Best way to remove Tailgate insert
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dawgs1125mbsr, Mar 1, 2023.
  1. Mar 1, 2023 at 9:57 AM
    Dawgs1125mbsr
    Dawgs1125mbsr [OP] Well-Known Member
    Bought these off Amazon 3 yrs ago. Damn things are fading and paint coming off. They’re the 3D actual letters and not stickers . Best way to remove without screwing the paint up? Thanks
  2. Mar 1, 2023 at 9:58 AM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    Heat gun or blow dryer to warm up the adhesive, then peel off. Don't go too hard with the heat though if using a gun.
    DaBigDogg and TacoTime55 like this.
  3. Mar 1, 2023 at 10:03 AM
    Martian__
    Martian__ Well-Known Member
    Southern California
    You can use a heat gun or a steamer to warm up the adhesive. Then use fishing line to get behind the emblem and cut through the adhesive to pull the emblem off. Just rub the remaining adhesive off after that.
  4. Mar 1, 2023 at 10:09 AM
    jeffmansion
    jeffmansion Well-Known Member
    16UTILITY4x4MT2.7
    K&N 63 series CAI, AVS Vent Visors, 16x8 Level 8 MK6 Rims, 285/75/16 MT, Eibach Pro lift, JBA UCAs, Wheelers 3leaf AAL, DV8 skidplate, Westin bedmat, Backrack, swaybar delete, Magnaflow cat-back, 9Drive throttle controller, 2LO Mod, Cali Raised Rock Sliders, Tyger rear bumper, Chinese Body Armor front bumper clone, 10K pound Winch, Smoked headlights, LED Bulbs.
    i would avoid heat gun personally... too risky with your paint there, can easily get too hot and damage paints. i will stick to my trusty ol hair dryer moving forward for most of this type of work.
    vaca likes this.
  5. Mar 1, 2023 at 6:58 PM
    starman202
    starman202 Well-Known Member
    Heat gun (or leave car parked outside during warmer days for a couple of hours) and fishing line
  6. Mar 1, 2023 at 7:49 PM
    Dawgs1125mbsr
    Thanks. What type or thickness of fishing line? Does it matter
  7. Mar 2, 2023 at 4:33 AM
    jeffmansion
    16UTILITY4x4MT2.7
    Doesnt matter, if you have some old line on hand give it a try. I just used old cheap line.
  8. Mar 2, 2023 at 6:26 AM
    jakbakcrak
    jakbakcrak Well-Known Member
    Jack
    2020 Quicksand TRD Off Road Tacoma
    Several aesthetic
    Ditto hair dryer and fishing line..! Worked for me
  9. Mar 2, 2023 at 6:28 AM
    tacoWithstickyrice
    tacoWithstickyrice Well-Known Member
    '19 DCSB TRD OffRoad 4x4
    I had the same issue where the "anodizing/paint" began to peel off. I plasti-dipped mine...
  10. Mar 2, 2023 at 6:31 AM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    10 lb hi vis braid with a 4 lb monofilament leader
    kidding, use whatever you have; mono, fleuro, braid, dental floss, etc. Heat is important though to soften the adhesive up, but not too much.
    if you don't plan on reusing them/don't care about damage, you could always try some plastic (not a metal flathead screwdriver please) trim removal type tool and prying (maybe against a microfiber towel or something to not scratch your paint). Next question will be how to get rid of the remaining adhesive; something like goo-gone, but go back and wash the area thoroughly and put some sort of protective layer back on it.
  11. Mar 2, 2023 at 7:19 AM
    Silver-Taco1
    Silver-Taco1 Well-Known Member
    Those letters are the nasty metal ones that corrode, right? I read reviews that they turn to shit after a couple years or less.
  12. Mar 2, 2023 at 10:15 AM
    SSMTRDOR
    SSMTRDOR Well-Known Member
    2020 TRD OR 4X4
    Hair dryer and fishing line. Then goo-gone. Then wash/wax.
    That's how I de-badged my truck. I'm sure it's the same for the inserts. Just be patient.
