Beware of Bosal exhaust replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bren, Mar 22, 2014.
  1. Mar 22, 2014 at 8:48 PM
    Bren
    Bren [OP] Well-Known Member
    CT
    01 Tacoma SR5 V6
    I recently replaced my rusty exhaust with a bosal system. I didn't want to spend a lot of money, so i went with the Bosal because it was the cheapest(115 shipped). The fitment was fine and the only problem I had was that the Bosal gasket was way too small and I had to go get one from Toyota. Now, the reason why I hate it. It makes a terrible humming noise any time you accelerate and it's alot louder than stock. It's terrible when your driving on the highway, it's a constant droning hum. It's comparable to when someone runs their finger on the edge of a wine glass. Do yourself a favor and invest in a better quality exhaust.
  2. Mar 22, 2014 at 8:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    it takes time to break in. After a couple hundred miles, it should be better.
  3. Mar 22, 2014 at 9:10 PM
    Bren
    CT
    01 Tacoma SR5 V6
    I have 600 miles on the new exhaust and no change. I hope your right and it will break in. I have read about others having the same problem with the bosal exhaust.
  4. Mar 24, 2014 at 8:36 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    I would of just replaced with an OEM exhaust for the same price
  5. Mar 24, 2014 at 8:50 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
  6. Mar 24, 2014 at 3:32 PM
    jdkilroy
    jdkilroy Well-Known Member
    Jon
    Southern NH
    '02 4x4 SR5 Access Cab
    Break-in periods are very common for an exhaust system. The tone of a system can completely change from 0 miles to 1500 miles.
  7. Mar 24, 2014 at 7:37 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    you get what you pay for.
  8. Mar 25, 2014 at 2:48 PM
    Bren
    CT
    01 Tacoma SR5 V6
    OEM cost a lot more than the Bosal.
  9. Mar 25, 2014 at 2:51 PM
    Bren
    CT
    01 Tacoma SR5 V6
    Yea, that definitely applies. If I had the money, I would of bought OEM or at least a better quality brand. Although, I did replace my Versa's muffler with bosal and have no problems, just as quiet as stock. It must just be specific to the Tacoma.
  10. Mar 25, 2014 at 3:15 PM
    Yamaha Dave
    I got my OEM stock Tacoma exhaust for $50 used. :confused:
  11. Mar 25, 2014 at 8:00 PM
    Bren
    CT
    01 Tacoma SR5 V6
    I really didn't want to put a used exhaust on. I wanted a brand new one, so I could coat it and maximize longevity. Also, even if I wanted to buy used, I was really pressed for time. Two of the hangers were completely broken and I didn't want to risk it falling off while driving.
