Best Water Pump To Use? Replacement Time
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BakoTruck, Nov 26, 2019.
  1. Nov 26, 2019 at 2:14 PM
    BakoTruck
    BakoTruck [OP] Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
  2. Nov 26, 2019 at 2:26 PM
    JAGCanada
    JAGCanada Well-Known Member
    Canada
    2010 TRD Sport V6 Auto Double Cab MGM
    BakoTruck[OP] and MolonLabeTaco like this.
  3. Nov 26, 2019 at 2:41 PM
    west467
    west467 Well-Known Member
    Two Black Tacos..03 and 09
  4. Nov 26, 2019 at 3:31 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Oem lasted 14 years, im sticking with oem.
    igno1tus, Lester Lugnut and whatstcp like this.
  5. Nov 26, 2019 at 3:31 PM
    west467
    Aisin is the OEM
  6. Nov 26, 2019 at 7:02 PM
    joeyv141
    joeyv141 Well-Known Member
    New Jersey
    08 DCLB 4x4 V6 TRD Sport
    I second OEM/Aisin.
    200,000 miles and still no leaks.
    BakoTruck[OP] and R0dzilla75 like this.
  7. Nov 26, 2019 at 7:04 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    OEM/Aisin all day
    BakoTruck[OP] likes this.
  8. Nov 26, 2019 at 7:17 PM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    Aisin water pump on Amazon is $85. It was the least expensive I could find on the internet that was a Aisin. It came with the gasket and the 2 o-rings. It should take less than an hour. Keep the pumps close by so you can clearly see all of the bolts you need to R & R. Here's a decent video on it:
    https://youtu.be/WFLp7kLH198
  9. Dec 2, 2019 at 4:04 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Thanks everyone! I appreciate it! Will go with the Aisin pump.
  10. Sep 15, 2021 at 9:06 AM
    Bareknuckles
    Bareknuckles Member
    Marc
    '07 Prerunner Double Cab 2wd
    356,000 miles with original water pump on my 07' 4.0L. Incredible.
    igno1tus likes this.
