Best tire size for 18x9 rims?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tscurtis, Apr 14, 2016.
  1. Apr 14, 2016 at 12:56 PM
    Tscurtis
    Tscurtis [OP] Member
    Tyler
    2010 Toyota Tacoma
    So I have a 2010 Toyota Tacoma and I'm about to lift it 3in. I'm new to this, so I was looking at getting 18x9 rims. What is the best size tire to buy to fit that size rim?
  2. Apr 14, 2016 at 1:01 PM
    Artruck
    Artruck Well-Known Member
    Lawrence, KS
    '09 Super Basic
    Welcome to tacomaworld.
    At the bottom of the page is a tire size calculator to compare sizes, and i think 285 75 16 is what most guys run on that size lift. So I would play around and check sizes against that. Also look up build pages for guys with 18s. I generaly google "tacomaworld" then what ever Im looking for. I find it faster than the search function.
  3. Apr 14, 2016 at 1:01 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    TRD Supercharger, TRD exhaust, Leather seats, running boards removed (why it came with them I cannot imagine), Salex organizers, BAMF behind-the-grill light bar, Rigid SR-20 and SR-Q - Spots mounted behind stock grill, color-matched grill, WeatherTech FloorLiner DigitalFit floor mats, Tech Deck, Avid bolt-on slider/step converted to weld on by TW member Achirdo, Diaz Fabrication Model T, Icon Stage 4 with OME Dakar rear leaf springs, OME Driveshaft spacer, Toytec 1" Front Diff Drop, FN BFD 18"x9" GMG Wheels, BFG KO2 285-65-18 tires, Ultragauge mounted above mirror, Tuffy Box lockable storage, MattGecko rear window security bar, Relentless Fab tailgate protector, CSJumper 700 lumen flood pattern back-up LED's, modified BeeRadd under-hood lighting with two KC Cyclones; KB Voodoo cargo management system and standard rails, AllPro hi-lift jack mount, 48" hi-lift, RCI Metalworks aluminum front skid, Flyzeye 3VP-RS in glovebox and console, AFE CAI, Coupe fuse box cover, battery hold-down bracket and CAI air-box cover, Wurton pod led's installed as bed lights on Lowbrow Customs motorcycle fork brake line aluminum brackets, Pop-n-Lock PL5400, Extang Solidfold 2.0, Rechelon Retro's, Moromoto LED fogs, URD Y-pipe, Walbro 255lph fuel pump, Speedhut AFR and Boost gauges, Cravenspeed gauge holder, CMC by Tandem Automotive, 70mm throttle body, CSF radiator, Doug Thorley shorties, Vibrant 7101 cats, SOS Offroad front and rear bumpers, Smoothflow 2.5” SC pulley, Steeda SC belt tensioner, roostfactor belt wrap kit, switch Pro 9100 in custom Tandem Automotive holder, WAT trans valvebody, FIC 650cc injectors, HP Tuner.
    285/65/18
  4. Apr 14, 2016 at 1:16 PM
    Tscurtis
    Tyler
    2010 Toyota Tacoma
    If I put 285/65/18 on a 3in lift. Would my tires rub?
  5. Apr 14, 2016 at 1:23 PM
    Artruck
    Lawrence, KS
    '09 Super Basic
    Depends on wheels and tires. Search for backspacing guidelines. You might need to trim a bit.
  6. Apr 14, 2016 at 1:34 PM
    Tscurtis
    Tyler
    2010 Toyota Tacoma
    Thanks everyone!
  7. Apr 14, 2016 at 1:34 PM
    ThomasMore66
    Anything above 265 will rub some. I removed flaps and trimmed some inner fender. I should do a CMC, but I only hit the frame at full lock and a compression. I'm not a huge off-roader. I stick to the trail. 285's are the recommendation of Icon and I have an Icon lift. I just followed along. Besides, 285's look badass.
  8. Apr 26, 2016 at 11:18 PM
    Tscurtis
    Tyler
    2010 Toyota Tacoma
    Ok so the rims I'm getting are 9in in width and my stock rims are 7.5in and the tires that are on the stock rims are 265/70/17 would those tires still work on the new rims?
