Best way to remove this clip?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by disel_V1, Oct 3, 2022.
  1. Oct 3, 2022 at 12:46 PM
    disel_V1
    disel_V1 [OP] I eat cold pizza rolls
    3rd Gen
    few things here and there.
    Hey y’all.
    I am about to replace my inner wheel liner’s and need help figuring out the best way to remove this clip. Looks like if I push down it’ll pop out, but knowing me… I’ll break something, so I’m looking to you for help!
    anyone know the best way to tackle these? Thanks
  2. Oct 3, 2022 at 1:00 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    A door panel removal tool should get it out.
    TexasWhiteIce likes this.
  3. Oct 3, 2022 at 1:01 PM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    use a flathead and pop out the center piece
  4. Oct 3, 2022 at 1:15 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    ^No center piece in those, just a hole that accepts self-tapping screws (like those holding mudflaps).
    Those clips are designed with a weak flange relative to the barbs holding it in. If you don't have access to the back side, plan on the the clip being destroyed (i.e. buy a few spares before you tear into it).
    musicisevil likes this.
  5. Oct 3, 2022 at 1:17 PM
    disel_V1
    3rd Gen
    Damn. Sounds good tho. So, just pry it out with a flathead and call it a day? So, should I use the flathead in the middle or use a clip removal tool?
  6. Oct 3, 2022 at 1:19 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^You'll need a combination of clip removal tool and pliers (small vise grips or Knipex-style pliers wrench). Screwdriver won't do jack all.
  7. Oct 3, 2022 at 3:15 PM
    Smacky2020
    Smacky2020 Well-Known Member
    Bristol, VA
    2020 TRD ORDC - Cement
    Stock wheels and suspension. Random "utilitarian" mods featured on this great forum.
    mtip, The Mink and tstack22 like this.
  8. Oct 3, 2022 at 3:26 PM
    disel_V1
    3rd Gen
    Awesome! Just got some. So.. if I break it in the front, can I push it out from behind? I don’t guess I’ll be able to get to it from behind. I’m just gonna tackle it (truck on ground) in my driveway.
  9. Oct 3, 2022 at 5:29 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    If you break the round flange, you push in the remainder. Some of the broken pieces will be accessible, some will not (they'd roll under the battery tray or the fuse box). Being plastic, loose pieces won't do any harm.
  10. Oct 3, 2022 at 7:08 PM
    disel_V1
    3rd Gen
    Blows my mind that they make these little clips so hard to access. I don’t really know another way to get to them from behind. May end up trying to pry, or maybe use a little drill bit and drill up the middle?
  11. Oct 3, 2022 at 7:26 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^You're overthinking this. Just do the best you can with a clip remover tool, rip out whatever's remaining with vise grips. Anything left after that can be pushed into the body to clear the hole. Don't use a drill.
  12. Oct 3, 2022 at 7:39 PM
    disel_V1
    3rd Gen
    You’re absolutely right. Just going to do what you’re suggesting and I’m sure it’ll be fine.
