Better gas mileage with different octane?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wasatchute, Feb 1, 2018.
  1. Feb 1, 2018 at 6:14 PM
    wasatchute
    wasatchute [OP] New Member
    Mark
    Utah
    Hey Everyone,
    New to TacomaWorld. Traded in my Wrangler and bought a 2017 OR AC late November and could not be happier. A buddy of mine referred me to the site and it is AWESOME! Question for you all...have been filling up with 88 octane first 3 fill-ups was averaging 18 - 18.5 mpg. Recently filled up at a new station with 87 octane and my mpg went up a whole gallon to 19.5. This is mainly city driving on fairly flat roads with the occasional freeway run. The truck only has 1100 miles on it. I drive it every day but, really only back and forth to work and around town(camping/flyfishing season has yet to begin). Wondering if the octane made any difference or if the truck is just "breaking in". Thanks, and glad I was turned on to the forum. Cheers.
  2. Feb 1, 2018 at 6:16 PM
    kurt1305
    kurt1305 Active Member
    Texas
    2018 TRD Off Road 4x4
    My mileage varies more based on the amount of ethanol.
  3. Feb 1, 2018 at 6:17 PM
    eurowner
    eurowner Duke Sky
    Scoty
    87 vs 91 in Colorado I see no difference in mpg.
    Jerry311SD, tonered and xxTacocaTxx like this.
  4. Feb 1, 2018 at 6:18 PM
    nat103
    nat103 Well-Known Member
    KY
    2017 DCSB OR
    I seem to get a little bit better mileage with premium
    trdmikey8 likes this.
  5. Feb 1, 2018 at 6:18 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Here we go again.
    Toyota says to use 87. Just use 87.
    Winter gas blends suck.
  6. Feb 1, 2018 at 6:19 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    The real question is: Is premium Ethanol free where you are? That might make a difference.
    shakerhood likes this.
  7. Feb 1, 2018 at 6:22 PM
    nat103
    KY
    2017 DCSB OR
    Both premium and regular ethanol free
  8. Feb 1, 2018 at 6:23 PM
    t4daddy
    t4daddy Well-Known Member
    North Alabama
    2008 PreRunner Double Cab
    It went up a whole gallon? You surely meant it went up a whole mile per gallon? One mile per gallon is basically zero change IMO. You simply cannot and will not replicate the exact same driving conditions every day. You need a bigger/longer experiment.
    cshrum and Kyitty like this.
  9. Feb 1, 2018 at 6:26 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    See Build Page
    You're a lucky son of a bitch then.
    pltommyo, 02Duck and shakerhood like this.
  10. Feb 1, 2018 at 6:27 PM
    ChrisK7UND
    ChrisK7UND Well-Known Member
    Colorado
    2017 Tacoma TRD Sport Double-Cab
    LED Interior Bulbs, Hondo Garage Phone Mount, Tacoma Bed Mat
    I use ethanol free here in Colorado. It’s 87 octane I believe. Runs great on good ol gas.
  11. Feb 1, 2018 at 6:30 PM
    wasatchute
    Mark
    Utah
    Yes, I meant a whole mile per gallon. I agree, I will continue to observe and see what happens. Thanks for the responses and being kind to the noob.
  12. Feb 1, 2018 at 6:36 PM
    su.b.rat
    su.b.rat broken truck
    over in the MT's new truck mileage often starts with under 15mpg and goes up to the higher teens or even 20's within a few thousand miles. on the same gas.
  13. Feb 1, 2018 at 6:38 PM
    ElGatoLoco
    ElGatoLoco Well-Known Member
    '17 DCSB TRD Sport
    I get the same 87 or 91 so I stick with 87 now
  14. Feb 1, 2018 at 6:41 PM
    Yota_Explorer
    Yota_Explorer Well-Known Member
    San Diego
    2015 Tacoma TRD Off-road
    Regular gas done waste your money
  15. Feb 1, 2018 at 6:46 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Octane rating makes absolutely no difference in mpg. Higher octane is all about resistance to engine knock during fuel detonation.
    With that said...
    If you consistently run a higher octane fuel, your timing will adjust accordingly over a period of time. Because of the change, you will have a bit more horsepower at wot. Probably not enough to notice but it will be a bit more.
    As far as efficiency though? That is a nope.
    You had a coincidence happen. Nothing more.
  16. Feb 1, 2018 at 6:50 PM
    wasatchute
    Mark
    Utah
    Answer I was looking for. Thanks.
    hiPSI likes this.
  17. Feb 1, 2018 at 6:50 PM
    DrVonEvilSatan
    DrVonEvilSatan Well-Known Member
    Toyota Truck
    The only thing that changes your mileage will be the available energy in the fuel. What I mean by that is basically ethanol content in traditional pump gas. Some engines take advantage of the additional fuel stability of premium and change engine parameters, most don't. The Tacoma's engine doesn't
  18. Feb 1, 2018 at 7:10 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    I use ethanol free only. Get an extra 1-2mpg vs when I used to use the normal blend up to 10%. Costs about $3.00/gallon these days. Race trac is 87, wawa is 89, marathon is 90.
  19. Feb 1, 2018 at 7:13 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I tried two tanks of 92 and lost some MPGs. Back on 87 and feeling good.
  20. Feb 1, 2018 at 7:27 PM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    I run 93 in my truck for this reason. When I first got my truck 12/16, I used 93 as I was babying my truck, switched after a while to 87 and ran that for 5 months or so. I then switched back for the last 5 months to 93 and while I don't notice any more power or better MPG (I have gotten my best and worst tank AVG on 93, consecutive tanks too.), I do notice that my truck does not do the low RPM chugging on 93. I buy 93 because my truck just hums along better with it.
    go2cnavy and hiPSI[QUOTED] like this.
