Best Way to add lift to a 6 inch kit
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rawdog03, Mar 9, 2021.
  1. Mar 9, 2021 at 3:20 PM
    Rawdog03
    Rawdog03 [OP] Member
    Will
    2015 Tacoma Trd 4wd
    I’m kind of new to the truck scene and don’t know a whole lot about suspension stuff. I’m thinking about getting a 6 inch zone lift and want to add another inch or two on top of that while maintaining safe angles and decent ride quality. What is the best way to do this without breaking the bank?
  2. Mar 9, 2021 at 3:25 PM
    FFBlack
    FFBlack Well-Known Member
    2019 TRD OFF ROAD
    Find another truck then a Tacoma. Just being honest these trucks , 6 inch lifts ,and ride quality dont go together. 3 inch max.
    wi_taco and .45 Calibear like this.
  3. Mar 9, 2021 at 3:26 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    The only way to lift 6" while retaining good geometry is a drop bracket lift. To my knowledge, Rough Country makes the only one for these trucks. This requires cutting out your stock front crossmember, so it's pretty permanent.
    You'll get a bit of hate from this site for 3+ inch lifts, but it's your truck do what you do!
  4. Mar 9, 2021 at 3:45 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    The zone is a drop bracket kit
  5. Mar 9, 2021 at 3:51 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    I was thinking about some adjustable bilstein 5100s for the front but I didn’t know if there’s a better method of getting more lift
  6. Mar 9, 2021 at 3:56 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    That’s the way guys with show trucks would do it. Are you planning on wheeling this truck or is it gonna be a pavement princess?
  7. Mar 9, 2021 at 3:56 PM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers and a skewp
    Maybe try a 3" lift with 5100s and add a leaf plus a body lift to get the rest. Should be able to get 4-6 inches that way
  8. Mar 9, 2021 at 4:00 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    mostly pavement besides on the weekends at my hunting lease where there’s a little bit of mud but not wheeling for sure
  9. Mar 9, 2021 at 4:04 PM
    gotoman1969
    I asked because there is no performance gain going to the 6” kit plus the fact if you wanna undo it down the road it’s a royal pia.
  10. Mar 9, 2021 at 4:06 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    Not too worried about that, honestly just going for looks
  11. Mar 9, 2021 at 4:10 PM
    gotoman1969
    Then go for it. Then yes the 6” drop bracket kit, plus the 5100s is one way to do it. You could also use and adjustable coilover and set it for 1” of lift by moving the collar as needed. Just depends on what you wanna spend on coilovers.
  12. Mar 9, 2021 at 4:11 PM
    gotoman1969
    Or this ^^
  13. Mar 9, 2021 at 4:15 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    Who makes it? I haven’t seen one around.
    14tacoma808 likes this.
  14. Mar 9, 2021 at 4:17 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    Ok so I won’t have any fitment problems? I heard doing that with that kind of lift it risky because it has strut spacers and I just want everything to fit right when I take it to the shop.
  15. Mar 9, 2021 at 4:44 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    Thanks man, can just get the 6 inch kit alone and see how it is
  16. Mar 9, 2021 at 4:50 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    Why do you want to go over 6 inches? That will likely reduce your ride quality. Since you are going for looks almost any commercial kit will work fine and still give you a decent ride.
    Mark77 likes this.
  17. Mar 9, 2021 at 5:13 PM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    I say go for 10"
  18. Mar 9, 2021 at 5:26 PM
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I say go for 14", same as extended coilovers. extra long travel
    whatstcp and wi_taco like this.
  19. Mar 9, 2021 at 5:46 PM
    gotoman1969
    It’s no different than placing the spacer on top of the factory coil. Personally I’d use adjustable coilovers if you went that way. You could also get full length coilovers for a 6” kit and adjust those to yield an extra inch. Put the 6” kit by itself and see want you think.
    whatstcp likes this.
  20. Mar 9, 2021 at 5:55 PM
    Rawdog03
    Will
    2015 Tacoma Trd 4wd
    Don’t think my gas tank would be happy
    TacoTyusday[QUOTED] likes this.
