Best way to carry 14ft poles
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Crimson Flam3s, Mar 28, 2019.
  1. Mar 28, 2019 at 7:39 PM
    Crimson Flam3s
    Crimson Flam3s [OP] Well-Known Member
    So I have been doing a lot of installs and will be doing a lot more in the near future that require carrying some lightweight 14ft poles.
    So far I have been managing fine with straps and tying down everything super tight plus a "roof protecting device" lol
    My main concerns are something to protect the roof and being able to safely carry a couple more poles.
    Considering:
    -Single side ladder rack although I wanted something that requires no drilling, and can easily be taken out when not in use.
    -Getting the factory roof rack and a ladder back all the way by the end of the bed
    -Using the same carrying system I use now and simply installing a backrack or roll bar to protect the roof but my budget is around $250 and most backracks/headache rack look really bad.
    Any other ideas?
  2. Mar 28, 2019 at 7:42 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    rtzx9r and hiPSI like this.
  3. Mar 28, 2019 at 7:47 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    If are under #100lbs get the roof rack on the truck like i did..i can carry my 19 foot hang glider....
  4. Mar 28, 2019 at 7:51 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    You could probably build a headache rack to use and only keep it in when you need it. Attach it to the bed rail system. Get some flat bar that's around 1/4 inch thick cut it down to the size of the bed rail and drill a hole in the middle and tap it
    Big tall dave likes this.
  5. Mar 28, 2019 at 7:57 PM
    Crimson Flam3s
    Thanks, I can't do this since I also carry other equipment that requires the tailgate closed and would prefer to not have 10 foot of pole sticking out behind me as I sometimes have to drive/maneuver/park around tight spaces before I can unload.
    Skydvrr and shakerhood[QUOTED] like this.
  6. Mar 28, 2019 at 7:59 PM
    shakerhood
    Southern Ohio
    I usually use it for long pieces of lumber, I think a lot of guys use them for kayak's.
  7. Mar 28, 2019 at 10:14 PM
    Shellshock
    Iowa
    16 foot trailer?
    BSFord, Bleep100, ajm and 1 other person like this.
  8. Mar 29, 2019 at 3:56 AM
    ICU1
    ICU1 Well-Known Member
    I hope it never happens, but think of other drivers. Not sure if that’s the safest way to haul 14’ poles.
    BSFord likes this.
  9. Mar 29, 2019 at 3:59 AM
    Trouble_The_Tacoma
    Trouble_The_Tacoma Well-Known Member
    Conrad
    14’6”
  10. Mar 29, 2019 at 4:11 AM
    Dishsoap
    Dishsoap Well-Known Member
    White Mountains, NH
    2016 SR5 DCSB V6
    Cut them in half.:crapstorm:
  11. Mar 29, 2019 at 5:50 AM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    If you’re doing this regularly you should get a bigger budget. Need to think of safety and get a proper rack or trailer.
  12. Mar 29, 2019 at 6:00 AM
    HelloMyNameIs
    HelloMyNameIs I know words, I have the best words.
    2018 TRD Off Road in Cement
    OME 2885, Billie 5100s, HS Prog AAL, 255/85r16 Cooper ST Maxxs
  13. Mar 29, 2019 at 6:11 AM
    96carboard
    96carboard Well-Known Member
    If its an "occasional" thing, use the back window.
    14 foot poles....
    14-6 (bed) = 8
    8-5 (cab) = 3
    ... you don't need a red flag except if it extends MORE than 3 feet beyond the back of the BUMPER.
    Ratchet strap it at the front of the bed. Loop the strap all the way around the cargo.
    If its an "all the time" thing, then you need to think about getting a rack.
  14. Mar 29, 2019 at 7:17 AM
    daveometrod
    daveometrod Well-Known Member
    18 TRD OR 4x4 DCSB Blazing Blue
    Michigan "4 feet or more beyond the bed or body "
    Where you live/drive is the law you need to know.
    96carboard[QUOTED] likes this.
  15. Mar 29, 2019 at 7:24 AM
    96carboard
    I've never seen anywhere under 3 feet, which is why I used that number, but by all means, if your area allows longer, use that.
    daveometrod[QUOTED] likes this.
  16. Mar 29, 2019 at 7:39 AM
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I was looking through my Smugmug gallery to see if I had any pictures of the rack I built out of random lumber I had laying around, and I guess this one somewhat gives you an idea. I guess it was a picture of my traction kite for some strange reason. I cobbled together a rack out of lumber I had, it took a few hours to make and worked awesome. It fit perfectly in the bed and I tied it to the bed tie downs. It was supposed to be temporary but the next year after winter (it was a canoe rack) it was still solid as can be, so I painted it to preserve it and used it until I got a trailer. It was solid as can be and the canoe was a big flat back that weighed 130 lbs.
    96carboard likes this.
  17. Mar 29, 2019 at 8:56 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
  18. Mar 29, 2019 at 9:29 AM
    96carboard
    I think that there is some degree of illusion in that image due to 2-dimensions.
    Look at the ladder's feet and compare the angle there with the passenger side of the car. If the ladder was entirely perpendicular to the vehicle's direction of motion, then the "front" foot could not be visible through the "back" foot.
    However, also compare the angle of the feet with the angle of the back of the car.
    So the ladder is actually mounted on a **diagonal**, which isn't nearly as bad as being mounted fully perpendicular to the direction of travel as it initially appears.
    Assuming that the ladder complies with osha, the rungs must be spaced between 10 and 14 inches. At the maximum 14 inches, 12 rungs and half rung extension beyond the end rungs, the total length of that ladder is not more than 15.2 feet.
    At a 45 degree angle, it would take up a width of 10.75 feet, plus the width of the ladder, so about 12 feet, which is the standard lane width.
    However.... assuming a square roof rack base, and that each side of the ladder is mounted against the side rail, then the angle must be LESS than 45 degrees.
    The equation to find the width is 15.2 sin X, where X is the angle made between the ladder and the direction of travel.
    I.e., at 5 degree increments from 20 to 40 degrees;
    15.2 sin 20 = 5.2 feet wide
    15.2 sin 25 = 6.4 feet
    15.2 sin 30 = 7.6 feet
    15.2 sin 35 = 8.7 feet
    15.2 sin 40 = 9.8 feet
    And note that you still have to add in the width of the ladder's rails, so about 16 inches.
    My best guess is that its probably at 20-25 degrees, which isn't NEARLY as bad as it initially looks.
    Still stupid as hell though.
    daveometrod likes this.
  19. Mar 29, 2019 at 9:35 AM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    I was just going to say that .
  20. Mar 29, 2019 at 9:37 AM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Admit it... it was you. :rofl::rofl:
    Crimson Flam3s[OP] and tcjacado like this.
