Best way to lift the rear? 3 leaf AAL vs leaf pack?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tedNugent, Mar 29, 2021.
  1. Mar 29, 2021 at 3:33 PM
    tedNugent
    tedNugent [OP] Well-Known Member
    ted
    2019 trd Sport
    Well I ordered a 6112/5160 combo from rogue offroad asking them to give me an inch in the front and they ended up sending it to me a notch higher than I asked, so I'm sitting with .5 of bro lean. I hate to get a block to even it out after i just spent 1500 on suspension, and I keep hearing add a leafs make the ride quality harsher. Is there any other option that is 1-1.5 inches of rear lift? I'm not seeing any full leaf packs that are under 2". I dont want to do 2" because ill have way too much rake. Is a 3 leaf add a leaf really that bad?
  2. Mar 29, 2021 at 3:40 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I have one in the rear of mine yes I hate that the ass of my truck is up not by much. I'm ocd so if I get a 4 in. Lift my truck would sit level I would hope
  3. Mar 29, 2021 at 3:50 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    1 inch blocks in the rear are fine. Replace the entire leaf pack in 50k miles.
    Hooper89 likes this.
  4. Mar 29, 2021 at 3:57 PM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    I did the HS AAL 3 leaf pack with my TSB leaf pack. I removed the overload (that would have raised it closer to 2" and it doesn't really work correctly with a AAL in there anyway) and I think it rides really good, not harsh at all. Very much stock like.
    Another option is firestone airbags. I'm thinking of adding them to my set up for when I get mulch, crushed rock etc. I don't want to wreck the springs without the overload in there, and you can fine tune the ride height.
    brockleegreens likes this.
  5. Mar 29, 2021 at 4:01 PM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Just get a 1” block that isn’t complete shit and you’ll be gtg
  6. Mar 29, 2021 at 4:03 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Rake is good if you use it like a truck
    02Duck, D.A.S. Taco, bodean and 6 others like this.
  7. Mar 29, 2021 at 6:51 PM
    tedNugent
    ted
    2019 trd Sport
    what would be more comfortable on road, 1" block or 3 peice AAL?
  8. Mar 29, 2021 at 6:54 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    Exactly. You want some rake. Perfectly level with no load looks strange when you load it and drives strange to. But if you never load it I guss it would be ok. I prefer some rake.
  9. Mar 30, 2021 at 5:03 AM
    shotgunbilly420
    Let me get a better understanding not one aal but three of them ? If so 3 aal it will ride super rough I have one on my truck and it bounces a little empty
  10. Mar 30, 2021 at 5:12 AM
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    You said BEST. A deaver new leaf pack.
    D.A.S. Taco and Gen3TacomaOBX like this.
  11. Mar 30, 2021 at 5:45 AM
    vtown
    CT
    He’s talking a about the 3 leaf AAL packs that are available from headstrong and others.
    71tattooguy likes this.
  12. Mar 30, 2021 at 5:47 AM
    bolt_thrower77
    bolt_thrower77 Well-Known Member
    2021 DCLB trd or
    nothing wrong with a rear block
    vtown likes this.
  13. Mar 30, 2021 at 5:48 AM
    medicfung
    medicfung Well-Known Member
    richie
    2019 DC TRD OFFROAD 4x4 6ft bed quicksand
    Icon rxt leaf pack is amazing, completely changed the way my truck drives for the better. Softer and stiffer at the same time, compliant, yet holds up the weight without any lean
  14. Mar 30, 2021 at 5:49 AM
    vtown
    CT
    I mean, a 1” block will not change the ride at all and is cheap...probably the answer in your case. The 3 leaf AAL packs will lift more than an inch and will probably slightly stiffen the ride. I didn’t notice the stiffness, but I do have a cap so have some weight back there.
    Gen3TacomaOBX likes this.
  15. Mar 30, 2021 at 5:50 AM
    tedNugent
    ted
    2019 trd Sport
    I'm looking at those right now. I'm thinking the first stage for my application. Thats great news on the ride quality!
    medicfung[QUOTED] likes this.
  16. Mar 30, 2021 at 5:51 AM
    tedNugent
    ted
    2019 trd Sport
    I hate the idea of a block for some reason. Just seems like a cheap bandage fix. Going to probably go with the icon rxt leaf pack like was suggested.
  17. Mar 30, 2021 at 5:55 AM
    medicfung
    richie
    I had the wheelers 3 leaf progressive aal before and let me tell you, it is a significant difference in ride quality, so much so that my truck drives better. Over big bumps or dips it just soaks it up without hitting the bumpstops, I think since I’ve only bottomed out once or twice.
    Crikeymike and 71tattooguy like this.
  18. Mar 30, 2021 at 5:59 AM
    tedNugent
    ted
    2019 trd Sport
    Well that is great to hear. Hopefully I can find the rxts in stock somewhere!
    vtown likes this.
  19. Mar 30, 2021 at 6:39 AM
    Hatfieco05
    Hatfieco05 Well-Known Member
    Portland, OR
    2020 DCLB TRD Off-Road Premium
    The 3 leaf progressive that Icon/All Pro/Wheelers sells would accomplish what you want. The leaf pack will definitely do it but with most people reporting the aal kit with overload removed only giving and 1" of lift you'd sit where you want where the leafpack will net you more lift. Are both 6112 set 1 click higher than you wanted? Usually they set the drivers one click higher than passenger to account for tacoma lean. Remember they will settle in too.
  20. Mar 30, 2021 at 6:44 AM
    WZ00R2
    WZ00R2 Well-Known Member
    TN
    2020 Cement OR
    6112/5160, Deaver U402, 255/80r17, SCS BR6
    They shipped my 6112s on the wrong setting as well. What are they set at?
