Best undercoating material to prevent rust?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dennisi01, Jul 16, 2010.
  1. Jul 16, 2010 at 6:49 AM
    Dennisi01
    Dennisi01 [OP] Well-Known Member
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Hey folks.. Living in NJ, and having owned a 95 4runner, I'm a little scared of rust. My truck is only about a month old, hasn't seen a winter yet (it was born in April of 2010), and I want to do the right thing in preventing rust. I'm also taking it to OBX next week, so will be driving on the beach, and want to prevent even the littlest spec of rust from showing up if I can :) Anyway, whats the best thing to use? I see rustoleum has an undercoat spray, as well as an engine enamel spray(that sounds like tough stuff) and I think I also read that people spray rustoleum bedliner underneath to prevent rust? What do you experts suggest?
    Also, what should I *NOT* spray under the truck? I plan on hitting everything that looks like it could rust, but I dont want to spray something that shouldn't be and cause issues. I am WAAAAY obsessive about my new truck, but it is my first 'nice' new vehicle (my only other new car was a 2005 honda civic with no power windows or locks that was bought as a commuter car, which got sold to buy my 2010 red taco :p)
    Thanks all!!!
  2. Jul 16, 2010 at 7:21 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Periodically brush, clean, and repaint rust. Undercoating won't show it's rusting underneath. It's also harder to work on undercoated areas.
  3. Jul 16, 2010 at 7:22 AM
    JAG
    JAG Well-Known Member
  4. Jul 16, 2010 at 7:35 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    The best rust preventer is moving somewhere where it doesn't snow :D
    When you drive at the OBX just make sure you rinse it off. Its kinda hard to avoid the salt spray especially when the winds are coming off the ocean.
    While its new and clean, I would spray bedliner. I noticed a little surface rust on the frame rails and cab mounts of my '07 so I sanded them, primed them and painted them w/ duplicolor spray on bedliner. However, I live in GA so rust isnt really a problem here.
  5. Jul 16, 2010 at 8:07 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    I'll post some pics soon :) My question is about prevention. There is no rust underneath yet, since the truck is so new and hasnt seen a winter yet.. would bedliner be best for the frame rails and such? I'm guessing we dont spray anything on the exhaust right?
  6. Jul 16, 2010 at 8:10 AM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    A high quality durable paint would be best, several applications if possible.
    Do not use rubberized undercoating on your frame.
  7. Jul 16, 2010 at 8:15 AM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    ok.. rustoleum undercoating would be the stuff to use?
  8. Jul 16, 2010 at 8:19 AM
    Crom
    Nick
    San Diego, CA
    Millions
    I would not advise that. Undercoating can develop perforations and your frame can rot sight unseen. I would only use undercoating on non-metal surfaces.
    I would use paint. Per your other post, do not paint any part of the exhaust.
    If you have a respectable body shop or auto-restoration shop in your city--call them. Ask them what they would coat a frame with.
  9. Jul 16, 2010 at 11:42 AM
    Dave333
    Dave333 Well-Known Member
    Dave
    Loganville
    06 PreRunner TRD long bed dbl cab
    Borla Exhaust, D/T LT, TRD CAI, Hella Rallye 4000, ARB, M/T Sidebiters 16", 265/75/16, Stubbs HD SKO Sliders, OME 3" lift with 886, Dakar Rear leafs, Satoshi
    POR 15 is what most guys use when restoring cars. I've used it on 2 of my rebuilds, both I had to sand down to bare metal to remove surface rust. One frame has set outside for 3 years now with no problems. You can purchase it as a roll on or spray. Works great.
    REDdawn6 likes this.
  10. Jul 16, 2010 at 11:47 AM
    dzlpwrd
    dzlpwrd toyota fan from birth
    james
    wilton maine
    1995.5 v6 4x4 sr5
    ported air box, 3 inch custom exhaust, with cat delete, tinted windows, 4 6 inch 300 watt speakers, 2 1800 watt amps,2 6x9 900 watt speakers, pioneer recievier with ipod control, 3 inch lift, color match cap, more to come...
    dont use undercoating it is porous and will not seal. i use rustolem professional oil base paint on everything i own. it comes in a silver can is available at walsmart in gallons or most any hardware store in poof cans.
