Best suspension setup for rough dirt / gravel road?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SMG, Feb 21, 2013.
  1. Feb 21, 2013 at 4:28 PM
    SMG
    SMG [OP] Member
    Nova Scotia
    2022 TRD Off Road Premium
    OEM LED Headlights, TRD Pro Taillights.
    Hey guys,
    The winter roads just owned my stock 04 TRD's suspension and I put a used stock suspension on today to get me by for now. I've lived here for a long time but I've never seen the roads get this bad it's been unreal. Usually the roads are great all year round but this year has been very warm and wet.
    Anyway, what would you guys recommend for a suspension setup to take a bit of abuse? I try to drive carefully but I just can't stand to crawl. I don't hit a cringeworthy bump very often. It's a very level road but it's just completely full of potholes and washboard.
    Any help would be much appreciated! I'm definitely not scared to spend >$1000 for a good setup that will last.
    Thanks!
  2. Feb 21, 2013 at 5:09 PM
    Trusso24
    Trusso24 Well-Known Member
    Tony
    San Luis Obispo
    99 Prerunner XCab
    Fox Coilovers Blacked Out Debadged
    I access a similar road and I've come down to the decision of an OME lift kit with nitro charger shocks and dakar leafs. Developed in Australia for the bumpy outback but is a great all around set up it seems. Around that price online. Waiting for my funds to pull the trigger. That's my .02
  3. Feb 21, 2013 at 6:00 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    mid travel setup for you would be perfect..
  4. Feb 21, 2013 at 7:15 PM
    SMG
    SMG [OP] Member
    Nova Scotia
    Thanks guys! Does the OME count as a mid-travel?
  5. Feb 21, 2013 at 7:20 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    no it doesn't.
    Id get some Fox or King extended travel Coil OVers with resi's on them with new UCAs from Camburg. Then take off your sway bar. Front will ride like butter.
    For the rear id go for some fox shocks as well or kings. Get some new leaf packs. Dakars or Wheelers 5 packs with wheelers AAL would be nice.
    Not going to be cheap however..
  6. Feb 21, 2013 at 7:21 PM
    ethanfoy
    ethanfoy Well-Known Member
    ethan
    Little Rock AFB
    99 toyota tacoma xcab 4x4
    I think you have to get new ucas for mid travel correct me if I'm wrong.
    Beat me to it^
  7. Feb 21, 2013 at 7:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    and slightly longer shocks.
  8. Feb 21, 2013 at 7:28 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    Fuck it sas it
  9. Feb 21, 2013 at 7:33 PM
    sk8rjess
    sk8rjess IG: @whoishack
    Cody
    Nashville, TN
    02 4x4 sr5
    some duct tape and zip ties
    he wants a smooth ride. he can do that a lot cheaper staying away from a SAS lol
  10. Feb 21, 2013 at 7:37 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    But but but he said he's okay with over a grand
  11. Feb 21, 2013 at 7:41 PM
    scocar
    scocar hypotenoper
    These guys will spend all your money faster than you can. For what you describe, OME is perfect, and disconnecting the swaybar (only with stronger aftermarkt coils) will really help soak up the bumps. Ther's a forestry road up near Donner Summit that sounds very much like what you descrieb, and the OME cruises over it, and makes it downright fun.
  12. Feb 21, 2013 at 7:55 PM
    sk8rjess
    Cody
    Nashville, TN
    02 4x4 sr5
    :laughing:
    what are you talking about.. we've already charged it to his card :typing:
    but honestly, what Blackdawg and scocar both said would work. it all honestly boils down to what you want to spend.
  13. Feb 21, 2013 at 8:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Also maybe investing in some OBA or a co2 system so you could air down a bit on the dirt roads, that would help a lot.
  14. Feb 22, 2013 at 5:43 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    You could save some money on the rear leafs and do the spring refurbishing mod.
    Here's a link to the thread, all the info is in there.
    http://www.tacomaworld.com/forum/suspension/194386-tacoma-spring-refurbishing.html
    There are a bunch of guys running them with good results out West mobbin dez or w/e west coast nonsense they call it:boink:
    This would allow you to spend more money on UCA's, coilovers & rear shocks. It sounds like it would be more beneficial to you to spend more on good shocks with proven damping/ rebound than expensive ass rear lift leafs.
    Just my .02...
  15. Feb 22, 2013 at 8:30 AM
    scocar
    scocar hypotenoper
    Actually, Jordan, a little more info about your roads and conditions might help.
    What kind of mileage are you talking about, and on what surfaces? Obviously the washboard is dirt/gravel, but do you also have paved roads with bad potholes, etc.? And what distances are we talking about? And do you ever drive significant distances at freeway speeds on good, smooth roads, and is this your daily driver/only vehicle, and do you frequently carry heavy loads in the bed, or nothing at all?
    Monte brought up onboard air. That seems potentially a little elaborate in a commuting situation (if that is your situation), but it made me think that a different tire/wheel setup could also help you soak up potholes, like 15 inch wheels with 33s, and lower air pressure.
    And Sloths' point is valid, too. Good shocks can make a big difference in this situation. What do you have now, and how many miles are on them?
  16. Feb 22, 2013 at 8:33 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I know a few guys in heavily snowed areas that run 20psi till it warms up again..but they have snow almost all winter. I know that wouldn't work where i live.
    I agree though, more info on the roads and your driving situation.
    Im still thinking a nice coilover and nice rear shocks though for the smoothest ride if thats what you want.
  17. Feb 22, 2013 at 8:38 AM
    scocar
    scocar hypotenoper
    Yeah, the rear is going do dance and buck all over the goddman place with worn out or weak shocks and no load in the bed in these conditions. Hell, it will do that on interstate in bad repair.
  18. Feb 22, 2013 at 8:39 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yep. And with squishy stock leafs..not doing any favors either lol
  19. Feb 22, 2013 at 8:41 AM
    scocar
    scocar hypotenoper
    POS fucking worthless crap. :mad:
