Best undercoating material to prevent rust?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dennisi01, Jul 16, 2010.
  1. Oct 30, 2016 at 1:06 PM
    #41
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    I'm well aware of that, I've seen it happen and the results, which is why im using the bed liner polyurethane coating, I've seen factory rubber coating on a BMW for instance where the rust crawls up behind it. But that probably wouldn't happen with oil coating over the top.
    Haha, plus you're from GA so you're going on hearsay, I've been working under rusty NY vehicles for 20 years now
  2. Oct 30, 2016 at 5:11 PM
    #42
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    Im a huge fan of fluid film. I buy it by the gallon and use my compressor to spray underneath (car lift ftw!). The stuff coats the metal and creeps into tight places. It lasts about 6 months before you have to spray again. The problem i see with others is trying to get the top of the frame and other tight areas as well as prep required. I hit my truck every 6 months, takes 5to10minutes and im good.
    http://www.kellsportproducts.com/whatisfluidfilm.html
    I bought the undercoating kit that came with 2gallons and the gun. Black friday deal a few years back.
    Just another option for ya.
    tomwil and ARCHIVE like this.
  3. Oct 31, 2016 at 10:22 AM
    #43
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Rust Bullet and than a coat of Krown or Fluid Film works well.
    But for a new frame, just spray it with Krown or Fluid Film annually and you should not have any issues.
  4. Oct 31, 2016 at 10:43 AM
    #44
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    i bought a gallon of POR15 from ebay and applied it to the bottom of the truck, its been over a year now and it hasn't shown any signs of peeling. Looks exactly like it did when i put it on. I would recommend buying the pint size because you will only use a quarter of the 1 gallon. Plus its way way cheaper.
    #44
  5. Oct 31, 2016 at 10:53 AM
    #45
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Fluid film is what I use. The mechanic I used in PA sprays his frame with chain saw bar oil for winter and his frame has held up well.
  6. Nov 1, 2016 at 7:53 PM
    #46
    ShOwStOpper
    ShOwStOpper Well-Known Member
    some good suggestions on this thread,,never heard of fluid film nor corrosion free 3000 before..
    what if ones truck already has an old coat of some rubberized coating under there,,you most likely cant add a solution such as fluid film or corrosion free 3000 over the top of it am i right?
  7. Nov 1, 2016 at 8:09 PM
    #47
    ARCHIVE
    Eric
    I just bought my first can of fluid film to try.
    I also used SEM chip guard on inboard side of rockers first, careful using this it appears to fade your paint. Then I'm going to take truck in and have it oil sprayed, there is a place called Krown near me, guess it's better known in Ontario Canada.
  8. Nov 2, 2016 at 5:32 AM
    #48
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    I think that realistically, whichever way you go, if you are in a road salted area especially, you have to realize that there is no magic bullet.
    These are all 'maintenance' approaches and will need to be repeated. I do mine annually prior to the arrival of winter and more salt.
  9. Nov 2, 2016 at 6:35 AM
    #49
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I've used POR15, Rust Bullet, Eastwood Rust Encapsulator, and KB coatings anti-rust paints. All on different toyota trucks over the years. The key is to do the prep work LIKE IT SAYS ON THE CAN. Just putting the stuff on straight from the can isn't going to last long and it's going to peel off. I actually tried the rubberized rust encapsulator on a crusty 96 tacoma I had for a while and it ALL flaked off even doing the prep work. My current truck I did the KB coatings on the outside of the frame and eastwood internal frame coating on the inside. Then when Toyota had the frame campaign checks they wound up coating it with their stuff which seems to be really rugged. And I fluid film the crap out of the underside of my truck every fall. For an 05 that's got 175k new england miles on it mine's incredibly clean underneath.
  10. Nov 2, 2016 at 10:23 AM
    #50
    seabear31
    seabear31 Member
    Maine
    09 Tacoma SR5 V6 4x4
    none yet
    After chasing rust under my '09 Tacoma (V6 4x4 Extended cab) here in Maine (lots of salt in the winter) I have reached some conclusions.
