Best way to mount speakers to adapters
Discussion in 'Audio & Video' started by mrcheap, Aug 19, 2023.
  1. Aug 19, 2023 at 8:55 AM
    mrcheap
    mrcheap [OP] Well-Known Member
    So basically I’ve developed rattles as the screws attaching my speakers to the adapters have become loose…..is there a better way to secure them as a couple of them keep spinning…..
  2. Aug 19, 2023 at 9:05 AM
    Clearwater Bill
    Billy
    Largo Florida
    Can you use a small bolt/nut with a drop of blue locktite?
  3. Aug 19, 2023 at 9:08 AM
    mrcheap
    Thinking of an adhesive……
  4. Aug 19, 2023 at 5:41 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    You can use a little sound deadening or a small strip of foam in between and step your screw size up . Just don’t over tighten it.
  5. Aug 19, 2023 at 5:52 PM
    mrcheap
    Yea I’m using felt tape….probably will step up a screw size as the screws that came with seems “just enough” but seems to have loosened over time….
    Stevie17 likes this.
  6. Aug 19, 2023 at 7:45 PM
    Stevie17
    Stevie
    Crossville, Alabama
    I used the supplied screws for my adapters and the original screws that mounted the adapters to the doors. And also did sound deadening and fast rings .
  7. Aug 20, 2023 at 7:21 AM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    get some larger diameter screws. but if you're vibrating the doors that much, you probably really need a decent crossover setup with a subwoofer.
  8. Aug 21, 2023 at 12:02 PM
    6spd
    6spd Well-Known Member
    san diego
    2023 4x4
    Hurricane nuts on the backside of the adapter
  9. Aug 27, 2023 at 8:45 PM
    3Marcus3
    3Marcus3 Member
    Marcus
    Long Island NY
    2022 Mag Grey Tacoma Sport Access Cab 6MT
    I used 4-40 x1-1/4 machine screws/nuts with washers and red locktite and so far (3 months) no issues
  10. Oct 31, 2023 at 8:17 AM
    Sandthemall
    Sandthemall Well-Known Member
    Sandamal
    2023 TRD OR MT
    Pictures of your set up would help. I installed metra adapters and they cracked after a week of driving. Get some heavy duty adapters or make your own from plywood. Then get rid of the loosey goosey green OEM screw anchors and replace with some good fasteners from the hardware store.
  11. Nov 2, 2023 at 6:49 PM
    gb_23
    gb_23 Well-Known Member
    Central Alabama
    2023 TRD Sport
    If you are using the plastic adaptors for the speakers throw them in the trash, then go to a good stereo shop and get some made out of wood. They will sound better and if you know how to use a screw driver you won’t strip out the screws. If you really want them to sound better use sound deadening to seal the adaptors to the doors. The store I used to run we would alway use wood over the plastic crap, we had templates of the adapters so we could usually route a pair out in a couple of minutes.
