BFG KM2 (Mud Tire) 80 PSI?? WTF?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOYOTA 09, Dec 7, 2020.
  1. Dec 7, 2020 at 1:03 PM
    TOYOTA 09
    TOYOTA 09 [OP] Kicking Ass Since 1981
    Maine
    2009 SR5 MT 4x4 Access Cab
    Preview 2009 SR5 4x4 MT Black Sand Pearl (Access Cab) SUSPENSION ToyTec 5100 Billstein Coil Overs (3" Lift) Fox 2.0 Remote Res Rear Shocks Total Chaos UCAs Full Dakar Leaf Pack w/Extra AAL TIRES & WHEELS BFG AT KOs 265/75/16 load range E American Rancing AR-23 Wheels Borla CAT back exhaust AFE cold air intake w/custom TRD clear cover Satoshi grill w/Grill Craft insert Hella 500 behind grill lights Rigid Industries Backup lights Interior Custom LEDs and Bed Lights Backup Cam Anytime MOD Leather armrest and rear seat MOD Weathertech floor liners Custom rear gear/dog platform Cobra CB and Garmin GPS Bed Mat UWS low pro tool box with Custom LED lights Diff breather MOD Custom painted engine cover Wet Okole seat covers
    I've had a set of BFG Mud tires on my truck the past three years...always aired them to 32 PSI. My buddy and i were driving today in the truck and the TPMS came on. We stopped for air and he said I was wrong for running 32 PSI since the sidewall of the tires suggested 80 PSI when cold....what is everyones thought on this. I just aired them up to 60 to see if i could notice a difference....
    Aardvark13 likes this.
  2. Dec 7, 2020 at 1:08 PM
    ImMrCrash
    ImMrCrash Intermittent Error
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    Bilstein 5100’s Dakar CS047R Supreme Suspension U-Bolt flip kit Sumo Springs Blue ADV Fiberglass Fenders 1st Gen Snorkel DV8 Apex Plate Bumper X-Bull 13k Winch KC HiLiTES 6x9 Trail-Gear Sliders 4x Innovations LCA Skids Spidertrax 1.25” Eagle Alloy 16x8 4” BS Fierce Attitude M/T 315/75R16 Bearcat 980SSB CB
    That’s just the max pressure of the tire.
    Your required tire pressure is based on the weight of the vehicle and load on the tire. Best bet is to follow the recommendation on the door jamb or do a chalk test.
  3. Dec 7, 2020 at 1:08 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    HELL no lol! You’re not driving a full-size mega cab 10ft bed towing a trailer of sumo wrestlers lol
  4. Dec 7, 2020 at 1:10 PM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    :rofl::rofl::rofl:
  5. Dec 7, 2020 at 1:10 PM
    Loco_Driver
    Loco_Driver Well-Known Member
    Connellsville, PA
    2018 TRD OR DCSB M/T
    Loco Driving Mode
    I do 35 PSI. If i'm towing I put the rear to 40-44 PSI depending on the tongue weight.
    smw62891 and boston23 like this.
  6. Dec 7, 2020 at 1:15 PM
    Aardvark13
    Aardvark13 Sultan of Squeeze, Wizzard of Slide
    Byl
    Knoxville
    2014 DCSB OR
    Aardvark4x4 Built for Go
    It says 'At max load of 3195lbs per tire, 80 PSI'. If your Taco is sitting at 12,800lbs, then maybe yes.. :) I ran these on my full size ford at 50PSI, on a Taco, I wouldn't go over 40 unless loaded for expedition.. I run mine at 34-36 as I'm a little heavy..
    ImMrCrash, smw62891 and Thatbassguy like this.
  7. Dec 7, 2020 at 1:17 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Pump those suckers to 80 bro :bananadance:
  8. Dec 7, 2020 at 1:18 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    As said above. Chalk test or just follow the door pressure. Your tires are an important part of your suspension system.
    It's not a bicycle tire or trailer tire that you run at max pressure.
  9. Dec 7, 2020 at 1:21 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    If they are LT tires, they should be inflated higher than the stock SL tires.
  10. Dec 7, 2020 at 1:21 PM
    CalcityRenegade
    CalcityRenegade Well-Known Member
    Calgary, Alberta, Canada, Earth
    2023 T4R ORP KDSS
    I got excited thinking it was Friday already...
    ImMrCrash, Aardvark13 and Thatbassguy like this.
  11. Dec 7, 2020 at 1:29 PM
    TOYOTA 09
    Maine
    thank you guys! Ill go back to 32 PSI!
    Island Cruiser and ImMrCrash like this.
  12. Dec 7, 2020 at 1:31 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    E rated tires are designed to be used on heavy duty trucks with curb weights 1000-1500 lbs more than the GVWR of a Tacoma. Guys who drive 3/4 and 1 ton trucks only run 50-60 PSI when unloaded. And that is with an empty 7000 lb truck. They only air up to 80 PSI when loaded and have 10,000 lbs or more on the tires. Driving a Tacoma @ 80 PSI is insane, even dangerous. The wheels on light duty trucks are only designed to stay together at 60-65 PSI. The wheels on heavy duty trucks are designed for those pressures, not Tacoma's.
    I run 30-32 PSI with E rated tires on my Tacoma and that is more than enough even when loaded heavy. I run about 35 PSI on my F150 with E rated tires. No need for more with the weight of those trucks and the GVWR's.
    Island Cruiser likes this.
  13. Dec 7, 2020 at 1:34 PM
    ImMrCrash
    Utah
    07 DCSB ᴛʀᴅ ᴏʀ 4x4
    While you’re at it you should ask your buddy how many miles his tires last before the center of his tread is gone.
    And then ignore any future automotive recommendations he throws at you
    :smack:
  14. Dec 7, 2020 at 1:43 PM
    Island Cruiser
    Kauai
    Baja
    His buddy won’t be able to answer by the lack of filling in his teeth from driving around in 80psi lol
