Best traction on wet grass.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boco10, Sep 26, 2023.
  1. Sep 26, 2023 at 5:37 PM
    Boco10
    Boco10 [OP] Well-Known Member
    ADK
    I have a tow behind lift rented for the week. Working on a lake front home and dam the grass is wet till at least noon. Basically, I have to back lift up a decent incline to position lift. Do you think airing down would help? Just trying to leave the least amount of pecker tracks as possible. Thanks
  2. Sep 26, 2023 at 5:44 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Couldn't hurt. Same as putting it in 4hi. Maybe even 4low
    shakerhood and Boco10[OP] like this.
  3. Sep 26, 2023 at 5:54 PM
    LeakyAC
    LeakyAC Captain jackass
    2016 SR5 Access Cab 2.7 4x4 Super White II
    -Uni filter secondary air pump mod -A/C drip line extension mod -ARB F + R diff breathers relocated -ARB front recovery point -"Tow Package" class V receiver + oem 7/4 plug + aux ATF cooler -Toyo Open Country ATIII 245/75R16 -Yellow fog lights (amber Lamin-X w/ PIAA amber H16s) -BakFlip G2 tonneau cover -TRD Pro grille -Body-matched bumper caps -Blackout emblems -Husky X-Act Contour floor liners -RokBlokz mud flaps -oem bed mat Not yet installed: -0" lift Bilstein 5100 F + R w/ 4Runner front shock lower bolt swap -Total Chaos LCA cam tab gussets
    Yea 4x4 will help but be careful with the gas pedal to not let the wheels spins and destroy the grass
    Junkhead likes this.
  4. Sep 26, 2023 at 6:03 PM
    SH10151
    SH10151 Farang
    SF Bay Area
    2022 SR AC UP 4x4
    4lo will combat wheel spin.
    Boco10[OP] likes this.
  5. Sep 26, 2023 at 6:23 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Low range will make wheel spin more likely. Too much torque at low rpm. The best way to prevent wheel spin is the opposite. If possible, use high range and start in 2nd gear. Works great in ice/snow. But may not be possible in this case.
    Malvolio and df41590 like this.
  6. Sep 26, 2023 at 6:26 PM
    Bishop84
    Bishop84 Well-Known Member
    Wet grass is like ice, we actually called a trail run off once because a truck nearly slid off a cliff.
    Honestly any tire that can bite grass will destroy it. So I agree air down, 4 low and go slow.
    Junkhead, hiPSI and Chew like this.
  7. Sep 26, 2023 at 6:29 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    Most of the time when I see people using lifts and the like on grass, they lay down plywood or similar. Stops sinking in and provides better traction. The hill could be the kink in that plan though
    Junkhead, Koolbreeze7 and soundman98 like this.
  8. Sep 27, 2023 at 4:45 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    When you find out what really works, let me know. I live at a lake front home also with a grassy knoll for unloading, and loading my boat. Without 4hi, You'll just spin on muddy grass.
    Tocamo likes this.
  9. Sep 27, 2023 at 4:57 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Find someone with a 4x4 tractor to back it up. Lifts are heavy and may sink, making it harder to back up.
  10. Sep 27, 2023 at 5:14 AM
    nightcrawler
    nightcrawler Well-Known Member
    ‘17pro
  11. Sep 27, 2023 at 5:17 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Lay down a pile of branches where your wheel tracks will be and drive on them.
  12. Sep 27, 2023 at 6:52 AM
    Boco10
    ADK
    Here I go. It is quite steep.
  13. Sep 27, 2023 at 6:54 AM
    Boco10
    ADK
  14. Sep 27, 2023 at 7:23 AM
    ejl923
    ejl923 Well-Known Member
    Eric
    Western Mass
    15 DCSB TRD Off Road
    not sure what model you have, and if 3rd gens have it. My 2nd gen off road has a-trac which applies brakes to any spinning wheel in 4 lo. Its not magic but work well.
  15. Sep 27, 2023 at 7:30 AM
    Boco10
    ADK
    Sx no lo track.
  16. Sep 27, 2023 at 7:50 AM
    Boco10
    ADK
    Nee to get chimney on last town house
  17. Sep 27, 2023 at 8:13 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I think the 3rd Gen Multi Terrain system is kind of like A-Trac on steroids. Good idea, that might help.
    PS: only on OR trim trucks I think.
  18. Sep 27, 2023 at 10:22 AM
    Boco10
    ADK
    That sucked. No weight in ass end. Airing down helps but ass end keep sliding out
  19. Sep 27, 2023 at 10:50 AM
    zoo truck
    None
    I have the same poor man's posi in my gen3 sr5. It doesn't work on a hilly grade with wet grass very well. You still spin pulling a boat and trailer. So far 4wd is the only option that works well.
  20. Sep 27, 2023 at 11:02 AM
    ejl923
    Eric
    Western Mass
    my atrac is 4wd, all 4 wheels get the brakes if spinning, you could call it poor mans 4 wheel posi. It works well plowing uphill in icy conditions for me.
    zoo truck[QUOTED] and Junkhead like this.
