Bilstein 24-186728
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Garymvvvvvv, Dec 18, 2024.
  1. Dec 18, 2024 at 3:42 PM
    Garymvvvvvv
    Garymvvvvvv [OP] It's easier to get forgiveness, than permission.
    Gary
    La Grange Texas
    2022 Tacoma SR5
    TRD pro grill, Raptor Grill Lights, 2 color fog lights, rock flood lights, light bar with powder coated front bumper, X-Bull winch, K&N cold air intake, RIPP ignition coils, oil catch can, E3 iridium spark plugs, 275/70 R17 BFG KO3 tires, OPT7 tail gate light bar, black out mirror caps and rear bumper caps, sprint booster, LED interior-exterior light bulbs. Tacoma Beast 3rd brake light, infinity tail lights and Alpha Rex Nova series headlights, Seat covers, Mr. hood scoop with 18 inch amber light bar inside.
    Yes, I have searched previous posts for these shocks and did not find my answer.
    So....Here I go.
    Purchased a set of Bilstein 5100 Height Adjustable front shocks and the Bilstein 24-186728 rear shocks.
    The height adjustable fronts have grooves and a C clip that you can move up to adjust the lift from 0-2". The rear shocks do not, although they state a lift from 0-1". I contacted summit racing where I purchased them and was told that they do not provide lift, they accommodate an already existing lift of 0-1". He also stated that was the same for the front shocks.
    I quickly realizes he was not an expert on this subject.
    I installed 275/70 R18 KO3's and just need a little lift to remove "minor" rubbing on the fender well during sharp turns.
    I was planning on lifting the front end 1.5" and the rear 1". to help level the truck from the aftermarket bumper and winch while providing some tire clearance.
    Can someone explain to me if the rear shocks actually lift the rear end, and how do I do that
  2. Dec 18, 2024 at 3:47 PM
    ToyodaSun
    ToyodaSun Well-Known Member
    Parts Unknown
    17' DCLB TRD OR
    You are going to need to add a leaf spring to the rear leaf packs to achieve the lift, the shock alone will not do it. Lift can also be achieved with a block spacer.
    Garymvvvvvv[OP] likes this.
  3. Dec 18, 2024 at 5:13 PM
    Garymvvvvvv
    Gary
    La Grange Texas
    2022 Tacoma SR5
    TY ToyodaSun, I had looked at those options before buying the shocks thinking that they would do the lift (Duhhhh?)
    My high school football coach use to tell me, "DONT THINK, it weakens the team"
    I'm 75 and know my limitations. Except for the tires being mounted. I have installed all the mods to my truck so far thanks to this forum and U-Tube. Dont think I am going to tackle the front shocks with the springs and control arms issue. However, I do feel I can do the rears. I think the spacers are within my abilities, not so sure about the add a leaf. Just looking for 1 " rear lift to level.
    Do you think the spacers are an OK option
  4. Dec 18, 2024 at 5:56 PM
    ToyodaSun
    Parts Unknown
    17' DCLB TRD OR
    Spacers are ok as long as you don't plan on overloading the bed with weight, heavy offroading, or heavy trailering. I have spacers on a nissan titan but I'm not a big fan of them, I find the ride to be a bit jarring. They are definitely easier DIY than leaf springs though.
    For the best ride feel I would go with a leaf spring and you can select a spring based on how much load/weight you plan on putting on the truck. Too weak a spring with too much weight is not good. Too strong of a spring with not enough weight, also not good, as the ride will be harsh and bouncy. The nice thing about a spring is that you can select one based on your particular use case.
  5. Dec 19, 2024 at 6:23 AM
    Garymvvvvvv
    Gary
    La Grange Texas
    2022 Tacoma SR5
    I have only added a tonneau cover and I do not plan on adding anything else to the bed. I have a small 5 X 10 utility trailer which I use infrequently. I don't do extreme offroading, mainly dirt roads/trails. Based on this information I would appreciate any insight as whether to go with spacers or leaf. and a preferred manufacturer for both scenarios.
    Thank you
    Gary
  6. Dec 19, 2024 at 6:31 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Do not try to clear tires with a lift. It wont work...never will. The suspension will still cycle the exact same path of travel. Wheel offset and alignment is all that will help you. I ran that exact size for 40,000 miles and never had any rubbing. Your alignment numbers need to be 3-4° caster, 0-0.5° camber, 0 total toe and the wheel offset needs to be around +6 to -15. Anything different and you will rub the cab mount, frame, and/or front plastic.
    As for the rear, go with an add-a-leaf over a block. They are about the same price installed and the AAL will give much better performance.
    Toycoma2021 likes this.
  7. Dec 19, 2024 at 11:51 AM
    Garymvvvvvv
    Gary
    La Grange Texas
    2022 Tacoma SR5
    Thanks to everyone. On an old post< i saw a similiar discussion and a member recommended the 1.5" AAL by All Pro Offroad.
    found them on Wheelers and Tacoma Beast...(free shipping from Wheelers) From what I understand from previous posts, my Bilstein 5100 series rear shocks SHOULD work. Even though they are rated for a 0-1 inch lift.
  8. Dec 19, 2024 at 1:20 PM
    airforceb2cc
    Don
    KCMO
    Yes, they will work. Check out the Icon system as well. Stay away from tacomabeast as they are a complete disgrace to the offroading community.
