best tie rods for lifted trucks
Discussion in '1st Gen. Tacomas (1995-2004)' started by thumper72, Feb 7, 2016.
  1. Feb 7, 2016 at 12:23 PM
    thumper72
    thumper72 [OP] Well-Known Member
    Jon
    Ogden Utah
    2000 toyota tacoma prerunner v6 auto
    5100's, ome dakar leafs and ome coils, problem solver tie rods, eazycompany ditch light brackets and auxbeam osram 4" led pods, 2014 4runner wheels, 265/70/17 goodyear authority tires, soon to have 50" led bar on roof
    I have read a lot of threads moog verses oem and such but it seems pretty much undecided and i'm in need of a drivers side inner tie rod so i'm going to replace them all to be on the safe side. so what kind are going to last me on a 00 prerunner and is going to be great?? if you have links to sites that would be awesome... don't mind if aftermarket prefer it to be honest as they are generally better designed then oem...
  2. Feb 7, 2016 at 12:47 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    moog is crap value line. not meant for heavy usage (light driving with lifted trucks). go for OEM or raybestos professional.
  3. Feb 7, 2016 at 1:49 PM
    98 Taco Max
    98 Taco Max Well-Known Member
    Max
    Calgary, AB
    v6 Tacoma 4x4
    OEM, i trust their proven quality and reliability, for steering and ball joints i say why cheap out
    if you want to save some cash and go with a cheaper brand then you should be checking on them more often and possibly doing preventative maintenance over shorter lifespans, im sure moogs are just fine, but almost certainly wont last as long and higher risk of failures because of poorer manufacturing/quality standards compared to oem
    both will do that job, depends on how you use your truck, how comfortable you are with doing your own maintenance, budget, etc. and how big a lift you're referring to....
  4. Feb 7, 2016 at 1:53 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
  5. Feb 7, 2016 at 2:19 PM
    thumper72
    Jon
    Ogden Utah
    i just bought the truck a month ago and am trying to replace things on the suspension right now and just took it into toyota and he said the front drivers side inner tie rod has a little play so i just want to replace them all at the same time so i can get a base line of when stuff is needed for a maintenance schedule.... don't care the cost want something that is going to with stand time and abuse is all, my lift is about 2" over stock also sry
  6. Feb 7, 2016 at 2:45 PM
    CodeSeven
    Serge.
    Coachella Valley
    for a simple little lift like 2 inches, just take your truck to an alignment tech and tell him to swap out the tie rods or give him the tie rods to swap out. no need to find a mechanic.
    thumper72[QUOTED][OP] likes this.
  7. Feb 7, 2016 at 2:46 PM
    98 Taco Max
    Max
    Calgary, AB
    v6 Tacoma 4x4
    I did the same thing when I first got my truck at 200k kms, replaced upper and lower bjs and inner and outer tie rods all OEM parts, they were more expensive than napa parts (also had to pay exchange rate and shipping from the states to Canada) but we'll worth it. If moneys not an issue, Can't go wrong with OEM :thumbsup: that's my 2cents anyways
    thumper72[OP] likes this.
  8. Feb 7, 2016 at 2:54 PM
    Trapperr
    Trapperr Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I went with the Napa precision or performance line on tie rods. Also going to lift. I'll let you know how they are
  9. Feb 7, 2016 at 2:55 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    OEM lasted 16 years. Go with OEM if you want similar longevity.
