Bike rack + travel trailer -- anybody have a solid solution?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by vectaur, Jun 21, 2022.
  1. Jun 22, 2022 at 10:36 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Oof! Tough areas for sure.
  2. Jun 22, 2022 at 11:45 AM
    jgr81
    jgr81 Well-Known Member
    Jen
    Summit County CO
    16 Tacoma TRD OR Access Cab, 03 4runner v8
    I feel like I've tried all available combos when towing my 16ft casita trailer, and nothing is perfect lol
    When running my topper I've put the bikes on top... nice and out of the way but a PITA to get the mtb up and down with a lifted truck
    A company makes a hitch for the casita and I put that on with a 1up rack... Doesn't affect it as much as I thought it would, just have to add a lot of extra tongue weight and not run a bunch of water in the camper tank. My model of casita is fairly tongue light so it's not the best option but doable.
    Before that I was using a lippert jack-it bike carrier that mounts under the jack, it was OK, but turning radius was tight when running a topper - with the topper off the bars have plenty of room. This is with MTB though, road bikes would be so much easier with that set up. https://www.amazon.com/Lets-Go-Aero-Jack-Carrier/dp/B01MYRM7MM I took it off so I could add a jack-e-up removable jack mount since I couldn't put my tailgate down with the jack in placeo_O
    I've taken the topper off several summers and have used normal yakima bike mounts on yakima truck bed bar mounts... super fast to remove them when not using them and you could easily move 4 bikes around. Not a cheap option though, I had the bike mounts already and bought the bed rock bars on craigslist.
    I have the older version of this, it really worked great and room to store stuff underneath. https://www.amazon.com/Yakima-Bedrock-Truck-Bed-Rack/dp/B07MDSNWVN
    Now I have the topper off with a raceface 2 bike tailgate pad since I have a dirtbike now to haul around. I had it mounted to the side and crushed my brake lever when backing up sharply recently... I moved it to the middle of the tailgate and it was fine. I'm also running a stromburg carlson rack that holds a cooler over the propane tanks, without that I probably wouldn't have crunched them lol
    Edit to add pics -
    6797F204-AE1D-49BE-AFC5-905D6B23E6A5.jpg2F6B3170-95AC-4185-BC97-A819C323E442.jpg 29AF5918-E249-43AD-88A0-1D37597A747D.jpg AF9E95F7-76DA-4171-ABA5-C1283B921022.jpg
    brtnstrns likes this.
  3. Jun 22, 2022 at 2:22 PM
    brtnstrns
    brtnstrns Well-Known Member
    Seattle
    2020 Voodoo Blue TRDOR DCSB
    Putting that little Casita to work!
    jgr81[QUOTED] likes this.
  4. Jun 22, 2022 at 2:43 PM
    Browner
    Browner Well-Known Member
    Shawn
    Central Iowa
    2020 TRD OR
    Prinsu Rack, CBI Sliders, UpTop Truss Rack, Softtopper, TRD OEM 2" Lift, SCS Rims, Wildpeak tires, OVS RTT and 270 Awning, Off-Grid Engineering Dual Battery tray, Red-arc BCDC, Switch Pros Controller, cheap Amazon lights.
    I've done the front bike rack thing before and would not recommend it. It's very distracting, and depending on the hitch and rack, it blocks a lot of your view.
    This was a few years ago with 4 bikes on the front and four on the back, driving into downtown Chicago for an organized "Nite Ride" on a weekend. No issues, but not a fun experience. Always worried about hitting a pot hole or dip in the road and several thousand dollars of bikes end up under the Explorer. It does draw attention though.
  5. Jun 22, 2022 at 2:45 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    I only run like this to nearby campgrounds across a couple counties on in-town roads. I’m down to about 12 like this. Usually I have our mountain tandem bike up there and at about 13.5mpg.
    brtnstrns[QUOTED] likes this.
  6. Jun 22, 2022 at 4:15 PM
    jgr81
    Jen
    Summit County CO
    Lol I sure do, dragged that thing all kinds of places! It was much improved when I put 15in wheels on it and bigger tires with a higher load rating. Not sure how I didn't blow a tire before!
  7. Jun 22, 2022 at 5:11 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    This is an issue I had to overcome last year. I have a pop up camper so there isn't much room to store things in there. I pretty much have it filled with the gear to set up a camp site and cook. I have a hard tonneau cover and load food clothes and fire wood in the bed so no room for my bike there.
    My camper has a 2" receiver on the rear bumper so I got a two bike platform rack that I use on the trailer and the truck at times.
    It works fine I took it on several trips some well over 100 miles each way and no issues..
    This is the rack I bought for 2 bikes but 4 bike platform racks are available.
    https://www.amazon.com/dp/B07GBPBW1T?ref=ppx_pop_mob_ap_share
    I see this 4 bike one is available
    https://www.amazon.com/dp/B00AK9YMIM
  8. Jun 22, 2022 at 6:46 PM
    wb_doublecab
    wb_doublecab Well-Known Member
    2020 ORLB
    What about BillieBars? Bed bars that work with bed covers. I purchased a set and added their rockymount locking fork mount and the rear tire Trays. Used them for a month and traded my truck in. I kept the bars but new taco has topper so may sell them. Screenshot_20220622-214531_Gallery.jpg
  9. Jun 22, 2022 at 6:52 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Put a Curt front end receiver and mount your bikes in front. You can also use it to push the trailer into tighter spots with sharper turns than you could by backing it in.
  10. Jun 22, 2022 at 6:58 PM
    OnHartung'sRoad
    By the way- we stayed at Fort
    Flagier State Park for our first night out of Seattle on our last long roadtrip. Right on the beach with good sea kayak access and nice bike trails for the kids, it was nice!
  11. Jun 25, 2022 at 10:03 AM
    pushgears
    pushgears Well-Known Member
    2021 OR DCSB MT
    D0DA18E7-9C10-4D32-A6B8-DC75230DAB72.jpg Even have room for a 17’ kayak
  12. Aug 13, 2022 at 5:52 PM
    Fox Mulder
    Fox Mulder Well-Known Member
    22 Army Green TRD Sport DCSB
    Not sure where you’re at, but I’m looking for some bed bars if you decide to sell.
    BasicPainter likes this.