  11. Jul 16, 2010 at 4:34 PM
    mcgiiver
    mcgiiver Well-Known Member
    Princeton, NJ
    2009 Access cab 4x4, 4 cyl, stick
    Aftermarket Driving Lights, Hidden Hitch, Removed rear headrests, Side protective moldings, vacuum gauge, Scan Gauge, Leer cap.
    I don't like the undercoating because rust can form beneath it sight unseen until the undercoating comes off in a big flake. Paint , even Rustoleum doesn't seem to provide good enough protection from impact or abrasion.
    I once had a car rustproofed. They used something that was light brown in color and best described as an oily wax, sort of like a beeswax. It was sprayed on and in doors and such. I think it sort of self healed itself when touched as if it never fully dried. Seems like it continually exuded oil to protect the metal. I would love to get a few cans of the stuff if I knew exactly what it was.
  12. Jul 16, 2010 at 4:47 PM
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    See 'Carwell'.
  13. Jul 16, 2010 at 6:05 PM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Wow, that stuff from Carwell/Rust doctors looks pretty good.. anyone have any experienced with it?
  14. Jul 16, 2010 at 6:16 PM
    VTDave
    VTDave Well-Known Member
    Vermont, USA
    05 Access Cab 4x4 Base 5sp Man, 16 DCSB 4x4 Sport 6sp Man
    x10. Do a search. You'll see a lot of the Canadians use this product. Also, Rustoleum primer and then paint will work well.
    Don't use any gimmicky products. Just paint.
  15. Jul 16, 2010 at 6:24 PM
    WNYTACOMA
    Clarence, New York
    I use it on my 09'. I had it done prior to the 1st winter and had it re-sprayed prior to the 2nd. So far, so good.
    We probably see as much salt as anyone where i live about 1/2 hour outside of Buffalo, New York.
    They also sell cans of it for 'touch ups' that i intend to try for touch ups between fall applications. I think the cans are supposed to carry about a $7.00 hit and the guy at the shop said they go pretty far. They were out of the cans when i stopped by this spring, and i haven't had sense of urgency tto get back with it being teh summer. I will get back there soon. The place is about 20-25 minutes away from me.
    I've used others in the past and this one seems to be the best so far. My friend used to own a Ziebart and i slathered my 87' prior to its first winter with probably about 30 lbs of that crap.
    I would feel like an idiot in a salt happy state crawling under my truck yearly and sanding the frame to re-paint it, only to have to go through that nonsense yearly, all the while losing the battle badly.
    If i was to resort to that insanity, the por-15 would be the only option.
  16. Jul 16, 2010 at 6:41 PM
    Dennisi01
    Dennis
    Forks, PA
    '10 SR5 4x4
    None
    Which stuff did you use specifically? I'm in new jersey, so we arent quite as bad as buffalo, but still bad. I don't want to deal with rust, especially since I plan on keeping this truck for a long time. I could also do my wife's Forester I suppose, LOL!:)
  17. Jul 16, 2010 at 6:43 PM
    paintdiddy
    paintdiddy Machine gun shits
    shithead
    nj and not from "the jersey shore"
    silver bullet
    i need to do my 2010 as well being a jersey jerk
  18. Jul 16, 2010 at 6:54 PM
    Crom
    Nick
    San Diego, CA
    Millions
    This has been my experience too. I use rustoleum for touchups underneath my truck but if gravel or rocks hit it, the paint will chip. To be fair, I am using the same paint I used on my sliders, so it's not heavy duty, but it works well if it's not scraped or damaged.
    That stuff is called cavity wax. The body shop I spoke to recommended that I have it sprayed inside the front boxed part of the frame where I had my sliders welded on.
  19. Jul 16, 2010 at 7:34 PM
    chopper
    chopper ky taco
    chop
    stanton,kentucky
    05 taco reg cab 4x4
    dura tracs, debadged, weathertech floormats, removed mudflaps,black paint wheels,k&n air intake.
    Sprayfoam crack sealer at lowes !!!!!
  20. Jul 16, 2010 at 7:35 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Google "Krown" to see if it is available in the states. Amazing stuff, no buildup either. Leaks like crazy when it gets warm out though.
