Best way to paint frame (paint is coming off)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by IEsurfer, Jan 23, 2020.
  1. Jan 23, 2020 at 5:08 PM
    IEsurfer
    IEsurfer [OP] Well-Known Member
    Socal
    So I'm pretty OCD anal about my frame and I was about to fluid film it the other day when I noticed some paint was already coming off my frame. What's the best way to paint it, I thought about spraying rustoleum but I'm ocd about the overspray on to the body underneath the truck (I could cover it up I suppose) or do you guys brush paint it?
  2. Jan 23, 2020 at 5:09 PM
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Wire brush, brake cleaner, POR-15 Topcoat
    3dognate, Sharpish, rickc5 and 3 others like this.
  3. Jan 23, 2020 at 5:09 PM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    You live in socal, you can color it with a sharpie and it will be fine. But if you really want there is heat resistant spray paint.
  4. Jan 23, 2020 at 5:10 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Brush on a little rustoleum and call it good.
    Fluid film in SoCal?
  5. Jan 23, 2020 at 5:10 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    If you're that anal about it, the problem you're going to run into is after correcting that little patch the part you painted won't match the rest of the frame.
    So the only solution is to remove the entire frame, bead blast it, paint it in a booth, then reinstall. No big deal right?
    Also why the hell are you messing around with fluid film in Southern California? Last thing I want to do is cover my shit in oil if it doesn't need it.
    Skydvrr, TireFire, WoodsGhost and 4 others like this.
  6. Jan 23, 2020 at 5:11 PM
    TacoBuffet
    AL
    Ya I dont know why your even bothering with Fluid Film in CA, I didnt when I was in AZ, truck looked great. Unless your messing around in the ocean / beach.
    shakerhood likes this.
  7. Jan 23, 2020 at 5:17 PM
    IEsurfer
    Socal
    I go to the mountains a lot, cal trans uses brine and salt depending on location and I surf weekly
  8. Jan 23, 2020 at 5:17 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Yup. My truck has a combo of CRC and fluid film on it. I usually look like a coal miner by the time Im done doing any work underneath. Sucks, but this former VA truck had to have it.
    TacoBuffet likes this.
  9. Jan 23, 2020 at 5:18 PM
    Shwaa
    Shwaa Well-Known Member
    Bay Area, CA
    '13 DC Prerunner TRD Off-Road
    My brother lives near the coast in CA and his frame is trashed, way worse than a lot of the "bad" ones I have seen posted here. There is a misconception that CA = good frames. Not always the case. If you are coastal, in Northern CA anyway, you are fucked.
    TireFire and IEsurfer[OP] like this.
  10. Jan 23, 2020 at 5:21 PM
    TacoBuffet
    AL
    Hence my mentioning the ocean, sand, etc. But I spent a good deal of time in AZ and I would imagine the southern parts of CA or areas like near Edwards you wouldn't have a problem. Of course if you go up the mountains where they use salt / brine, or drive along the coast, beach, in the water ya your frame is gonna need it, but otherwise in that climate, likely not.
  11. Jan 23, 2020 at 5:26 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Even then a handful of trips up a brined road every year isnt gonna hurt. Just spray it off with a hose. Its the trucks that are driven on salted roads for 40% or more of the year that get rotted out mainly.
    TacoBuffet[QUOTED] likes this.
  12. Jan 23, 2020 at 5:27 PM
    IEsurfer
    Socal
    Won't the bare metal (attached pic) rust no matter what? Unless painted over obviously.
  13. Jan 23, 2020 at 5:29 PM
    TacoBuffet
    AL
    Depends, probably but it will be minimal and surface rust, its not gonna start eating away at the integrity of the frame like us salt belt peoples. I've already done fluid film twice this winter on mine :(
    IEsurfer[QUOTED][OP] likes this.
  14. Jan 23, 2020 at 5:31 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    See post 2
    Ignore the other good advice, which is correct, because you will, not because you shouldn’t.
  15. Jan 23, 2020 at 5:31 PM
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    This is my frame in South Texas. Fluid Film won't hurt
    IEsurfer[OP] likes this.
  16. Jan 23, 2020 at 5:31 PM
    TacoBuffet
    AL
    Hey that's my post :D
  17. Jan 23, 2020 at 5:32 PM
    TacoBuffet
    AL
    Near the gulf coast? I remember you could taste that sh*t in the air when I was in Galveston and MS area.
    ALI3N_123[QUOTED] likes this.
  18. Jan 23, 2020 at 5:33 PM
    ALI3N_123
    Eric
    Austin, Texas
    I'm an hour drive west from South Padre Island
  19. Jan 23, 2020 at 5:33 PM
    Superdave1.0
    Superdave1.0 Grandma Dave
    SoCal
    LX470, 2025 Civic Si
    I didn't even know what fluid film was until joining Tacomaworld. :rofl:
  20. Jan 23, 2020 at 5:34 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    what about removing frame, replicating it to stainless steel, painting it, and then reinstalling that?
    doublethebass and Grossomotto like this.
