BFG KO2 alternatives?
Discussion in 'Wheels & Tires' started by Tacoma13_NC, Oct 27, 2023.
  1. Oct 27, 2023 at 1:14 AM
    Tacoma13_NC
    Tacoma13_NC [OP] Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; BFG KO2's (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT)
    Currently running a set of 265/70/17 KO2s on a set of 4Runner TRD Pro wheels. They're "ok" but looking to change it up a bit. I want to move up to a 285/70/17 tire and I like the look and weight of the Ridge Grapplers. I know the Wildpeaks get a lot of love on here but what other options are out there that are comparable to the mentioned three? I really like the look of the RGs and they seem to have a good all-around rating. The KO2s are not that great in rain which we get a fair amount of in NC. I'm lifted about 2.25" inches but don't have any CMC or other cutting done yet. Not sure what will be needed if any with those wheels. Thanks!
  2. Oct 27, 2023 at 3:27 AM
    23MGM
    23MGM Well-Known Member
    2023 TRD Off Road
    Super Swampers are an alternative, but probably not comparable with the superior traction they provide to the others.
    CT-Tacoma and BC Hunter like this.
  3. Oct 27, 2023 at 3:42 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
  4. Oct 27, 2023 at 3:46 AM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    Wild peaks.
    Tacoma13_NC[OP] and ID_IFD_3431 like this.
  5. Oct 27, 2023 at 5:54 AM
    BC Hunter
    BC Hunter Well-Known Member
    Kootenays, British Columbia
    2022 Black AC OR MT w/all TRD goodies
    TRD: Lift, Exhaust, Air Intake, Skid Plate & "Beadlock" wheels. Batman sticker. 255/85R16 Toyo MTs. Debadged. H9s.
    In that size, Nitto makes a "passenger" version (although the tire size doesn't include a "P") and, in the LT sizes, both a "C" and "E" rated version. The passenger version is only 48.74 lb (22.11 kg) Both LTs show as exactly the same weight (57.89 lb. or 26.26 kg) which seems counterintuitive.
    Which are you considering? If you aren't driving over sharp rocks, the lighter one might be your best option.
    Tacoma13_NC[OP] likes this.
  6. Oct 27, 2023 at 6:20 AM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    After going with bfg a/t's the last 35 years it was time for a change...
  7. Oct 27, 2023 at 6:21 AM
    ID_IFD_3431
    ID_IFD_3431 Well-Known Member
    2009 Access Cab 4WD
    +1 for wildpeaks
  8. Oct 27, 2023 at 8:30 AM
    Tacoma13_NC
    I was thinking about the P version since I don't really rock crawl. Light off-roading and dirt roads and trails is the extent of what where I go.
    BC Hunter[QUOTED] likes this.
  9. Oct 27, 2023 at 8:31 AM
    Tacoma13_NC
    I'll look into these. How do you like them following the BFGs?
  10. Oct 27, 2023 at 8:36 AM
    uhchxrlie
    uhchxrlie Well-Known Member
    2020 MGM Tacoma SR SX Package
    Do not have any interaction with the BFG's but I second the Toyo Open Country. I have 265/75/16 and they are awesome.
  11. Oct 27, 2023 at 8:36 AM
    Bishop84
    Bishop84 Well-Known Member
  12. Oct 27, 2023 at 8:44 AM
    S00TLYFE
    S00TLYFE Active Member
    Travis
    Anaheim, CA
    2010 Tacoma TRD
    not sure if they make them in your size, but i run Toyo R/T's on my Super Duty and they're great, not as noisy as you'd expect for the type of tread pattern, work well, etc.
    im on my second set of wildpeaks on my tacoma
  13. Oct 27, 2023 at 8:52 AM
    Tacoma13_NC
    ColoradoTJ likes this.
  14. Oct 27, 2023 at 8:57 AM
    OffroadToy
    Love the look and how they handle. The road noise is a hair more than the bfg's on highway but being a cross between a/t and m/t that was to be expected... around town there is no difference. Both the bfg's and these are e rated 10 ply.
    I have a 2" lift... even at 275/70/17 had to remove mud flaps and did some minor plastic trimming up front... clears cab mount by 1/2". I ending up trimming mud flaps/heat gun to bend under cab mount and shortened them.
    edit: these aren't 3 peak snow rated... so far not bad on snow but be careful on ice.
  15. Oct 27, 2023 at 9:09 AM
    ColoradoTJ
    ColoradoTJ Retired cat herder Moderator
    Colorado
    3500 Duramax, Roush Mustang, Jeep Crawler
  16. Oct 27, 2023 at 10:14 AM
    Tacoma13_NC
    Anybody have or has run the Mickey Thompson Baja Boss? They look like a solid option too.
    Island Cruiser likes this.
  17. Feb 23, 2024 at 3:21 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Replaced the factory tires and wheels on the Tacoma this week. I’ve been running BFG All Terrains on at least one vehicle for almost thirty years.
    I tried DuraTracs for a while and they wouldn’t stay balanced. Replaced those with KO2s
    Some think they are outdated and don’t perform well in rain. I’ve never been let down by them.
    4xdog and Tacoma13_NC[OP] like this.
  18. Feb 27, 2024 at 3:09 PM
    barch88
    barch88 Well-Known Member
    Michigan, USA
    2022 Tacoma SR utility package
    Toyo AT3
    finslayer83, Pista1 and Marty65 like this.
  19. Feb 27, 2024 at 3:34 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    My Gen 1 still has first-gen KOs.
    67k mi and about 35% of tread depth remaining.
    ColoradoTJ[QUOTED] likes this.
  20. Feb 27, 2024 at 3:57 PM
    Fordman777
    Fordman777 Member
    Phillip
    Boone, N.C. U.S.A
    2022 Tacoma TRD Sport 4x4 access cab army green
    K&N filter, TRD rims Nitto Ridge Grappler tires, old school metal oil filter housing
    I’ve got Ridge Grapplers on my Tacoma, they work great. My parent’s vehicles can’t make it up our driveway when it’s covered in snow, and mine does it with Ridge Grapplers no problem.
