on what the issue is. Could be a bad shock.
  13. Jul 21, 2018 at 1:30 PM
    520Toyota
    520Toyota Well-Known Member
    C.V.
    Nor Cal
    dcsb 6spd 4x4 offroad
    Ome lift
    Installer didn’t install one of the hidden washers or rubber cushion. It’s common to forget.
    BillsSR5 likes this.
  14. Jul 21, 2018 at 1:33 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    I don't see the isolator bushing under the hat, or maybe they didn't use the cushion bushing underneath the hat too, the bilsteins 5100 front struts don't come with new upper stud bushings, they say to use the old OEM bushings
  15. Jul 21, 2018 at 1:58 PM
    alimjr
    alimjr Well-Known Member
    Almar
    Southern California
    2018 Magnetic Grey Tacoma TRD Sport
    -TRD Pro Grill -TRD Shift Knob -OEM Side Steps -BakFlip MX4 -FN FX Pro Wheels -Toyo OpenCountry AT2 265/70/17
    You should be able to fit a 6mm hex wrench on the very top of the shock bolt then tighten the bolt to squish the bushing to the same size as the washer.
  16. Jul 21, 2018 at 2:17 PM
    09 Redneck
    09 Redneck Well-Known Member
    Ga
    2BBFA9CE-504B-40F1-BB69-895396E4C0E8.jpg 5E4BEBE4-BA35-4BB8-88FC-689D8DFB2391.jpg CC58CE06-5DA5-442A-A682-7D4CBB7B5134.jpg
    Last pic shows one of the bushings underneath the top hat.
  17. Jul 21, 2018 at 2:39 PM
    DukesTaco
    DukesTaco Well-Known Member
    AZ
    2nd Gen Double cab Pre Runner
    Dm 'nd you
  18. Jul 21, 2018 at 2:56 PM
    omg_miiiike
    Maryland
    Thanks everyone for the replies..
    Just got it back and here's what we have now.. He had to rethread because apparently I over tightened it or something.
    Does this look better?
    37604988_10157919626198508_5291052980257_d72238e786d818d29ded68dd6d8713b9a0023708.jpg
    alimjr likes this.
  19. Jul 21, 2018 at 3:01 PM
    DukesTaco
    AZ
    If you start to hear a sqeak from the suspension in about 6k miles it will be from the top hat and the shock shaft rubbing . If not tightened it will ovalise the top hat hole and will need to be replaced .
  20. Jul 21, 2018 at 3:02 PM
    Sig45
    Mark
    Maine
    Looks better.
    omg_miiiike[OP] likes this.
