Biggest tire on TRD Pro wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GangPlank, Feb 14, 2016.
  1. Feb 14, 2016 at 9:10 PM
    GangPlank
    GangPlank [OP] Well-Known Member
    David
    2016 Tacoma TRD OR DCSB 6spd
    Does anyone know what the biggest tire you can run on the 4Runner TRD PRO wheels with a 3 inch lift or in the 3rd gen case a 2 inch lift.
    Biggest tire that won't rub with the wheels with 3inch lift?
    Anyone know if that wheel will clear 285/70/17 without rubbing with a lift?
    What is the offset of the trd wheel?
    Sorry if this has been answered already. I tried looking but couldn't find a direct answer. I see a lot of people running 265/70/17 but that's without a lift.
  2. Feb 14, 2016 at 9:17 PM
    uood8
    uood8 If You Search...You Shall Find.
    Greensboro, NC
    '16 Sr5 4x4 DCSB
    Pretty much stock
    270 70 17 is as far as I would push it
  3. Feb 14, 2016 at 9:19 PM
    sunshinetaco
    sunshinetaco Well-Known Member
    Ken
    CA
    2016 DCSB OR
    Can that fit on stock suspension?
  4. Feb 14, 2016 at 9:25 PM
    BeaverNation
    BeaverNation Well-Known Member
    ^^ yes. You can run certain 285/70/17 with minimal rubbing on stock suspension, depends on the tire and alignment.
    sunshinetaco likes this.
  5. Feb 14, 2016 at 10:24 PM
    littlechilds
    littlechilds skyhawk
    Cowtown
    16 trd sport Upgrade package DCLB
    KO2 tires, TRD pro rims. BP skid plate, Extang 2.0 cover, dipped grill and badges
    Just a heads up…I have the trd pro rims on 270/65/17's and literally 100% of the people here on this forum said it wouldnt rub. Well, mine rub every time i hit a bump on a 3/4 turn. I just hope it doesn't wear out my tires.
  6. Feb 14, 2016 at 10:29 PM
    GangPlank
    David
    Stock suspension?
  7. Feb 14, 2016 at 10:30 PM
    GangPlank
    David
    Will 285/70/17 ko2 tires rub on TRD pro wheels with a lift?
  8. Feb 14, 2016 at 10:40 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    The TRD Pro wheels are 17"x7", 285/70/17 KO2s should be mounted on wheels with a width of 7.5" to 9"
  9. Feb 14, 2016 at 11:25 PM
    GangPlank
    David
    I see makes sense. Thank you
  10. Feb 14, 2016 at 11:35 PM
    Rising Eagle
    Rising Eagle Well-Known Member
    Berkshires MA
    2020 DCSB OR
    I'm running TRD pro wheels with BFG KO2 285 70/r17's and Icon stage III 2" lift. No rub.
    When I put 1.5" spydertrax spacers on I got a little rub on the body mount. Tomorrow I'm going to get the alignment adjusted to positive caster by 1 or 2 degrees more. This should fix it but if it doesn't I'll have to get the cab mount chop (CMC). Hope that helps.
  11. Feb 14, 2016 at 11:47 PM
    sunshinetaco
    Ken
    CA
    2016 DCSB OR
    Nice truck :thumbsup:
    TWTaco and Rising Eagle[QUOTED] like this.
  12. Feb 15, 2016 at 12:03 AM
    GangPlank
    David
    So I guess you can mount 285s on the TRD pro wheels. Would they run a lot without the spacers? Looks like the best option to avoid spacers is different wheels or just stick to the 265 tire size.
    BTW nice truck. Looks great!
  13. Feb 15, 2016 at 12:07 AM
    sunshinetaco
    Ken
    CA
    2016 DCSB OR
    I believe the FN FX Pro wheels are similar to the 4Runner TRD Pro wheels and they are 17x8 instead of 17x7.
  14. Feb 15, 2016 at 12:09 AM
    GangPlank
    David
    Yea I've seen those. They look good also. Thanks. I think they also have the right offset so you don't need spacer which is a plus.
  15. Feb 15, 2016 at 12:10 AM
    Rising Eagle
    Berkshires MA
    2020 DCSB OR
    285's on TRDs is fine. Not sure what you mean by "run a lot"? If you get a different wheel with backspace equivalent to 1.5" spacers it might still rub with 285's.
    Thanks.
  16. Feb 15, 2016 at 12:13 AM
    GangPlank
    David
    Sorry I meant rub* All this offset stuff is new to me sorry.
  17. Feb 15, 2016 at 12:15 AM
    Rising Eagle
    Berkshires MA
    2020 DCSB OR
    Without spacers there is zero rubbing. I chose to put spacers on for a little wider and aggressive stance.
  18. Feb 15, 2016 at 12:19 AM
    GangPlank
    David
    I see. Thank you. I'm still deciding on what to do. So many choices hahaha
  19. Feb 15, 2016 at 8:30 AM
    Ericor
    Ericor Member
    British Columbia
    2016 Tacoma DCSB TRD Sport 6MT BBP
    Same here. Hits the top of the stock mudguard. Doesn't seem too hard, but I'll end up leveling with 5100s up front, which may fix it.
    littlechilds[QUOTED] likes this.
  20. Feb 15, 2016 at 9:42 AM
    hoarder23
    Shay
    NJ
    Scratches
    You can mount 285s on a 7" rim but every tire manufacturer out there recommends against it. I, for one, would trust the engineers at BF Goodrich or Goodyear before some dude on the internet. As @sunshinetaco said the FN FX Pro wheel is a great alternative, it's cheaper, comes with center caps, is wider, has multiple color options and the customer service form FN is amazing. At the end of the day you need to realize that everyone here has biases and just because someone has hundreds of posts that doesn't make them an expert.
    rubicon1968 and sunshinetaco like this.
