Bilstein 5100,888 OEM, Add a leaf w33’s
Discussion in '3rd Gen. Tacomas (2016-2023)' started by djgynee, Aug 20, 2019.
  1. Aug 20, 2019 at 5:59 PM
    djgynee
    djgynee [OP] Well-Known Member
    Southern California
    2018 Magnetic Grey Metallic Tacoma DCLB TRD Sport
    So you those new to lifts like me. You CAN fit 33’s without rubbing with this set up
    https://youtu.be/C9Xz5yyk-LI
    88 Rotors. I got the lift, rims, tires , grill, skid plate. One stop shop. Not done yet. Will I ever be?
    putt1333 and Nightscape like this.
  2. Aug 20, 2019 at 6:07 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Have you rubbed when compressed?
  3. Aug 20, 2019 at 6:18 PM
    wsb
    wsb Well-Known Member
    VA Beach
    2019 Cement TRD OR DCSB
    struts set to 0? overall lift after settling? what is the offset of wheels?
  4. Aug 20, 2019 at 6:43 PM
    Nightscape
    Nightscape Well-Known Member
    SoCal
    2017 TRD Sport DCLB
    Looks similar to my setup ome 5100, 887 with 2" AAL. Your springs front and rear are going to sag eventually. I just ordered a HD Dakar pack and 1/2" thick strut top plates.
    SlashGSX likes this.
  5. Aug 20, 2019 at 7:28 PM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    Exactly what I did. Had the HDs for 6 months now.
    Just installed small spacers this weekend. Back to a nice stance.
  6. Aug 20, 2019 at 7:42 PM
    djgynee
    Southern California
    I have 888 so those are med duty vs 887 are light duty so I’d don’t expect to loose any lift. Everything is settled now. No rub. Full compression I can’t give you an honest answer as far as off-road. Light I’m sure but serious off road trails you have to check with someone who really goes balls out
    Rockefelluh likes this.
  7. Aug 20, 2019 at 8:17 PM
    djgynee
    Southern California
    Time will tell. I’m sure with all the tacomas they’ve done they would had ppl coming back after 1 year dropping that kind of money complaining and changing to the 889.
    And ride quality is far better than stock
  8. Aug 20, 2019 at 8:32 PM
    djgynee
    Southern California
    OME website:
    2888 Springs are used on 2016+ OME Tacoma Lift Kits. They can also be used on 2005-2015 Ome Struts and will result in more lift than the 2887.
    Apparently someone forget to tell the manufacturer their springs only last one year.
    I will say this.... there are soo many opinion and experiences here anyone can get you to second guess your decision. One shop says this one shop says that.
    I went with what my buddies did and ALOT of ppl here. Majority. So we could all have made the same error. But being on 4th year of 3rd gen I think we are safe with this set up.
    My buddy and his boss and me.
    All 2018 trd sport long beds
    I will say that alignment is extremely important as the dealer many deals with manufacturers specs and not mods. So I need to go get it aligned at a specialist that can really dial in my caster/camber it’s a hair forward.
  9. Aug 20, 2019 at 9:24 PM
    Dr. Emmett Brown
    All 3 are 2wd?
  10. Aug 20, 2019 at 9:52 PM
    djgynee
    Southern California
    Yes sir. 2wd trd sport
  11. Aug 20, 2019 at 9:57 PM
    grubburg
    grubburg Well-Known Member
    2019 TRD OR MT
    K & N Intake, Gibson Catback (chopped), Weathertech floormats, 285/70/17 Ridge Grapplers, Black Rhino Glamis wheels, Kicker Key, Kicker Hideaway, Infiniti Speakers, OV Tune, 888's, 5100s X 4, HS 3-leaf, LR SPC UCAs, Diff Drop, Carrier Bearing Drop, OEM Bed Mat, Morimoto HID low beams, Morimoto LED 2 Stroke High Beams, KC 336 LED bar, KC C3 LED pods for rear, KC LED 6'' SlimLites ditch lights, N-Fab Steps, Auxbeam Interior Blue Lights, 7r41lbr34k3r Shift Knob, Wet Okole Seat Covers, Diode Dynamics SAE Pro Fogs, Cali Raised ditch light brackets, hidden light bar brackets, tailgate light brackets.
    I have the 888s 5100s and 3 leaf HS kit. No rubbing either with 285/70/17.
    djgynee[OP] likes this.
  12. Aug 20, 2019 at 10:04 PM
    djgynee
    Southern California
    Great set up. It seems to be the most popular, reliable and affordable. I was going to go with the fox 3” but this set up gives you 2.5 lift in the front and that ( most common opinion) is the sweet spot for our Tacomas. If I went 3” full inches with the Fox it was strong recommended to buy upgraded UCAs as well to adjust the positive camber you will get at the 3” point as it will give you faster tread wear and cv boot tearing sooner because it is out of spec range that can be adjusted with stock UCAs
  13. Aug 20, 2019 at 10:37 PM
    SpeySquatch
    2016 TRD OR DCSB
    With the stock bumper config, yes you will likely be fine. Also missed they were 2wd...my bad
    I think the Bilstein 5100’s are better than the OME shocks. My 888 were so stiff and jarring with the OME shocks. I went through ball joints in one year.
    djgynee[QUOTED][OP] likes this.
  14. Aug 20, 2019 at 10:42 PM
    djgynee
    Southern California
    So I take it you had after market mod upfront? Winch or bumper or something? I don’t plan or added any weight to the front
  15. Aug 20, 2019 at 10:44 PM
    djgynee
    Southern California
    THAT SUCKS 1 year bro. That’s why I just stuck in the “safe zone”.
  16. Aug 20, 2019 at 10:52 PM
    SpeySquatch
    2016 TRD OR DCSB
    130lbs of lo-pro bumper and winch
  17. Aug 20, 2019 at 10:55 PM
    djgynee
    Southern California
    Very nice. Kinda of an important piece of missing info though bro. But now I get why you had that experience.
    Well if I get stuck in my 2WD you can pull me out:thumbsup:
    SpeySquatch[QUOTED] likes this.
  18. Aug 20, 2019 at 11:48 PM
    Dr. Emmett Brown
    Yeah the 2wd is 350 pounds lighter than the 4wd so the 888s will definitely not be a problem for you. For me it was
    SpeySquatch likes this.
  19. Aug 21, 2019 at 7:09 AM
    Dr. Emmett Brown
    2015 - 2wd double cab short bed
    3985 curb weight
    2015 - 4wd double cab short bed
    4195 curb weight
    2017 - 2wd double cab short bed
    4095 curb weight
    2017 - 4wd double cab short bed
    4445 curb weight
    250 pound difference from 2nd gen 4wd to 3rd gen 4wd
    Which raises the question as to wtf happened to make the 4wd so much heavier in the 3rd gen?! Someone knows. Educate me.
    Because the 2wd 3rd gen is only 100 pounds heavier than the 2nd gen 2wd
  20. Aug 21, 2019 at 8:06 AM
    djgynee
    Southern California
    Each generation gets bigger. Humans and Tacomas
