BFG All-Terrain T/A® KO2 Size??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tacolover406, Nov 17, 2020.
  1. Nov 17, 2020 at 12:06 PM
    tacolover406
    tacolover406 [OP] New Member
    Hi! I have a 2017 Tacoma Off-Road with stock tires (265/70R/16). I want to purchase a new set of BFG all-terrian K02 tires for it. Everything I've read on the tires it sounds like I need to stick with C load. I was looking at getting the 265/70R/17 C load but want to make sure they fit.
    Anyone have recommendations on what size? Thanks!
    Thatbassguy likes this.
  2. Nov 17, 2020 at 12:10 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    17 inch tires wont fit on your 16 inch rims
  3. Nov 17, 2020 at 12:12 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    A 265/75/16 will be the same basic size as a 265/70/17, but I think KO2's are only available in load D or E in that size. There are probably other tires offered in load range C or even SL if you're looking to keep it light.
    tacolover406[OP] likes this.
  4. Nov 17, 2020 at 12:41 PM
    tacolover406
    Should I go with the E load in that size then?
  5. Nov 17, 2020 at 12:45 PM
    th3118
    th3118 Well-Known Member
    Mesa, AZ
    2016 Quicksand TRD Offroad
    Are you buying new wheels?
  6. Nov 17, 2020 at 12:48 PM
    th3118
    Mesa, AZ
    Then don’t buy
    17” tires!
  7. Nov 17, 2020 at 1:02 PM
    benzy
    benzy Well-Known Member
    Bay Area, CA
    2006 DCSB TRD OR
    Simple OME/884/AAL lift. 32” WP’s
    You will take a hit to mpg for sure. If you drive in harsher off road conditions they are worth it. The side walls are very durable and you can air them down pretty low with confidence.[/QUOTE]
  8. Nov 17, 2020 at 1:32 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    If you value on road ride comfort, E load are not advisable. You can air them down to help, but that further hurts mpg and makes handling feel mushy. They are a good all around A/T tire, otherwise. Good road manners. Mediocre in the snow in my experience, though.
  9. Nov 17, 2020 at 1:41 PM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    I have 265/75/16 on stock rims with ko2 E rated. The ride is def stiffer but the tires are great. I never worry about sidewall punctures. They are a workhorse tire. Depends how you use your truck
    Hooper89 likes this.
  10. Nov 17, 2020 at 1:48 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    I would stick with SL and more tame tread pattern unless you like road noise and lower mpg. Some of the aggressive tires can be scary on the freeway in the rain/snow too.
    E rated in smaller trucks is more for offroading over rocks etc to lower the odds of a flat.
  11. Nov 17, 2020 at 2:54 PM
    PuckerbuttPliny
    PuckerbuttPliny Well-Known Member
    California
    2018 TRDOR 4X4 DCLB
    275/70r17 KO2 E Load 4R TRD Pro Rims
    What are you looking for?
    Comfort? - SL tire
    Durable / less comfortable - C Load
    Most Durable / least comfortable -E Load.
    I myself have ko2’s in a E load (275/70r17), and can attest that I still have all my fillings in my teeth, contrary to what TW will lead you to believe. Just cause it’s stiff, doesn’t mean it’s a crap ride... just means it’s going to not soak up expansion joints as well. What it will do though, is give you more peace of mind when the rocks get sharper, and you get further away from people.
    Oh, and yes MPG will take a hit, I think I max out when doing 100% highway at 17-18mpg.
  12. Nov 17, 2020 at 2:56 PM
    th3118
    Mesa, AZ
    A lot of people here like Falken Wildpeak AT3. Great tire, less expensive.
    265/75-16 is a inch bigger and will fit fine. I love mine.
    krupnation likes this.
  13. Nov 17, 2020 at 3:24 PM
    krupnation
    krupnation Active Member
    100 series Land Cruiser
    Second this statement. I've had the Wildpeaks in 265/75-16 on my OR since Sept and they've performed great so far. They're much lighter than the KO2's in the same size (E-rated), I think 13 lbs lighter per tire if I remember...
