Best way to remove decals?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dannybten23, Jan 18, 2020.
  1. Jan 18, 2020 at 12:57 PM
    dannybten23
    dannybten23 [OP] Active Member
    Getting a 2019 4 door, short bed Sport next week!
    I want to remove the "TRD Sport" Stickers but not damage the paint underneath.
    What is the best way to do it?
  2. Jan 18, 2020 at 1:01 PM
    DamGuide
    DamGuide Well-Known Member
    Nooga, TN
    2020 TRD Offroad
    Heat from like a hair dryer/warm day helps and goo gone
    RyanDCLB, Color_Me_Taco and kite_325 like this.
  3. Jan 18, 2020 at 1:02 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    If the truck is new, they usually peel off pretty easy. I took mine off a few months after getting it and they just pulled right off in one big sheet.
  4. Jan 18, 2020 at 1:05 PM
    sonocotaco
    sonocotaco Well-Known Member
    ken
    Rohnert Park
    2016 TRD Sport AC 4x4 Super White
    Hair dryer
    kite_325 likes this.
  5. Jan 18, 2020 at 1:06 PM
    Fishnwiz
    Fishnwiz Well-Known Member
    Bill
    2019 Silver TRD ORDCSB 4x4
    Ask dealer to when you pick it up
    strongrob and GreyBaldTaco like this.
  6. Jan 18, 2020 at 2:54 PM
    Mayonayze
    Mayonayze Well-Known Member
    Truth. Make those maggots do work.
  7. Jan 18, 2020 at 2:56 PM
    Mayonayze
    And congrats!
  8. Jan 18, 2020 at 2:58 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    I just used my fingernail. Started one end and pealed it up.
  9. Jan 18, 2020 at 3:09 PM
    abodyjoe
    abodyjoe Well-Known Member
    joe
    2017 Tacoma double cab TRD Offroad. quicksand in color
  10. Jan 18, 2020 at 3:18 PM
    Spazum888
    Spazum888 Well-Known Member
    Spaz
    Orlando, FL
    2017 Taco TRD off-road 4x4
    Blow dryer or heat gun on low. To remove the sticky residue just use IPA (isopropyl alcohol) with a clean microfiber towel. Just be sure to wax the area you use the ipa on because you will be stripping the surface of any wax or sealant.
    I did it with my badges and it turned out perfect.
  11. Jan 18, 2020 at 3:19 PM
    kite_325
    kite_325 A simple human, being
    North Carolina
    2017 TRDOR
    If you do the door badges, I recommend the “heat gun + fishing line behind the badges” method
    GreyBaldTaco likes this.
  12. Jan 18, 2020 at 3:37 PM
    Joe671
    Joe671 YouTube Mechanic
    Joe
    Washington State
    2019 Tacoma TRD Off Road
    I used a heat gun for the bed decal. Just a little heat and it'll come off. You don't want to cook your paint. A little goo gone for the residue and you're done. Good luck.
  13. Jan 18, 2020 at 5:21 PM
    hellfire0480
    hellfire0480 Well-Known Member
    Long Island
    2019 TRD OR Quicksand
    Eibach Pro lift, MR701, 285/70R17 AT3W, SOS Sliders, Sherpa RR
    abodyjoe[QUOTED] likes this.
  14. Jan 18, 2020 at 6:42 PM
    The Pirate
    The Pirate Takoyaki Takoma
    I didn’t need any heat for my decals, I just used my finger nail and carefully pulled them off in a big sheet (one side actually tore little). This left almost no residue on the paint. I have a theory that using heat actually causes more goo to get left behind, since it sort of melts. I would recommend trying without heat first and if you have trouble then get the hair drier.
  15. Jan 21, 2020 at 9:45 AM
    Joe671
    Joe
    Washington State
    Lucky you. I tried without heat and the sticker just kept breaking. With a little heat it came off easy with minimal breaking and only reason I used goo gone was to take off some residual glue. A hair dryer will work fine. I used the heat gun because it was readily accessible in the garage.
  16. Jan 21, 2020 at 10:17 AM
    the_elf_fan
    the_elf_fan Member
    Todd
    Santa Fe, NM
    2020 TRD O/R
    hair dryer and dental floss (or fishing line)
  17. Jan 21, 2020 at 11:13 AM
    Tacospike
    Two Trucks
    I just peeled mine off, washed it, done.
  18. Jan 21, 2020 at 11:41 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
  19. Jan 21, 2020 at 11:44 AM
    Carny1
    Carny1 Well-Known Member
    2019 DCSB TRD OR
    I recently removed mine. Decided to go with the hair dryer over my heat gun, as there should be less of a chance of getting it too hot. Then I used 3M Part #38987, Specialty Adhesive Remover - Aerosol to remove the residual adhesive. Followed that up with a new coat of wax for that area.
    BraddahRO likes this.
