Best Upgrades to my 1st gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by Noah02Tacoma, Dec 30, 2020.
  1. Dec 30, 2020 at 4:15 AM
    Noah02Tacoma
    Noah02Tacoma [OP] Member
    Noah
    2002 Toyota Tacoma TRD SR5
    Stock
    What's up everyone!
    My 02 Tacoma just joined the 200,000 mile club!!!
    Just looking for some nice upgrades. Reaching out for any ideas Thanks! Tacoma .jpg
    CrustyTaco and Taco critter like this.
  2. Dec 30, 2020 at 11:58 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Upgrades for what? Could be anything.
    Do you want 40's and tons, or LED map lights?
    Front bumper could use an alignment, tho.
    jonesbt, TWJLee and Black DOG Lila like this.
  3. Dec 30, 2020 at 12:12 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 180k
    881/5100/Dakars 4R wheels / TBU / New frame
    I think it would look good with the fender flares and bumper plastic restored back to black. Could also consider replacing your window belt trim, looks like the black coating has worn off. Part numbers on those are 68210-04020 and 68160-04020. I tint all of my cars, so that would be the next thing for me at least.
  4. Dec 30, 2020 at 12:12 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Doing my part one Taco at a time with sheep fat
  5. Jan 4, 2021 at 11:39 AM
    tanstaafl26
    tanstaafl26 Well-Known Member
    San Diego
    Tacoma TRD 4x4
    Bought my 04 TRD 4x4 new. 265k now. Tundra front brakes with steel braided lines from Wheelers was hands down the best bang for the buck. I did it when the original Tundra WE calipers were cheap and readily available. I'd probably do the WL version, (Same rotor I think, but larger caliper) if I had to do it again. I've read there are even larger brakes available from the Lexus GX series now. I believe those require at least 17" rims though-I want more tire/less rim. Found Brembo blank rotors at rockauto on clearance and used stock Tundra pads. Pads lasted 90k & the rotors longer. Did the work myself so I used the extra $ to do the Wheeler's 3 rear spring pack, OME 881 springs with Bilstein 5100 shocks. The cheesy spring compressor was scary though...I run the 5-star rims off a Limited 4runner with 235/85-16 BFG KO2's. Bit squishy 'round freeway cloverleafs but I picked up some MPG and the traction in snow is better than the wider 265/75 versions. And they don't rub the frame at full lock like the 265/75's did. Everything else is stock. After the front brakes, I'd say get a Scangauge II. I plugged in a Scanguage to monitor trans temps. Turning off the overdrive on hills or when loaded helps alot. I have a trans cooler to install next.
  6. Jan 4, 2021 at 11:42 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Best 'upgrade' is driver mod :burnrubber:
  7. Jan 5, 2021 at 8:17 AM
    1997tacomav6
    Denver
    Start off with as stated,
    1) new bumper as it look like a big dent
    2) window belt trim
    3) remove the fender flares and repaint them
    4) replace the lower ball joints, MUST DO
    Wulf likes this.
  8. Jan 5, 2021 at 2:13 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I like to say the best upgrade you can do to your truck is a daily driver.
    Also, what @1997tacomav6 said.
    1997tacomav6 likes this.
  9. Jan 5, 2021 at 3:51 PM
    preybird1
    preybird1 02 taco on 37's
    Russ
    Salt lake city Utah
    2002 taco s\c
    Trd S\C with nosecone hybrid bearing upgrade kit. 2.0 urd pulley, 7th injector kit-urd "6 fabtech lift with 3" body lift. 20" XD spy wheels with toyo open country r\t's in 37"x 12.50x20. Front and rear diffs re-geared to 4.88 dirty 30 drive axles. and a rhino pack clutch. Custom exhaust and huge mudflaps!
    supercharge it! or exhaust mods! lift it!
  10. Jan 5, 2021 at 3:52 PM
    jbrandt
    Justin
    When do you get yours?
    :rofl:
  11. Jan 5, 2021 at 3:53 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    With two working hands I'd say mines better than yours :luvya:
  12. Jan 5, 2021 at 3:53 PM
    jbrandt
    Justin
    Mine was a downgrade.
    :anonymous:
    Kwikvette[QUOTED] likes this.
  13. Jan 5, 2021 at 3:54 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You're missing out what's happening in the LT :burp:
  14. Jan 5, 2021 at 4:09 PM
    jbrandt
    Justin
    I'm gone for 5 minutes and I'm 16 pages behind...
