BFG KO2 275/70/16
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wheelsag, Mar 2, 2020.
  1. Mar 2, 2020 at 12:26 PM
    wheelsag
    wheelsag [OP] Member
    2019 TRD PRO
    Anyone running these on their truck stock(no lift or leveling kit)? Pics of you are would be great. Have a 19 Pro and thinking about putting a set on and don’t want to change factory suspension.
  2. Mar 2, 2020 at 12:45 PM
    PuyallupJon
    PuyallupJon 2020 AG Pro
    Jon
    Puyallup, WA
    2020 Tacoma
    Never seen that size before.
    275/70 17?
  3. Mar 2, 2020 at 12:46 PM
    kherron
    kherron Well-Known Member
    Kevin
    Folsom, CA
    2020 Tacoma TRD Pro
  4. Mar 2, 2020 at 1:06 PM
    Lastplace
    Lastplace Well-Known Member
    Southeast VA
  5. Mar 2, 2020 at 1:23 PM
    6MTPro
    6MTPro Well-Known Member
    HI -> CA
    2018 TRD Pro 6MT | 2004 4Runner 4.7 V8
    Tune, 285/75/16, Diode Dynamics, PPF, Bakflip Mx4, Meso, Cali Raised, TJM
    I would get 265/75/16 before I got 275/70/16 especially on a Pro. If you're feeling a bit bolder you can go for 285/75/16.
    I currently have 265/75/16 on my Pro and like them but I am probably going up to 285's on the next go. It's too bad they dont make 275/75/16 because that would be a great size for the Tacoma's.
  6. Mar 12, 2020 at 11:38 AM
    Loco_Driver
    Loco_Driver Well-Known Member
    Connellsville, PA
    2018 TRD OR DCSB M/T
    Loco Driving Mode
    How much of a difference in gas mileage/ handling did you notice switching to the 75’s vs the stock 265 70 16s?
    im about to get some KO2s and the price is way less per tire going with the 75s...
  7. Mar 12, 2020 at 11:46 AM
    1992SR5V6
    1992SR5V6 Well-Known Member
    2018 TRD Sport 4x4 Cement
    Bolt on only...
    They are priced a lot higher than 265/75R16's.
    BFG KO2's 275/70R16 $234
    GY UltraTerrain AT's 265/75R16 $167
  8. Mar 12, 2020 at 11:53 AM
    Sippi
    Sippi Well-Known Member
    Boca Raton, Fl
    El Taco Negro - 2017 Sport DC 4x4 6MT
    OVTune 2.0 TC Electronic BHLM 4R Sema with Nitto G2s Swing Case OEM Goodies Pro Items
    Tire Kingdom has the BFG KO2's 265/70R16 for 200 before fees
  9. Mar 12, 2020 at 11:54 AM
    Edf339
    Edf339 Member
    Edmonton AB
    2020 TACO TRD PRO MANUAL
    Not really a good info since I just installed my KO2 265/75R16 , e rated, on my 2020 trd pro manual( 2100 kms on it) last week but here is the number for a week.
    Avg is around 15.5 mpg, 70/30 city/hwy
  10. Mar 12, 2020 at 12:30 PM
    6MTPro
    HI -> CA
    Negligible. A lot of the perceived difference is from your speedometer being slightly off from the larger tire. Also comes down to Gas type, PSI, etc. and all kinds of stuff.
  11. Mar 12, 2020 at 12:35 PM
    NinjaxBart
    NinjaxBart Well-Known Member
    Spencer
    2020 Tacoma Off-Road DCSB Cement
    Following
  12. Mar 12, 2020 at 12:36 PM
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    275/70-16 is a shorter tire than 265/75-16 unless skills have severely eroded over the years.
    Why would you want to run a tire only 0.5" taller than OEM but wider over a 1" taller tire that's the same width as OEM? I would think unless you spend a lot of time in the sand that you'd want the extra height over the width, and as stated before, the 275/70 is a much pricier tire than the 265/75 option.
    MBC808 likes this.
  13. Jun 16, 2020 at 12:22 AM
    MBC808
    MBC808 Member
    TRD PRO AG Tacoma
    I’m in the same boat here. Are u gonna lift your truck to get the 285s on your pro? I still have stock tires and deep in the rabbit hole of deciding/researching.
  14. Jun 19, 2020 at 10:37 AM
    6MTPro
    HI -> CA
    I think with the additional stock height and wheel offsets the pro is probably okay to puts 285's. The lift would probably provide peace of mind. I would do that before I started doing CMC or any heat gun work.
    MBC808[QUOTED] likes this.
