BFG 315/70R17 KO2 Measured Size and BS
Discussion in 'Wheels & Tires' started by Glenn_R, Dec 6, 2017.
  1. Dec 6, 2017 at 10:16 AM
    Glenn_R
    Glenn_R [OP] The Unicorn Turd Gen
    Glenn
    17 Tacoma DCSB OR Inferno
    Looking for someone that has this tire mounted and on truck (can be the load C or E). What is the vertical height of the tire? If you can would like tire pressure and rim width. Yes I know what tiresize.com and BFG has posted. BFGs just seem to always run small.
    Glenn
    90yota likes this.
  2. Dec 6, 2017 at 10:18 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    Indicated size on the mfr website will never match an installed measurement.
    Jerry311SD likes this.
  3. Dec 6, 2017 at 10:25 AM
    Glenn_R
    Glenn
    Yep, that is why I am asking.
  4. Dec 6, 2017 at 10:27 AM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    They are smaller.....you know you’re gonna have to cut, right?
  5. Dec 6, 2017 at 10:28 AM
    Glenn_R
    Glenn
    Cut, chop, heat, and bang is what I think will be needed.
  6. Dec 6, 2017 at 7:47 PM
    Glenn_R
    Glenn
    Found this thread on Wayalife that has many actual measured tire sizes. It looks like that tire is only 1" taller than my 34X10.5R17 KO2s.
  7. Dec 6, 2017 at 7:47 PM
    anthony250f
    Anthony
    San Diego, CA
    Ok? Just curious why do you need to know the exact sizing ?
  8. Dec 6, 2017 at 7:55 PM
    Glenn_R
    Glenn
    So I know what cutting, ponding and such I need to do, also is it even worth doing all this for 1" of total height or 1/2 more ground clearance.
    Edit: and OCD
  9. Dec 6, 2017 at 8:09 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Every truck is different. It's highly dependant on your alignment. Best thing to do is put them on, try and compress the suspension ( even better take the coilovers out all together) turn the wheel and see what needs cutting. Repeat until you clear at full lock both ways and full stuff
  10. Dec 6, 2017 at 8:16 PM
    Glenn_R
    Glenn
    This I understand, but I like to do some panning and mocking up before I spend $1K on tires. I have 34"s now and with the way I have my alignment set up (SPC UCAs) I only rub on the back of the front fender. And that is from full stuff to fully extended.
  11. Dec 6, 2017 at 8:47 PM
    anthony250f
    Anthony
    San Diego, CA
    So this is just for looks? No it’s not worth it. If you are actually gonna use 35s then ok
    You have to cut the fenders and the flares too...cut the shit out of the cab mount. Puns the firewall with a sledge.
  12. Dec 6, 2017 at 8:52 PM
    Glenn_R
    Glenn
    Who said anything about looks? I want more ground clearance, I want to be able to run level 8 trails with confidence. My truck actually is used off road. If you don't have these tires or know the measurement of them mounted please move on.
    Island Cruiser and ztaragon like this.
  13. Dec 6, 2017 at 9:08 PM
    anthony250f
    Anthony
    San Diego, CA
    I have had those tires before and yes they do run smaller. I have 315/70/17 hankooks and they are fiarly small too...quite a bit smaller than my buddies MTR tires. If you don’t mind cutting and all that then just get the tires and cut whatever is needed.
    Pretty sure my current tires are hardly over 34” mounted
  14. Dec 7, 2017 at 5:25 AM
    Glenn_R
    Glenn
    I find it crazy they are so small measured. The 34X10.5R17 KO2s I have measure 32.8" and it looks like the 315/70R17 KO2s are about 33.4" I was hoping for a gain of more ground clearance going to the 315/70. I wish someone made a 35X11.5.
  15. Dec 7, 2017 at 7:21 AM
    anthony250f
    Anthony
    San Diego, CA
    Even though they measure smaller they still look much larger than 33 or 35s.
  16. Dec 7, 2017 at 8:11 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    You're talking about 1/10ths of an inch. Literally splitting hairs.
  17. Dec 7, 2017 at 9:37 AM
    Glenn_R
    Glenn
    Yep
  18. Dec 7, 2017 at 9:52 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    I can try to get these numbers this weekend after I get my KO2 315s on. Are you pretty close on yours with full cycle? My CMC is to the point where I barely have any outside area around the cab mount left before it got boxed.
    90yota likes this.
  19. Dec 7, 2017 at 12:53 PM
    Glenn_R
    Glenn
    Coot, I have not done the CMC for the 34s and have about 1/4 clearance at the cab mount. I do rub on the front of the fender with my current alignment. I think I can fit the 35s with the CMC, smashing over the seam and removing the inner fender liner or heating to reshape. The 315 is much wider than it is taller than what I have now. Would really like the measurements after you mount those new tires.
  20. Dec 7, 2017 at 12:59 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Will do man, you may want to look into a CMC...with dirtys I bet you rub unless you got a 6 inch DB lift.
    90yota likes this.