    1. Rustoleum "rubberized" Undercoating doesn't work well. Neither does Corroseal, a product that's supposed to convert rust into a hard, paintable surface.
    2. Rustoleum Rust Converter (which looks like black spray paint) doesn't work well. All of these products come off with a wire brush the following year regardless of prep work.
    3. Fluid Film does work pretty well as long as you don't mind that the surfaces you spray it on remain greasy-feeling or tacky. This stuff is also good for electrical connectors like your trailer wiring hookup.
    4. The A-frames, etc., and the vehicle frame members near them always need attention.
    5. You have got to crawl under there with your wire brush and spray-on goo at least a few times a year, to keep after the rust. And you need to be sure to remove the spare tire and go after all the steel pieces up in there.
  11. Nov 2, 2016 at 11:43 AM
    #51
    Kerrigan911
    Dan
    you can spray fluid film over the coating but not sure how effective it would be. if there are spots where they coating is coming off i can see hitting it with something else as being beneficial.
  12. Nov 2, 2016 at 5:19 PM
    #52
    Yoda's TRD
    Yoda's TRD Well-Known Member
    David
    Haslett, MI
    2025 TRD Sport Hybrid
  13. Nov 2, 2016 at 6:45 PM
    #53
    TacoGlenn
    TacoGlenn Nobody Makes a Monkey Outta Me!
    PNW
    '13 MGMAC 2.7L SR5
    Hellwig 1251's, Leer 122, Kahtec smart stop delay flashing 3rd brake light, de-chromed, de-badged, WeatherTech mats, WeatherTech side window deflectors,
  14. Mar 25, 2017 at 11:34 AM
    #54
    Canadianguy91
    Canadianguy91 Well-Known Member
    Sean
    Halton Hills, Ontario, Canada
    2016 Limited
    Krown undercoating, Protect a plate, blindspot mirrors, Reese stainless steel towing ball, Bakflip MX4 tonneau cover, Tufskinz tailgate letter inserts, Console organiser, Tinted windows, LED interiors, Bed lights, Hood lights, Black Canadian flag decal (@bfeth), Oem bed mat, WeatherTech floor liners, Arctic Claw XSI tires, Recovery Shackle, Ultimate LED turn signals V3 @mesojdm, OEM TRD Off-Road tow hook, Bilstein 5100's with ARB's Old Man Emu 2887 coils, ICON progressive add a leaf, General Grabber ATX tires, Fuel ripper rims, Auxbeam F-16 H11 Led headlights, Borla S-type catback exhaust with black tip, custom powertray, vinyl badge inlays, (@rrentrop), Rear diff breather mod, Redarc trailer break controller https://m.youtube.com/watch?v=qqN7m1pc6AA
    does your truck still look good? im looking to get mine rust proofed
  15. Mar 25, 2017 at 11:37 AM
    #55
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    POR-15 or fluid film
  16. Mar 25, 2017 at 11:45 AM
    #56
    ARCHIVE
    Eric
    Just a review of the Krown oil undercoating I said I was going to do in November. I was really happy with the product and application done at Superior Auto Sales on Camp rd in Hamburg, NY.
    The product was very thin and shiny, but it stuck well, (unlike another product I had applied to my family van). While Krown did drip, everything stayed covered.
    I am very likely to have Krown done again next fall, and I would recommend it to anyone.
  17. Nov 27, 2020 at 6:05 PM
    #57
    ARCHIVE
    Eric
    Just a reminder to Tacoma owners, get your frame undercoated! I have been converted to Fluid Film (Still happy with the Krown I had sprayed) and have been applying FF myself for last few years on my Tacoma. The insides of my frame channels have stayed perfect
    https://www.tacomaworld.com/threads...-videos-tacoma-tundra-4runner-sequoia.617918/
