BF goodrich all terrain ta ko2
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dftacoma17, Aug 17, 2020.
  1. Aug 17, 2020 at 3:25 PM
    Dftacoma17
    Dftacoma17 [OP] Member
    2017 Tacoma SR5 4x4
    Has anyone else experienced that these tires ride pretty rough? Cause I'm question the dealership ability to balance the tires. Just got new 265/75/16 bfgoodrich all terrain ta ko2 and there riding rough.
  2. Aug 17, 2020 at 3:33 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Did you get E load?
  3. Aug 17, 2020 at 3:44 PM
    Dftacoma17
    2017 Tacoma SR5 4x4
    Yeah.
    Junkhead likes this.
  4. Aug 17, 2020 at 3:45 PM
    BalutTaco
    BalutTaco Moja_Przygoda
    2019 Cement Limo Trail Edition -> 2022 Magnetic Grey OR
    Bird nest engine bay.
    They ride fine to me. over 10k miles what PSI? I'm usually around 30-35
  5. Aug 17, 2020 at 3:47 PM
    Dftacoma17
    2017 Tacoma SR5 4x4
    There around 38 cold heated up around 40-41
  6. Aug 17, 2020 at 3:48 PM
    BalutTaco
    Maybe drop it, But I also had bilstein 4600s OR model trim. What suspension does the SR5 come with?
  7. Aug 17, 2020 at 3:48 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    That's too high for an E-load. Hell, thats too high for a C-load, unless you have a shit ton of aftermarket weight.
    KO2s are notorious for being a PITA to balance.
    Rockefelluh and Garyji like this.
  8. Aug 17, 2020 at 3:48 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    That's why.
  9. Aug 17, 2020 at 3:50 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    That will do it. No problems with balancing over here. Im getting C load next week.
  10. Aug 17, 2020 at 3:52 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    If you use the LT tire air pressure calculator, your e loads should be 37 cold. Google it.
  11. Aug 17, 2020 at 3:52 PM
    Dftacoma17
    2017 Tacoma SR5 4x4
    Guess I'll just have to ride these out literally!
  12. Aug 17, 2020 at 3:53 PM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    I did not really have any issues with them but depending on your weight and such like others mentioned. If you have a fairly stock struck thats way to high. They are going to be much stiffer than any C rated or stock tire. Most people outside of the mall crawl believe in the tougher sidewalls on some tires that actually have 10 ply. Some E rated are actually closer to D rated and have less.
    What size tire do you have and what does the rest of your truck look like? that would help us here.
  13. Aug 17, 2020 at 3:55 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Actually LT tires require more psi than SL to support the same weight. For example, stock size SL can be 29-30. If you go E load stock size, you will need 37 psi to support the same weight. You can check out LT tire air pressure calculator.
    Bertw192[QUOTED] likes this.
  14. Aug 17, 2020 at 3:56 PM
    BalutTaco
    Damn really? Been riding low PSI for a good min!! HAHAHA
    Rockefelluh and Junkhead[QUOTED] like this.
  15. Aug 17, 2020 at 3:57 PM
    Dftacoma17
    2017 Tacoma SR5 4x4
    265/75/16 and it's all stock.
  16. Aug 17, 2020 at 3:59 PM
    nudavinci64
    Robert
    The link @Mrtacoman88 posted is great. Take out the guess work and do the chalk test. That wil tell you where to put it. Last time I did that my front and rear are different based on where the weight sits.
    Also if plan to keep it stock I would recommend looking into C-Rated your MPGs will thank you.
  17. Aug 17, 2020 at 3:59 PM
    Dftacoma17
    2017 Tacoma SR5 4x4
    So if Idrop the air to 35 psi should ride a little smoother?
  18. Aug 17, 2020 at 3:59 PM
    Bertw192
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    I trust ya! Thank you for correcting my misinformation. Seems counter intuitive.
    nudavinci64 and Junkhead[QUOTED] like this.
  19. Aug 17, 2020 at 3:59 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Same here, i just learned about all this couple months ago, thanks to @splitbolt . Been running door jamb psi on my previous truck and my taco with e loads
  20. Aug 17, 2020 at 4:01 PM
    nudavinci64
    Robert
    I run higher on my E-Rated but the truck is HAF. Chalk test will take the guess work out.
    Junkhead[QUOTED] likes this.
